Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [teneo] Problem with double index on column
[teneo] Problem with double index on column [message #1021019] Tue, 19 March 2013 07:29 Go to next message
I have a probably simple problem for which I cannot find a solution. I have the following mapping situation.
I have two main entities ORDER and PERSON. An ORDER can have PERSONs of different types assoicated (e.g. type "OWNER","RESPONSIBLE","RECEIVER"). I try so solve this by adding an entity ORDER_PERSON.
My current ecore model is as follows:
<ecore:EPackage xmi:version="2.0"
    xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
    xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="sample"
    nsURI="http://com.somesample" nsPrefix="sample">
  <eClassifiers xsi:type="ecore:EClass" name="Order">
    <eStructuralFeatures xsi:type="ecore:EAttribute" name="id" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//ELong"
        iD="true"/>
    <eStructuralFeatures xsi:type="ecore:EReference" name="orderPersons" ordered="false"
        lowerBound="0" upperBound="-1" eType="#//OrderPerson" containment="true" eOpposite="#//OrderPerson/order">
      <eAnnotations source="teneo.jpa">
        <details key="appinfo" value="@OneToMany(mappedBy=&quot;order&quot;, indexed=false)"/>
      </eAnnotations>
    </eStructuralFeatures>
  </eClassifiers>
  <eClassifiers xsi:type="ecore:EClass" name="Person">
        iD="true"/>
    <eStructuralFeatures xsi:type="ecore:EAttribute" name="name" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
  </eClassifiers>
  <eClassifiers xsi:type="ecore:EClass" name="OrderPerson">
        iD="true"/>
    <eStructuralFeatures xsi:type="ecore:EReference" name="order" ordered="false"
        unique="false" lowerBound="1" eType="#//Order" eOpposite="#//Order/orderPersons">
        <details key="appinfo" value="@JoinColumn(name=&quot;ORDER_ID&quot;, nullable=&quot;false&quot;)"/>
      </eAnnotations>
    <eStructuralFeatures xsi:type="ecore:EReference" name="person" ordered="false"
        unique="false" lowerBound="1" eType="#//Person">
        <details key="appinfo" value="@JoinColumn(name=&quot;PERSON_ID&quot;, nullable=&quot;false&quot;)"/>
      </eAnnotations>
    <eStructuralFeatures xsi:type="ecore:EAttribute" name="type" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
  </eClassifiers>
</ecore:EPackage>
The generated schema is as follows:
  create table T_ORDER (
        ID number(19,0) not null,
        DTYPE varchar2(255 char) not null,
        primary key (ID)
    create table T_ORDER_PERSON (
        ORDER_ID number(19,0),                       -- see question below
        PERSON_ID number(19,0) not null,
        TYPE varchar2(255 char),
        primary key (ID)
    create table T_PERSON (
        NAME varchar2(255 char),
        primary key (ID)
    create index T_OrderDTYPE on T_ORDER (DTYPE)
    alter table T_ORDER_PERSON
        add constraint FK_OrderPerson_person
        foreign key (PERSON_ID)
        references T_PERSON
        add constraint FK_OrderPerson_order
        foreign key (ORDER_ID)
        references T_ORDER
    create index T_OrderPersonDTYPE on T_ORDER_PERSON (DTYPE)
    create index OrderPerson_person on T_ORDER_PERSON (PERSON_ID)
    create index Order_orderPersons on T_ORDER_PERSON (ORDER_ID)  -- see question below
    create index OrderPerson_order on T_ORDER_PERSON (ORDER_ID) -- see question below
    create index T_PersonDTYPE on T_PERSON (DTYPE)
    create sequence hibernate_sequence
I have two issues:
1. How to get T_ORDER_PERSON.ORDER_ID not nullable?
2. How do I get rid of the second index (OrderPerson_order) on T_ORDER_PERSON.ORDER_ID?
Any help would be appreciated.
