[XCore] derived feature unimplemented [message #1022244] |
Thu, 21 March 2013 10:34  |
another problem with (the newest M6 milestone of) XCore. There are two xcore projects named 'base' and 'extender'. The 'base' project is generated from base.xcore:
package base
class Foo {}
class Bar {
int x
int y
derived int sum get {
return x + y
class MyClass extends Foo, Bar {}
the 'extender' depends on 'base' and is genreated from extender.xcore:
package extender
import base.Foo
import base.Bar
The result is that base.MyClassImpl is different than extender.MyClassImpl. The getSum() method from base.MyClassImpl is generated correctly. The same method in extender.MyClassImpl throws UnsupportedOperationException. Is it a bug or did I miss something? Both projects are attached in the ZIP file.
FUDForum. Page generated in 0.04419 seconds
