Home » Modeling » TMF (Xtext) » JvmModelInferrer and InferredTypes
JvmModelInferrer and InferredTypes [message #1022422] Thu, 21 March 2013 17:01 Go to next message
i a playing around with xbase' new typesystem.
here is my grammar
Model:
	elements+=Element*;
Element:
	"field" name=ID "=" init=XExpression;
I want to create a javabean out of this. here is my inferrer
class MyDslJvmModelInferrer extends AbstractModelInferrer {
	@Inject extension JvmTypesBuilder
	@Inject extension TypeReferences
   	def dispatch void infer(Model model, IJvmDeclaredTypeAcceptor acceptor, boolean isPreIndexingPhase) {
   		acceptor.accept(model.toClass("my.company.greeting.MyGreetings"))
   			.initializeLater([
   				for (e : model.elements.filter(x|x.name != null && x.init != null)) {
   					val f = e.toField(e.name, inferredType) [
   						initializer = e.init
   					members += f
   					members += e.toGetter(e.name, inferredType(e.init))
   					members += e.toSetter(e.name, inferredType(e.init))
somehow the inferring is not working
field xxxx = "aaaa"
@SuppressWarnings("all")
public class MyGreetings {
  private String xxxx = "aaaa";
  public Object getXxxx() {
    return this.xxxx;
  public void setXxxx(final String xxxx) {
    this.xxxx = xxxx;
what am i missing?
another question is: can i use an inferred type without
actually reusing the xexpression the inferrer
(e.g. leave out initializer = e.init)
val f = e.toField(e.name, inferredType(e.init)) []
   					members += f
this gives me
Cannot infer type from recursive usage. Type 'Object' is used.
or should i use a "typeprovider" diectly in this case. if so what would be the replacement for the deprecated old one.
Christian
Re: JvmModelInferrer and InferredTypes [message #1022776 is a reply to message #1022422] Fri, 22 March 2013 09:54 Go to previous message
Hi Christian,
there is no API for that purpose available yet, but you could try to use
the type of the field itself, e.g. this inferrer works for me:
acceptor.accept(model.toClass("my.company.greeting.MyGreetings")).initializeLater(
members += f
members += e.toGetter(e.name, f.type)
members += e.toSetter(e.name, f.type)
Regarding your second question: No, currently it's not easily possible
to have an inferred type without an associated expression, though we
definitely want to support that. The API as is is still rough and not
yet settled though your feedback is very valuable to use. Could you
collect that in a bugzilla ticket? We want to improve on that for all
Xbase clients until the bundles are sealed for the Kepler release.
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Am 21.03.13 22:01, schrieb Christian Dietrich:
> here is my grammar
> Model:
> elements+=Element*;
> Element:
> .initializeLater([
> x.init != null)) {
> members += f
> field xxxx = "aaaa"
> return this.xxxx;
> this.xxxx = xxxx;
> what am i missing?
> another question is: can i use an inferred type without actually reusing
> members += f
> this gives me
> Thanks
> Christian
Previous Topic:Check Type of Element
Next Topic:Updating completely hosed my environment
Current Time: Sun Jul 27 12:02:38 EDT 2025
Powered by FUDForum. Page generated in 0.04794 seconds
