Home » Modeling » TMF (Xtext) » Using data rule Id instead of ID terminal
Using data rule Id instead of ID terminal [message #1021177] Tue, 19 March 2013 12:02 Go to next message
I am writing a grammar using Xtext.
I have a rule representing a Display Format:
FormatSpec :
	DecimalFrmt	|
	ExponentialFrmt
DecimalFrmt:
	'S'? 'D' FieldWidth ('.' FracWidth)?;
FieldWidth:
	INT;
FracWidth:
	INT;
ExponentialFrmt:
	'S'? 'E' FieldWidth '.' FracWidth;
So the intention is to be able to read format strings as: D5.3 (meaning to display an integer using 5-digits and 3 decimals) SD5, E12.2, SE15.2 and so on.
The problem is that this kind of formats are shadowed by the (default) terminal ID. and I can't write them without white spaces ('S D 5' works fine but is not what I want).
So I tried to use a data Type Rule 'Id' instead of the terminal ID (which I disable).
	terminal ALFA:
		'a'..'z' | 'A'..'Z'
	terminal DIGIT:
		'0'..'9'
	AlfaNumber :
		ALFA | DIGIT
	Id:
		ALFA AlfaNumber*
The problem I have now is that the parser tries to match some parts of the id with some keywords. For example if I have a keyword 'FRMT' I get an error if I try to define an Id 'idFRM02'.
Is this normal? If yes, are there any work-arounds? I have run out of ideas. Thank you for helping!
Stefan
Re: Using data rule Id instead of ID terminal [message #1021258 is a reply to message #1021177] Tue, 19 March 2013 14:51 Go to previous messageGo to next message
yes you have to list the keywords together with the terminal rule in a datatype rule
example
Model: "model" name=MYID;
MYID: "model" | ID;
Re: Using data rule Id instead of ID terminal [message #1021499 is a reply to message #1021258] Wed, 20 March 2013 04:27 Go to previous messageGo to next message
Hi Christian,
Thanks for your answer.
This is not exactly my problem. What I want to do is to disable the default terminal ID completely and use only my datatype Id only (because ID shadows some other rules).
But if I do
Model: "model" name=Id;
Id:
	ALFA AlfaNumber* | 'model'
AlfaNumber :
	ALFA | DIGIT
terminal ALFA:
	'a'..'z' | 'A'..'Z'
terminal DIGIT:
	'0'..'9'
I still have the same problem when I try to parse model mod42 I have an error saying that it expects an 'e' instead of '4'.
Re: Using data rule Id instead of ID terminal [message #1021503 is a reply to message #1021499] Wed, 20 March 2013 04:35 Go to previous messageGo to next message
don't import Terminals.
Alex
Re: Using data rule Id instead of ID terminal [message #1021505 is a reply to message #1021499] Wed, 20 March 2013 04:38 Go to previous messageGo to next message
In fact maybe disabling the ID terminal is not the solution. What I want to do is simply to be able to use my rules (simplified):
FormatSpec :
	DecimalFrmt
DecimalFrmt:
	signed?='S'? 'D' digits=FieldWidth ('.' decimals=FracWidth)?;
to parse something like SD12.5 (and not S D 12.5).
What's the best way to achieve it? By default it doesn't work (if I got it right it's because SD12 is interpreted as an ID and the rule doesn't match anymore).
Thanks!
Stefan
Re: Using data rule Id instead of ID terminal [message #1021507 is a reply to message #1021505] Wed, 20 March 2013 04:44 Go to previous messageGo to next message
Hi Alex,
Well I don't import any terminals, I only use mines (ALFA, DIGIT). The problem is that the datatype rule Id doesn't work as expected where the terminal ID used to work ( for ids containing a part of a keyword).
But please check my previous message because that is what I am really trying to do. Maybe disabling the ID terminal is not the right way to do it.
Re: Using data rule Id instead of ID terminal [message #1021514 is a reply to message #1021499] Wed, 20 March 2013 04:57 Go to previous messageGo to next message
Which is the super grammar you use
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Re: Using data rule Id instead of ID terminal [message #1021517 is a reply to message #1021514] Wed, 20 March 2013 05:09 Go to previous messageGo to next message
At the begining I was using the default Terminals (with org.eclipse.xtext.common.Terminals) but I removed the import when I tried to disable the ID terminal.