Thorsten
[Updated on: Tue, 19 March 2013 07:30] by Moderator
Re: [teneo] Problem with double index on column [message #1021168 is a reply to message #1021019] Tue, 19 March 2013 11:44 Go to previous messageGo to next message
Hi Thorsten,
I will need to try it myself in a testcase (using your model) to do some debugging. If you haven't gotten a reply in a
few days from me then feel free to ping on the forum again (in a friendly way :-).
gr. Martin
On 03/19/2013 12:29 PM, Thorsten Schlathölter wrote:
> iD="true"/>
> <details key="appinfo" value="@OneToMany(mappedBy="order", indexed=false)"/>
> </eAnnotations>
> </eClassifiers>
> iD="true"/>
> </eClassifiers>
> iD="true"/>
> <details key="appinfo" value="@JoinColumn(name="ORDER_ID", nullable="false")"/>
> </eAnnotations>
> <details key="appinfo" value="@JoinColumn(name="PERSON_ID", nullable="false")"/>
> </eAnnotations>
> </eClassifiers>
> </ecore:EPackage>
> primary key (ID)
> primary key (ID)
> primary key (ID)
> alter table T_ORDER_PERSON add constraint FK_OrderPerson_person foreign key (PERSON_ID)
> references T_PERSON
> alter table T_ORDER_PERSON add constraint FK_OrderPerson_order foreign key (ORDER_ID)
> references T_ORDER
> I have two issues:
> 2. How do I get rid of the second index on T_ORDER_PERSON.ORDER_ID?
> Regards,
> Thorsten
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [teneo] Problem with double index on column [message #1021328 is a reply to message #1021168] Tue, 19 March 2013 17:54 Go to previous messageGo to next message
Thank you Martin for your attention. If you can put some light into this I would really be thankful. Meanwhile it is more of an academic question because I have simply modified my schema. But still it is something between me and Teneo. I have spend a lot of time in this and other related mapping problems and somehow I am at a point of no return Smile. It's probably just some very simple configuration issue.
I really appreciate your work and your committment!
Thorsten
Re: [teneo] Problem with double index on column [message #1021342 is a reply to message #1021328] Tue, 19 March 2013 18:34 Go to previous messageGo to next message
Hi Thorsten,
Okay np, feel free to ask any other question. Also make sure to check out the global options which can be used to
control mapping behavior:
http://wiki.eclipse.org/Teneo/Hibernate/Configuration_Options
gr. Martin
> have spend a lot of time in this and other related mapping problems and somehow I am at a point of no return :). It's
> Regards,
> Thorsten
The Netherlands
Re: [teneo] Problem with double index on column [message #1021684 is a reply to message #1021342] Wed, 20 March 2013 10:06 Go to previous messageGo to next message
One thing that bothers me is the question if it was a good idea to choose Teneo for combining EMF/Hibernate or if I should have better chosen Texo/JPA? Is there a simple answer for that?
Thorsten
Re: [teneo] Problem with double index on column [message #1021705 is a reply to message #1021684] Wed, 20 March 2013 10:42 Go to previous message
Here are some tips:
- web service/web server environment --> texo/jpa
- RCP 2 tier (so rcp directly talking to the db): Teneo
- RCP 3 tier (so rcp <--> server <--> db): Texo/JPA using the TexoJSONResource
I like Texo very much because it is cleaner, Teneo works on the internals of Hibernate to make EMF work nicely with
Hibernate. Texo works with Hibernate in a standard way, that's why you can also use EclipseLink with Texo. In addition
Texo has all this other stuff related to json serialization, full web service crud support, test data generation, etc.
So if you have a choice I would use Texo...
The only missing feature in Texo is dynamic models, so models which change at runtime and need to deployed without
restarting the application, Teneo is capable of this, Texo is not.
gr. Martin
> Regards,
> Thorsten
The Netherlands
Previous Topic:[Teneo]dynamic table-name depending on attribute
Next Topic:[Texo] Retrieve children
Current Time: Wed Jul 23 04:48:33 EDT 2025
Powered by FUDForum. Page generated in 0.08864 seconds
