Home » Modeling » TMF (Xtext) » org.junit.ComparisonFailure when unittesting my language
org.junit.ComparisonFailure when unittesting my language [message #997302] Sat, 05 January 2013 05:38 Go to next message
Hello when unit testing my language I got into a weird error. When trying to isolate it I ends up with the same error for this language:
grammar org.xtext.example.mydsl.MyDsl with org.eclipse.xtext.common.Terminals
generate myDsl "http://www.xtext.org/example/mydsl/MyDsl"
Model: (typeImports+=IHT | typeDefines+=ED )*;
IHT returns ST:
  {IHT} 'imp' name=ID ';'
ED returns ST:
	{ED} 'enum' name=ID ';'
The error is:
org.junit.ComparisonFailure: expected:<[enum Y; imp X];> but was:<[imp X;enum Y];>
	at org.junit.Assert.assertEquals(Assert.java:123)
	at org.junit.Assert.assertEquals(Assert.java:145)
	at org.eclipse.xtext.junit4.serializer.SerializerTester.assertSerializeWithNodeModel(SerializerTester.java:96)
	at org.eclipse.xtext.junit4.AbstractXtextTests.getResourceAndExpect(AbstractXtextTests.java:271)
	at org.eclipse.xtext.junit4.AbstractXtextTests.getResource(AbstractXtextTests.java:244)
	at org.eclipse.xtext.junit4.AbstractXtextTests.getResource(AbstractXtextTests.java:219)
	at org.eclipse.xtext.junit4.AbstractXtextTests.getModel(AbstractXtextTests.java:190)
	at org.eclipse.xtext.junit4.AbstractXtextTests.getModel(AbstractXtextTests.java:186)
	at org.xtext.example.mydsl.tests.TestXTextBug.test(TestXTextBug.java:15)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
	at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:44)
	at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:15)
	at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:41)
	at org.junit.internal.runners.statements.InvokeMethod.evaluate(InvokeMethod.java:20)
	at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:28)
	at org.junit.internal.runners.statements.RunAfters.evaluate(RunAfters.java:31)
	at org.junit.runners.BlockJUnit4ClassRunner.runNotIgnored(BlockJUnit4ClassRunner.java:79)
	at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:71)
	at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:49)
	at org.junit.runners.ParentRunner$3.run(ParentRunner.java:193)
	at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:52)
	at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:191)
	at org.junit.runners.ParentRunner.access$000(ParentRunner.java:42)
	at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:184)
	at org.junit.runners.ParentRunner.run(ParentRunner.java:236)
	at org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.run(JUnit4TestReference.java:50)
	at org.eclipse.jdt.internal.junit.runner.TestExecution.run(TestExecution.java:38)
	at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:467)
	at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:683)
	at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:390)
	at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main(RemoteTestRunner.java:197)
And the tester is:
package org.xtext.example.mydsl.tests;
import org.eclipse.xtext.junit4.AbstractXtextTests;
import org.eclipse.xtext.junit4.InjectWith;
import org.junit.Test;
import org.xtext.example.mydsl.MyDslInjectorProvider;
import org.xtext.example.mydsl.MyDslStandaloneSetup;
@InjectWith(MyDslInjectorProvider.class)
public class TestXTextBug extends AbstractXtextTests {
    @Test
    public void test() throws Exception {
        with(MyDslStandaloneSetup.class);
        getModel("enum Y; imp X;");
If we remove both ';' in the grammar it works, if we remove only the one in 'enum' it still fails, if we remove the "returns ST" type conversion it still fails. My Xtext version is 2.3.1.v201208210947.
Did I missed something?
Re: org.junit.ComparisonFailure when unittesting my language [message #997613 is a reply to message #997302] Sat, 05 January 2013 07:30 Go to previous messageGo to next message
Damien,
In each case, how is the inferred Ecore model different? Just glancing
at it, I imagine Model has two references and so there's nothing in the
Model instance that would preserve the mixed ordering of IHT and ED so
serialization will put all the things from the first reference before
all the things for the second reference...
> IHT returns ST:
> ED returns ST:
> The error is:
> X;enum Y];>
> at
> at
> at
> at
> at
> at
> at
> at
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:597)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> And the tester is:
> @Test
Re: org.junit.ComparisonFailure when unittesting my language [message #997811 is a reply to message #997613] Tue, 08 January 2013 14:42 Go to previous messageGo to next message
Yep I understand that (and I figure it out myself).
However, I don't think the getModel() function from AbstractXtextTests should fails in any way. So either I do things in the wrong way in the Xtext grammar (in which case IMHO, it should be signalled outside the tests) or there is a bug.
I do that (conversion of IHT/ED to ST) in order to do cross-refs to type definition.
Re: org.junit.ComparisonFailure when unittesting my language [message #998144 is a reply to message #997302] Wed, 09 January 2013 07:42 Go to previous messageGo to next message
If I remember correctly (I stopped using AbstractXtextTests and switched
to the 'new way' of writing Junit tests with Xtend) you can disable the
tests for the serializer (I had similar problems, and I don't remember
whether it was a bug) by redefining a method of AbstractXtextTests
> IHT returns ST:
> ED returns ST:
> The error is:
> X;enum Y];>
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> And the tester is:
> @Test
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Re: org.junit.ComparisonFailure when unittesting my language [message #1020439 is a reply to message #998144] Mon, 18 March 2013 03:09 Go to previous messageGo to next message
can i get the location of xtext.junit jar which contains AbstractXtextTests class..
Re: org.junit.ComparisonFailure when unittesting my language [message #1021172 is a reply to message #1020439] Tue, 19 March 2013 11:47 Go to previous message
I don't understand...
Previous Topic:Xtext scoping with two models
Next Topic:Script editing without the actual editor
Current Time: Mon Jul 21 07:07:00 EDT 2025
Powered by FUDForum. Page generated in 0.04983 seconds
