Home » Newcomers » Newcomers » Please help me about red underline !
Please help me about red underline ! [message #1022128] Thu, 21 March 2013 06:18 Go to next message
index.php/fa/13962/0/When i create one new Servelet. It appear this error.
Please help me !!
  • Attachment: ga.JPG
    (Size: 114.17KB, Downloaded 1217 times)
Re: Please help me about red underline ! [message #1022213 is a reply to message #1022128] Thu, 21 March 2013 09:47 Go to previous messageGo to next message
What is the version of Java that you are using for this project? (right click -> Build Path -> Configure Build Path -> Libraries). Javax.servlet is part of Java EE (enterprise edition) not Java SE (standard edition), so if you have something like J2SE-1.5, JavaSE-1.6 or JavaSE-1.7 it won't work. You need to download JavaEE-1.6 then go in Window -> Preferences -> Java -> Installed JRE and add the path of your newly installed version of Java. Finally, go back in the build path of your project and edit the JRE library used to select JavaEE-1.6.
Stephane Begaudeau, Obeo
Twitter: @sbegaudeau
Google+: +stephane.begaudeau
Blog: http://stephanebegaudeau.tumblr.com | Eclipse Java Development Tools Tips and Tricks
Re: Please help me about red underline ! [message #1022843 is a reply to message #1022213] Fri, 22 March 2013 12:20 Go to previous message
If the project is targeting a valid server, the server should already be providing those libraries since it needs them to run itself. It's more likely that the project is either not targeting a server, or the chosen server is somehow not providing the basic Servlet APIs as libraries on the Java Build Path (and they should be coming from a server).
Previous Topic:Pre-configuring Eclipse Formatter
Next Topic:Eclipse Status Line
Current Time: Sat Jul 26 12:04:35 EDT 2025
Powered by FUDForum. Page generated in 1.11289 seconds