Re: Using data rule Id instead of ID terminal [message #1021522 is a reply to message #1021517] Wed, 20 March 2013 05:15 Go to previous messageGo to next message
can you share a complete reproducable grammar and example model?
Re: Using data rule Id instead of ID terminal [message #1021546 is a reply to message #1021522] Wed, 20 March 2013 05:53 Go to previous messageGo to next message
Yes, here is my grammar. I repeat that what I would like to have is to be able to parse something like Object newObj FRMT SE5.2
This is the initial try. I use default terminals:
grammar org.xtext.example.mydsl.NewTest
hidden(WS)
generate newTest "http://www.xtext.org/example/mydsl/NewTest"
import "http://www.eclipse.org/emf/2002/Ecore" as ecore
Model: "Object"
	name=ID
	displayFormat=PresFormat
PresFormat:
	'FRMT'
	format=FormatSpec;
FormatSpec:
	DecimalFrmt	|
	ExponentialFrmt	|
	HexFrmt |
	CharFrmt
 DecimalFrmt:
	signed?='S'? 'D' width=FieldWidth ('.' decimals=FracWidth)?;
FieldWidth:
	UnsignedIntConst;
FracWidth:
	UnsignedIntConst;
ExponentialFrmt:
	signed?='S'? 'E' width=FieldWidth '.' decimals=FracWidth;
HexFrmt:
	'H'  width=FieldWidth;
CharFrmt:
	'C'  width=FieldWidth;
UnsignedIntConst returns ecore::EInt:
	DIGIT+;
terminal DIGIT:
	'0'..'9';
terminal INT returns ecore::EInt:
'this one has been deactivated';
When I try to parse Object newObj FRMT SE5.2 I get an error "No viable alternative at input 'SE5' ".
NOTE: it works fine for Object newObj FRMT S E 5.2 but I don't want the white spaces.
So I guessed it's because SE5 is interpreted as an ID and I wanted to disable the ID terminal and use a datatype rule instead. Here is my new grammar:
//with org.eclipse.xtext.common.Terminals
hidden(WS)
Model: "Object"
	name=Id
PresFormat:
	'FRMT'
	format=FormatSpec;
FormatSpec:
	DecimalFrmt	|
	ExponentialFrmt	|
	HexFrmt |
	CharFrmt
 DecimalFrmt:
FieldWidth:
	UnsignedIntConst;
FracWidth:
	UnsignedIntConst;
ExponentialFrmt:
HexFrmt:
CharFrmt:
	DIGIT+;
Id:
	ALFA AlfaNumber*
AlfaNumber :
	ALFA | DIGIT
terminal DIGIT:
	'0'..'9';
terminal ALFA:
	'a'..'z' | 'A'..'Z'
terminal WS			: (' '|'\t'|'\r'|'\n')+;
I try to parse again the same thing Object newObj FRMT SE5.2.
This time I get an error on the 'newObj' id : " Mismatched character ' ' expecting 'e' ". The 'SE5.2' seems to work.
I hope it's clear enough...
Thank you
Re: Using data rule Id instead of ID terminal [message #1021635 is a reply to message #1021546] Wed, 20 March 2013 08:41 Go to previous messageGo to next message
why not
Id hidden():
ALFA AlfaNumber*
AlfaNumber :
ALFA | DIGIT
terminal DIGIT:
('0'..'9')+;
terminal ALFA:
('a'..'z' | 'A'..'Z')+
Re: Using data rule Id instead of ID terminal [message #1021650 is a reply to message #1021635] Wed, 20 March 2013 09:08 Go to previous message
Well if I do this I get the first problem again: it won't parse the 'SE5.2' part as I expect (using the ExponentialFrmt rule) because the 'SE' is considered to be an ALFA terminal... I get "No viable alternative at input 'SE'".
Previous Topic:Xtext 2.4.0M6
Next Topic:Xbase and logical containers
Current Time: Mon Jul 21 01:22:28 EDT 2025
Powered by FUDForum. Page generated in 0.26858 seconds
