Home » Archived » Test and Performance Tools Platform (TPTP) » Agent Controller Questions
Agent Controller Questions [message #102268] Mon, 02 July 2007 11:00 Go to next message
Originally posted by: cl.silistix.com
Hi all,
I have a few questions concerning the IAC.
My setup: eclipse3.3, TPTP4.4, fedora core 4 with jre1.6.0.
The IAC does not appear to be working. It is enabled and using the same
jre as eclipse but when I "test connection" under
preferences->profiling/logging->hosts there is no confirmation of
sucess. If I try to test my app I get "connection refused on local host".
Nowhere can I find mention of the Direct Local Connection. Is this not
included in TPTP4.4? I remember seeing it with a previous configuration
(eclipse3.2.2 TPTP4.3.1) and there are several posts on this group
saying that using the Direct Local Connection solved problems very
similar to mine.
I have tried using the standalone agent controller and I get the 36%
hanging problem.
This gets dumped to the shell that I started eclipse from when I get the
"connection refused" error:
at
org.eclipse.tptp.platform.iac.administrator.internal.startst op.AutoStartStop.hasProcessTerminated(AutoStartStop.java:275 )
at
org.eclipse.tptp.platform.iac.administrator.internal.startst op.AutoStartStop.startIAC(AutoStartStop.java:113)
at
org.eclipse.hyades.internal.execution.local.control.NodeImpl .connect(NodeImpl.java:283)
at
org.eclipse.hyades.execution.local.NodeImpl.connectUsingLega cyMethod(NodeImpl.java:431)
at
org.eclipse.hyades.execution.local.NodeImpl._connect(NodeImp l.java:122)
at
org.eclipse.hyades.execution.local.NodeImpl.connect(NodeImpl .java:359)
at
org.eclipse.hyades.execution.local.NodeImpl.connect(NodeImpl .java:347)
at
org.eclipse.hyades.execution.harness.TestExecutionHarness$4. run(TestExecutionHarness.java:2434)
at java.lang.Thread.run(Thread.java:619)
Sorry if I should have asked this in the other thread...
Craig
Re: Agent Controller Questions [message #102297 is a reply to message #102268] Mon, 02 July 2007 13:14 Go to previous message
Hi Craig,
Try to test IAC/AC with jre 1.5.
Regards, Igor
Previous Topic:Where can I find the source code of libpiAgent.so?
Next Topic:TPTP issues
Current Time: Sat Jul 26 23:22:26 EDT 2025
Powered by FUDForum. Page generated in 0.04533 seconds
