Home » Modeling » EMF » [CDO] Start own bundle in CDO Server
[CDO] Start own bundle in CDO Server [message #946554] Tue, 16 October 2012 05:36 Go to next message
I have a CDO server where I would like to add my own bundle. The bundle contains (CDO) code that reacts to a model change and does an operation (writes a file)).
It turns out to be really hard to start the "new" bundle together with the CDO server because:
- Either it will not start at all...
- Or it will start BEFORE CDO, which is not working since the bundle needs to create a CDO Session.
How can I do this properly?
Is there an CDO related osgi service or something that my bundle can depend on to make it start after the CDO server?
///Anders
Re: [CDO] Start own bundle in CDO Server [message #946629 is a reply to message #946554] Tue, 16 October 2012 07:01 Go to previous messageGo to next message
Am 16.10.2012 11:36, schrieb Anders Jönsson:
You may want to implement and contribute an org.eclipse.emf.cdo.spi.server.IAppExtension ;-)
Cheers
/Eike
http://www.esc-net.de
Re: [CDO] Start own bundle in CDO Server [message #947606 is a reply to message #946629] Wed, 17 October 2012 04:29 Go to previous messageGo to next message
Yes, it works perfect. Thanks a lot!
I use CDO client code in IAppExtension.start() to connect to the (same) server via tcp, start a session, open a view and listen to the model. Is this the preferred way to interact with the model or is there a more direct way to, for instance, open a view using CDO server code?
///Anders
Re: [CDO] Start own bundle in CDO Server [message #947618 is a reply to message #947606] Wed, 17 October 2012 04:43 Go to previous messageGo to next message
Am 17.10.2012 10:29, schrieb Anders Jönsson:
Excellent ;-)
Why not via JVM transport? That would be faster.
Yes.
You can open a ServerCDOView with these methods:
org.eclipse.emf.cdo.server.CDOServerUtil.openView(ISession, CDOBranchPoint, boolean, CDORevisionProvider)
org.eclipse.emf.cdo.server.CDOServerUtil.openView(ISession, CDOBranchPoint, boolean)
org.eclipse.emf.cdo.server.CDOServerUtil.openView(IView, boolean)
org.eclipse.emf.cdo.server.CDOServerUtil.openView(CommitContext, boolean)
But they have very limited capabilities, no write access, no invalidations. Just what's needed to traverse a state of
the model graph in terms of EObjects.
Cheers
/Eike
Re: [CDO] Start own bundle in CDO Server [message #947625 is a reply to message #947618] Wed, 17 October 2012 04:58 Go to previous messageGo to next message
>Yes.
Good to know. Thanks again!
///Anders
Re: [CDO] Start own bundle in CDO Server [message #1019369 is a reply to message #947625] Fri, 15 March 2013 10:57 Go to previous messageGo to next message
Hi (again),
Is there a way to get notified when the CDO server has completed its startup (I thought IAppExtension would be it)?
In order to be able to run my own code in a cdo server application and specifically to start it in an orderly fashion i implemented an org.eclipse.emf.cdo.spi.server.IAppExtension.
In the IAppExtension I configure a CDOSession and start a CDOTransaction to the same server (which is currently beeing started).
It turns out there is no guarantee that the server is started, which may occasionally render an exception of type:
org.eclipse.net4j.util.lifecycle.LifecycleException: Could not activate TCPClientConnector[localhost:2,036]
It seems to be the "Net4j extension starting" part that may or may not have happened before the IAppExtensions are called.
///Anders
Re: [CDO] Start own bundle in CDO Server [message #1019376 is a reply to message #1019369] Fri, 15 March 2013 11:07 Go to previous messageGo to next message
You could start your bundle that contains your own extension at a higher start level than cdo/net4j.
If you are using a product definition to export your server, you can configure the start level of each bundle in the "Configuration" section.
