VE After Upgrade throws exception on open [message #102169] |
Sun, 14 August 2005 22:08  |
I just upgraded VE, and when I open a previous visual edit developed class I
get the following exception in the Eclipse log. Can someone suggest the
next step? I have tried -clean and othere remedies, but nothing seems to
fix this one.
java.lang.NoClassDefFoundError: org/eclipse/ve/internal/cde/palette/Root
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Unknown Source)
at java.lang.Class.getConstructor0(Unknown Source)
at java.lang.Class.newInstance0(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
at
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExte
nsion(ConfigurationElement.java:162)
at
nsion(ConfigurationElement.java:142)
at
nsion(ConfigurationElement.java:129)
at
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutab
leExtension(ConfigurationElementHandle.java:48)
at
org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java
:232)
at
org.eclipse.ui.internal.registry.EditorDescriptor.createEdit or(EditorDescrip
tor.java:252)
at org.eclipse.ui.internal.EditorManager.createPart(EditorManag er.java:837)
at
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.jav
a:543)
at
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:365)
at
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReferenc
e.java:552)
at
org.eclipse.ui.internal.EditorReference.getEditor(EditorRefe rence.java:214)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.ja
va:2325)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2258
at org.eclipse.ui.internal.WorkbenchPage.access$9(WorkbenchPage .java:2250)
at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.ja va:2236)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2231)
at org.eclipse.ui.actions.OpenWithMenu.openEditor(OpenWithMenu. java:279)
at org.eclipse.ui.actions.OpenWithMenu.access$0(OpenWithMenu.ja va:271)
at org.eclipse.ui.actions.OpenWithMenu$2.handleEvent(OpenWithMe nu.java:178)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3080)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2713)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.
java:226)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Bud Curtis
Colorado Springs, CO
Re: VE After Upgrade throws exception on open [message #102316 is a reply to message #102271] |
Mon, 15 August 2005 23:00  |
Thank you Rich. That was the problem. There was a
"org.eclipse.ve.cde_11.0.0" in the plugin folder. After deleting it the VE
comes up without an error. Thank you again!
Bud Curtis
"Rich Kulp" <richkulp@us.NO_SPAM.ibm.com> wrote in message
news:ddquqv$e4u$1@news.eclipse.org...
> One more thing, if you had upgraded from an older VE 1.1 development
> driver, we had accidently shipped it as CDE plugin version 11.0 when it
> should of been 1.1. Make sure you don't have a CDE plugin at version 11.0
> Rich Kulp wrote:
> > Are there any other errors in the log? This means that the configuration
> > is not correct.
> Rich Kulp
Re: VE After Upgrade throws exception on open [message #610283 is a reply to message #102224] |
Mon, 15 August 2005 16:44  |
> is not correct.
Rich Kulp
Re: VE After Upgrade throws exception on open [message #610296 is a reply to message #102271] |
Bud Curtis
> > is not correct.
> Rich Kulp
FUDForum. Page generated in 0.07200 seconds
