Home » Archived » BIRT » Chart X Axis Labels inbetween data points?
Chart X Axis Labels inbetween data points? [message #1014879] Tue, 26 February 2013 11:23 Go to next message
Eclipse GuestFriend
Member
I have a dataset with categories on x axis and numbers on y axis. But the categories (x axis) represent datetime values. I won't explain why I use the categories instead of a datetime axis, just accept that I have a reason for it Wink
So my problem now is that I want to display hours on the x axis labels. Since my datapoints represent hourly aggregates, it would be inappropriate to put the label "10:00" under a datapoint which actually represents the aggregate 10-11 o'clock. So I want the date/datetime/time to be displayed under the tick to the left of the category. That way, the datapoint for the aggregate 10-11 o'clock would be positioned in the middle of the label '10:00' and the label '11:00' which makes it easier for the user to understand that it's the aggregate of 10:00-11:00.
By the way: "Cross between categories" doesn't work because it moves both the label and the datapoint.
In the attached picture you will understand what I mean: I create the labels from a string (in beforeDrawAxisLabel) but they should appear under the ticks and not under the datapoints.
Any help is very much appreciated!
Thanks in advance for your input. Cheers, Jakob
[Updated on: Tue, 26 February 2013 11:28] by Moderator
Re: Chart X Axis Labels inbetween data points? [message #1014941 is a reply to message #1014879] Tue, 26 February 2013 16:40 Go to previous messageGo to next message
You could try adjusting the inset on your axis label either from the chart editor or by using something like the following in your chart script:
function beforeDrawAxisLabel( axis, label, icsc )
if(axis.isCategoryAxis())
label.getInsets().setRight(20);
[Updated on: Tue, 26 February 2013 16:41] by Moderator
Re: Chart X Axis Labels inbetween data points? [message #1014946 is a reply to message #1014941] Tue, 26 February 2013 17:07 Go to previous messageGo to next message
Eclipse GuestFriend
Member
Thanks for the idea. That may work, but it puts some constraints: no chart resize, no resizing of the font / changing the font etc. Otherwise it will mess everything up. Furthermore it would not be possible to create a label for the last tick (as I would need one tick more than I have categories.
So... thanks so far, but if anybody has another idea I would appreciate it very much!
Re: Chart X Axis Labels inbetween data points? [message #1014953 is a reply to message #1014946] Tue, 26 February 2013 17:45 Go to previous messageGo to next message
I don't know that there will be another way. If you find one, please post it in here. I'll do the same.
Re: Chart X Axis Labels inbetween data points? [message #1022072 is a reply to message #1014879] Thu, 21 March 2013 04:34 Go to previous messageGo to next message
Hi, have you found solutions to achieve your goal? I came across the same problem and just need some advice, thanks.
[Updated on: Thu, 21 March 2013 04:40] by Moderator
Re: Chart X Axis Labels inbetween data points? [message #1023091 is a reply to message #1022072] Sat, 23 March 2013 04:08 Go to previous messageGo to next message
Eclipse GuestFriend
Member
No, I didn't find a solution and just went with labels '8:00-9:59 o'clock' for example. Maybe something which would work but which I did not try: A colleague came up with the idea: If I have the category 8:00 which stands for 8-10 o'clock, I would programmatically create a date add one hour, so the date would be 9:00. Then, in the axis settings, set the interval to 2, so that only ticks for 8:00 and 10:00 would be displayed. And the same for an interval of 1 hour, there one would set the interval to 1 and set the artificial date to 8:30.
Re: Chart X Axis Labels inbetween data points? [message #1023745 is a reply to message #1023091] Sun, 24 March 2013 23:37 Go to previous message
Well, thanks for your reply! I think I would go with your solution and just set the label text to a range such as "8-10".
Previous Topic:PDF export problem
Next Topic:Toggle between chart and table
Current Time: Tue Jul 22 04:20:13 EDT 2025
Powered by FUDForum. Page generated in 0.05359 seconds
