Home » Modeling » M2T (model-to-text transformation) » [Acceleo] How to make a type cast?
[Acceleo] How to make a type cast? [message #1018839] Thu, 14 March 2013 10:58 Go to next message
I am using Acceleo with a meta-model with some inherited classes. Imagine classes 'child1' and 'child2' inherit from 'parent'.
I want to do this:
[for (_par : Parent | aModel.eAllContents()->filter(Parent))]
    _par.parentattribute1 [comment write parent attributes of the class/]
    [if (_par.oclIsTypeOf(child1))]
	[(child1) _par;/]     [comment this does not work!!/]
        _par.child1attribute1 [comment write child1 attributes of the class/]
    [/if]
    [if (_par.oclIsTypeOf(child2))]
	[(child2) _par;/]     [comment this does not work!!/]
        _par.child2attribute1 [comment write child2 attributes of the class/]
    [/if]
[/for]
As far as I know, to be able to read an attribute defined in a child class I need to cast my object to be seen by acceleo as a child class, and I do not know how to do this. I tried this in different ways, for example the one above, but this is not accepted by acceleo.
Do you know how to do it?
Re: [Acceleo] How to make a type cast? [message #1021074 is a reply to message #1018839] Tue, 19 March 2013 09:38 Go to previous messageGo to next message
[mySupertype.oclAsType(MySubType).mySubTypeAttribute]
"oclIsTypeOf(MyType)" returns true if your object has precisely the type "MyType".
"oclIsKindOf(MyType)" returns true if your object has or inherits from the type "MyType".
"oclAsType" cast the object into one of its inherited type.
Stephane Begaudeau, Obeo
Twitter: @sbegaudeau
Google+: +stephane.begaudeau
Blog: http://stephanebegaudeau.tumblr.com | Eclipse Java Development Tools Tips and Tricks
[Updated on: Tue, 19 March 2013 09:38] by Moderator
Re: [Acceleo] How to make a type cast? [message #1021108 is a reply to message #1021074] Tue, 19 March 2013 10:28 Go to previous messageGo to next message
Hi Stephane,
that is exactly what I was looking for, but it does not work for me. I typed this:
[if (_par.oclIsTypeOf(Child_Class))]
	[(_par.oclAsType(Child_Class)).ChildAttribute/]
[/if]
It does not work, in fact when Eclipse builds the code I get the "Unrecognized variable: (ChildAttribute)" error. That is, the if works well (at least it builds), but then I still cannot access the child attribute.
Do you know why?
Re: [Acceleo] How to make a type cast? [message #1021663 is a reply to message #1021108] Wed, 20 March 2013 09:27 Go to previous message
How is your meta-model structured? Can you reproduce the issue with a minimal example or could you attach your meta-model and a minimal Acceleo module showing the issue?
Previous Topic:[Acceleo] Invalid attributes during template invocation
Next Topic:Xpand Workflow file
Current Time: Sat Jul 26 10:29:14 EDT 2025
Powered by FUDForum. Page generated in 0.04394 seconds
