Home » Eclipse Projects » Standard Widget Toolkit (SWT) » SWT source code for 32-bit Eclipse 4.3
SWT source code for 32-bit Eclipse 4.3 [message #1022845] Fri, 22 March 2013 12:21 Go to next message
I checked out the SWT source code from Git and switched to the Tag v4319. However, I found that the source code is for 64-bit (e.g. Many APIs return long instead of int). How can I obtain the source code for 32-bit. Thanks!
Re: SWT source code for 32-bit Eclipse 4.3 [message #1022919 is a reply to message #1022845] Fri, 22 March 2013 15:48 Go to previous message
Found the info in http://www.eclipse.org/swt/faq.php#gtk32
Previous Topic:Weird problems resizing Shell with 'setBounds()'
Next Topic:SWT OLE doVerb makes application menu disappear
Current Time: Sat Aug 30 19:41:23 EDT 2025
Powered by FUDForum. Page generated in 0.04710 seconds
