Home » Modeling » TMF (Xtext) » QualifiedNameProvider-Question(Perhaps a kind of bug? )
QualifiedNameProvider-Question [message #1021922] Wed, 20 March 2013 19:40 Go to next message
I'm just writing an own QualifiedNameProvider (extending DefaultDeclarativeQualifiedNameProvider) and a corresponding LinkingProvider (and i'm quite new to xtext). I nearly finished them both, when i discovered an error, telling me the method QualifiedName.create (org.eclipse.xtext.naming.QualifiedName.create(String singleSegment)) is throwing IllegalArgumentExceptions when the segment to be created is null.
We used this option for our defaultpackage (which doesn't have a name) but did first not notice that it doesn't work. Now i'm reworking the two classes, and with lots of printouts, i noticed that when only the QualifiedNameProvider is registered in the runtime, it neighter works nor does it throw Exceptions when providing "null" to the create method. There is no feedback telling me it doesn't work.
Only if i activate the LinkingProvider and inject the qualifiedNameProvider the exception is thrown.
Did i make a mistake or is there really no error telling me i'm feeding the create method a null?
PS: Is there any possibility to debug except System.out.println? It's quite time-consuming and annoying to start an eclipse application every time....
Re: QualifiedNameProvider-Question [message #1022033 is a reply to message #1021922] Thu, 21 March 2013 02:45 Go to previous message
Annika,
Comments below.
> is null. We used this option for our defaultpackage (which doesn't
Yes, better to use an empty string.
Perhaps something is catching the exception and logging it or even just
ignoring it.
It's hard to say...
The debugger is definitely your best friend. It has handy things like
exception breakpoints (see the toolbar in the title area of the
Breakpoint view), so you can set a breaking whenever a
NullPointerException is thrown. That will help you determine what's on
the call stack and how that exception is being handled by the things on
the call stack.
> every time....
The debugger supports hot replace so often you can change the code and
keep running...
Previous Topic:JvmType, add additional Types, that will be generated, but are not there YET
Next Topic:Editor Plugin fails to start
Current Time: Sun Jul 27 04:19:51 EDT 2025
Powered by FUDForum. Page generated in 0.03997 seconds
