Home » Archived » BIRT » How to Use User Properties
How to Use User Properties [message #1022810] Fri, 22 March 2013 11:10 Go to next message
can someone explaine me how (or for what) to use User Properties? I can set a user property for every element in the design. But I only can defined it, not set a value for it. Can I do this only per Java/Javascript? I want to define a property (with value) in the Report.
Example:
For an image I want to say: grayscale = true; Than I read the Property during the birt process and create my Image in grayscale mode. Parsing the Reportdesign is no Problem. I can read everything with the birt api, but I found no "Definition-Place" for this Information.
But I think, the user Properties are for this usage, or?
Thomas
Re: How to Use User Properties [message #1027388 is a reply to message #1022810] Tue, 26 March 2013 19:15 Go to previous messageGo to next message
When you give an element a user property, you're simply assigning a new property for the element. Once you've give a new property, you can set that property via "setProperty(propertyName,propertyValue)". For example, if you created a user property for an element called "isgray", then set the value of that parameter in your beforeFactory or wherever, like:
reportContext.getDesignHandle().findElement("myTable").setProperty("isgray",params["isgray"]);
The property "isgray" for the table is now set to whatever the parameter value is. In your onCreate, you can check the value of this property, like:
if(this.getUserPropertyValue("isgray") == "yes"){
this.getStyle().backgroundColor = "gray";
If the parameter is "yes", it'll be gray, if it's "no", it'll be the default color.
Re: How to Use User Properties [message #1027626 is a reply to message #1027388] Wed, 27 March 2013 03:37 Go to previous messageGo to next message
thank you very much. That is a way I can go. But why couldn't I set a "Default" with the Report Designer. Could may be a feature Request.
Thomas
Re: How to Use User Properties [message #1029537 is a reply to message #1027626] Fri, 29 March 2013 16:55 Go to previous message
Yeah. I'm not certain why a default is not available. You could definitely request an enhancement for a default value setting. If you log the request, put the info in here for others to vote on the feature. Thanks.
Previous Topic:List display records new new row in xls vesrion.
Next Topic:NullPointerException on chart with mouseover tooltip
Current Time: Fri Jul 18 21:07:55 EDT 2025
Powered by FUDForum. Page generated in 0.27052 seconds
