Home » Modeling » Papyrus » Papyrus install problems. And, what's needed for UML?
Papyrus install problems. And, what's needed for UML? [message #1021628] Wed, 20 March 2013 08:28 Go to next message
Just tried to install "Papyrus Runtime" from
http://download.eclipse.org/modeling/mdt/papyrus/updates/releases/helios
on Eclipse Helios, but it failed with the below message. Any idea what is going on?
I tried "Papyrus all" as well, but with similar results. I did manage to install "Papyrus UML", on the other hand. This also sort of raises a few additional questions, like:
  1. What exactly do I need to install to be able to edit UML diagrams?
  2. Why isn't "Papyrus Runtime" already installed after a successful "Papyrus UML" install? I mean, you'd think that a "runtime" would be a prerequisite for other components, or possibly that the other components would be part of the runtime, but neither seems to be the case here (?)
  3. Does Eclipse component installation always have to be so darn confusing??
- Toralf
(Error output follows.)
An error occurred while collecting items to be installed
session context was:(profile=PlatformProfile, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
Problems downloading artifact: osgi.bundle,org.eclipse.epf.common,1.5.0.201101131810.
File has invalid content:/tmp/signatureFile382439104790505828.jar
Invalid content:common.jar
The file "common.jar" in the jar "/tmp/signatureFile382439104790505828.jar" has been tampered!
Problems downloading artifact: osgi.bundle,org.eclipse.epf.common.html,1.5.0.201101131810.
File has invalid content:/tmp/signatureFile5549509020741295656.jar
Invalid content:lib/Tidy.jar
The file "lib/Tidy.jar" in the jar "/tmp/signatureFile5549509020741295656.jar" has been tampered!
Invalid content:commonHTML.jar
The file "commonHTML.jar" in the jar "/tmp/signatureFile5549509020741295656.jar" has been tampered!
Problems downloading artifact: osgi.bundle,org.eclipse.epf.richtext,1.6.0.201101131810.
File has invalid content:/tmp/signatureFile193915286673543073.jar
Invalid content:richtext.jar
The file "richtext.jar" in the jar "/tmp/signatureFile193915286673543073.jar" has been tampered!
Problems downloading artifact: osgi.bundle,org.eclipse.papyrus.diagram.common.palette.customization,0.7.3.v201104270854.
File has invalid content:/tmp/signatureFile4625254506578274974.jar
Invalid content:library.jar
The file "library.jar" in the jar "/tmp/signatureFile4625254506578274974.jar" has been tampered!
Re: Papyrus install problems. And, what's needed for UML? [message #1021632 is a reply to message #1021628] Wed, 20 March 2013 08:35 Go to previous messageGo to next message
I can say that I'm using Papyrus on Eclipse Juno, and the installation has no problems. Can you try to move to Juno?
Just installing Papyrus you can create and edit UML models
good luck!!
Re: Papyrus install problems. And, what's needed for UML? [message #1021677 is a reply to message #1021632] Wed, 20 March 2013 09:55 Go to previous messageGo to next message
Federico Toledo wrote on Wed, 20 March 2013 08:35
I might, but was rather hoping I wouldn't have to right now, as I seem to spend way too much time on getting everything up and running whenever I switch versions.
Maybe I'm forced to switch, though, to get the features I need, as when I look a bit closer, I notice that the release that works on Helios has rather incomplete UML support. I really wish that Papyrus could be built in a more platform-independent manner:-/ Not sure if it's technically possible, though...
good luck!!
What I was driving at, is that there isn't seems to be one obvious way to "just install Papyrus", since there are at least 3 different "top-level" packages. But maybe that's different with newer releases?
Re: Papyrus install problems. And, what's needed for UML? [message #1021682 is a reply to message #1021677] Wed, 20 March 2013 10:01 Go to previous messageGo to next message
Yes. It would be great not to have irritating progress such as fire,
wheels and telephones.
Juno gives you UML 2.4.1; enjoy.
Ed Willink
>> Hi,
> Quote:
>> good luck!!
Re: Papyrus install problems. And, what's needed for UML? [message #1021685 is a reply to message #1021677] Wed, 20 March 2013 10:09 Go to previous messageGo to next message
you can also use Papyrus standalone
http://www.papyrusuml.org/scripts/home/publigen/content/templates/show.asp?P=114&L=EN#2
Re: Papyrus install problems. And, what's needed for UML? [message #1021743 is a reply to message #1021685] Wed, 20 March 2013 11:58 Go to previous messageGo to next message
This is an old, deprecated, unmaintained version, for about 4 years now. So, you *can* use it, but won't get any support for it. Nor any "new" feature.
A litle bit of history:
Papyrusuml (1.12): Before 2009
-- Migrating Papyrus to the Eclipse Foundation --
Papyrus 0.7 (Helios): June 2010
Papyrus 0.8 (Indigo): June 2011
Papyrus 0.9 (Juno): June 2012
Papyrus 0.10 (Kepler): June 2013 - Developer builds only
I really recommend migrating to Juno (Either on Eclipse 3.8 or Eclipse 4.2).
Camille
Re: Papyrus install problems. And, what's needed for UML? [message #1022107 is a reply to message #1021682] Thu, 21 March 2013 05:38 Go to previous messageGo to next message
Ed Willink wrote on Wed, 20 March 2013 10:01
Yes. With any luck, though, "progress" will soon rid us of silly notions like being able to put improved variants of those wheels on a car without replacing the entire wehicle first...
Ed Willink
>> Hi,
Re: Papyrus install problems. And, what's needed for UML? [message #1738093 is a reply to message #1021632] Fri, 15 July 2016 13:09 Go to previous message
i am working with eclipse juno but i could not install papyrus.
i am following steps( help>install new software> work with: juno - http://download.eclipse.org/releases/juno
then i got error
org.eclipse.equinox.p2.core.ProvisionException
"Unable to read repository at http://download.eclipse.org/releases/juno/content.xml.
Address already in use: JVM_Bind"
Previous Topic:Where can I get these plugin?
Next Topic:Model synchronization in Sequence diagram
Current Time: Sun Jul 27 11:57:21 EDT 2025
Powered by FUDForum. Page generated in 0.04061 seconds