Anders Jönsson wrote on Fri, 15 March 2013 15:57
Hi (again),
///Anders
Re: [CDO] Start own bundle in CDO Server [message #1019399 is a reply to message #1019369] Fri, 15 March 2013 11:42 Go to previous messageGo to next message
On 15-03-13 15:57, Anders Jönsson wrote:
> Hi (again),
The way we do it:
CDO has plugin extenstion points like here:
<extension
point="org.eclipse.net4j.util.elementProcessors">
<elementProcessor
class="com.netxforge.netxstudio.server.job.JobHandler$Initializer">
</elementProcessor>
</extension>
The class must implement IElementProcessor
public Object process(IManagedContainer container, String productGroup,
String factoryType, String description, Object element) {
if (element instanceof IRepository) {
final IRepository repository = (IRepository) element;
repository.addListener(new LifecycleEventAdapter() {
public void notifyLifecycleEvent(ILifecycleEvent event) {
if (event.getKind() == Kind.ACTIVATED) {
...DO YOUR THINGY HERE
return element;
> ///Anders
Re: [CDO] Start own bundle in CDO Server [message #1019456 is a reply to message #1019399] Fri, 15 March 2013 14:23 Go to previous messageGo to next message
Am 15.03.2013 16:42, schrieb Christophe Bouhier:
> [...] The way we do it:
> <extension
> <elementProcessor
> </elementProcessor>
> </extension>
> @Override
> return element;
That's what I was going to suggest ;-)
Cheers
/Eike
Re: [CDO] Start own bundle in CDO Server [message #1019474 is a reply to message #1019456] Fri, 15 March 2013 15:19 Go to previous messageGo to next message
Am 15.03.2013 19:23, schrieb Eike Stepper:
>> <extension
>> <elementProcessor
>> </elementProcessor>
>> </extension>
>> @Override
>> return element;
Oh, and you can do the same thing with the configured acceptor!
Cheers
/Eike
Re: [CDO] Start own bundle in CDO Server [message #1021126 is a reply to message #1019474] Tue, 19 March 2013 11:03 Go to previous messageGo to next message
Hi, thanks for suggestions!
But, when i put my thingy in place of the "...DO YOUR THINGY HERE" thingy I still get an exception:
org.eclipse.net4j.util.lifecycle.LifecycleException: Could not activate TCPClientConnector[127.0.0.1:2,036]
The "thingy" here beeing that I am trying to create a CDOSession to the server using tcp (apparently I should use "jvm transport" instead but I haven't gotten around to that yet).
And the output below still happens after that (at least it is PRINTED to the log after the stack trace):
[INFO] Net4j extension starting
!ENTRY org.eclipse.emf.cdo.server.net4j 1 0 2013-03-19 15:30:43.627
!MESSAGE Net4j extension starting
[INFO] Net4j extension started
!ENTRY org.eclipse.emf.cdo.server.net4j 1 0 2013-03-19 15:30:43.641
!MESSAGE Net4j extension started
[INFO] CDO server started
!ENTRY org.eclipse.emf.cdo.server 1 0 2013-03-19 15:30:43.642
!MESSAGE CDO server started
Also; Eike, can you give me a little more hint about what "the configured acceptor" is.
///Anders
Re: [CDO] Start own bundle in CDO Server [message #1021193 is a reply to message #1021126] Tue, 19 March 2013 12:27 Go to previous messageGo to next message
Is your code capable to open a TCPClientConnector without the Extension
mechanism that I described earlier?
ah, that's a different issue.
here is a snippet.
final IManagedContainer container = IPluginContainer.INSTANCE;
acceptor = JVMUtil.getAcceptor(container, "default");
connector = JVMUtil.getConnector(container, "default");
// Create configuration
final CDONet4jSessionConfiguration sessionConfiguration = CDONet4jUtil
.createNet4jSessionConfiguration();
sessionConfiguration.setConnector(connector);
sessionConfiguration.setRepositoryName(REPO_NAME);
> ///Anders
Re: [CDO] Start own bundle in CDO Server [message #1021194 is a reply to message #1021193] Tue, 19 March 2013 12:28 Go to previous messageGo to next message
BTW, I really recommend to checkout the cdo test plugin, it has tons of
examples.
> here is a snippet.
> CDONet4jUtil
>> ///Anders
Re: [CDO] Start own bundle in CDO Server [message #1021219 is a reply to message #1021126] Tue, 19 March 2013 13:16 Go to previous messageGo to next message
Hej Anders,
I meant that if you rely on a TCP connection to the repository you should not listen for repository activation but for
the TCP acceptor activation, in Christophe's words:
if (element instanceof ITCPAcceptor) {
final ITCPAcceptor acceptor = (ITCPAcceptor) element;
acceptor.addListener(new LifecycleEventAdapter() {
return element;
The acceptor is always started after the repository, i.e. in the Net4j extension.
Does that help?
Cheers
/Eike
Am 19.03.2013 16:03, schrieb Anders Jönsson:
> ///Anders
Re: [CDO] Start own bundle in CDO Server [message #1021518 is a reply to message #1021219] Wed, 20 March 2013 05:09 Go to previous message
Listening to ITCPAcceptor activation solves the problem!
Thanks also for the JVM acceptor snippet, will try that later.
Thanks a lot
///Anders
Previous Topic:[XCore] basicSet method generated multiple times
Next Topic:Create a view on a 'merged' feature maps
Current Time: Mon Jul 21 02:42:45 EDT 2025
Powered by FUDForum. Page generated in 0.06077 seconds
