Home » Modeling » TMF (Xtext) » Logical containers for expressions (again)
Logical containers for expressions (again) [message #1022358] |
Thu, 21 March 2013 14:25  |
I have a model with lots of xbase expressions, which are spread across
many methods in the inferred and generated Java code. E.g. all
expressions for initializing my variable-like construct end up in a
single initialize method. E.g. the following DSL code
var Double d1 = new Double(1);
var Double d2 = new Double(2);
generates the following initialize code:
Double d1;
Double d2;
void initialize() throws IllegalActionException {
Double _d1 = new Double(1);
this.d1 = _d1;
Double _d2 = new Double(2);
this.d2 = _d2;
Each of the initial value expressions are all assigned to the initialize
method as their logical container. This will ensure that they are
properly scoped. However, after moving to xbase 2.4, this stopped
working. In this particular example, the Double constructor in the
second expression (new Double(2)) didn't resolve, but the one in the
first did. In other examples, the problem is always that something in
all but the first expression assigned to a logical container does not
resolve.
When I created a separate method that wrapped (was assigned as the
logical container of) each expression it worked again. I.e.
Double initD1() throws IllegalActionException {
return _d1;
Double initD2() throws IllegalActionException {
return _d2;
this.d1 = initD1();
this.d2 = initD2();
Is it a (new) constraint in xbase 2.4. that a method can only be the
logical container of a single expression?
Hallvard
Re: Logical containers for expressions (again) [message #1022789 is a reply to message #1022358] |
Fri, 22 March 2013 10:28   |
Hi Hallvard,
the logically contained expression is actually the body of the method,
so each method can only have one contained *root* expression. This was a
bug in the previous version that could have cause trouble and
inconsistencies in the compiler if this *feature* was used by accident.
Why did you want to initialize all variable in one separate method? This
will most likely confuse the Java compiler, too, e.g. when it tries to
verify definite assignment / initialization.
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Am 21.03.13 19:25, schrieb Hallvard Trætteberg:
> Double d1;
> Double d2;
> this.d1 = _d1;
> this.d2 = _d2;
> resolve.
> return _d1;
> return _d2;
> this.d1 = initD1();
> this.d2 = initD2();
> Hallvard
Re: Logical containers for expressions (again) [message #1022851 is a reply to message #1022789] |
Fri, 22 March 2013 12:35   |
Which I apparently did. I've now defined a method for each of the
expressions, which is called where the expressions previously were
placed. This results in very verbose classes, and worse, the methods are
visible everywhere, so it clutters the completion proposals.
If several expressions in a DSL are supposed to end up as *part* of a
method's body, what is the best way to do it, to get scoping etc. right?
In know, but the life-cycle of the instances is controlled by a
framework/protocol that requires initialization to be in a specific
method. There are also issues with exceptions.
Hallvard
Re: Logical containers for expressions (again) [message #1023263 is a reply to message #1022851] |
Sat, 23 March 2013 15:58  |
Am 22.03.13 12:35, schrieb Hallvard Trætteberg:
> Hallvard
Hi Hallvard,
if you make the synthesized methods private and start their names with
an underscore, they will not be visible from content assist.
In the future we'll likely (no promises, though) offer an API that'll
allow to delegate to existing expression from new ones, e.g. you could
create a block as the body of the initializer method, and nest these
delegators in the block that will cover your init expressions.
Sebastian
Current Time: Sat Jul 26 23:33:23 EDT 2025
Powered by FUDForum. Page generated in 0.05957 seconds
