Home » Newcomers » Newcomers » Problem Unzipping(The unzip failed)
Problem Unzipping [message #901885] Tue, 14 August 2012 17:33 Go to next message
I went to unzip the Eclipse Download and got this message:
Extracting to "C:\Users\Owner\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\RBNRKMO7\eclipse-java-juno-win32-x86_64\"
Use Path: yes Overlay Files: no
Creating directory: "C:\Users\Owner\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\RBNRKMO7\eclipse-java-juno-win32-x86_64\eclipse\".
Extracting eclipse\.eclipseproduct
Extracting eclipse\eclipsec.exe
Creating directory: "C:\Users\Owner\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\RBNRKMO7\eclipse-java-juno-win32-x86_64\eclipse\features\".
Creating directory: "C:\Users\Owner\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\RBNRKMO7\eclipse-java-juno-win32-x86_64\eclipse\features\org.eclipse.wst.common_core.feature_3.4.0.v201107190500-7B7EFMSF7RZHOjIpQz-P-QS\".
Extracting eclipse\features\org.eclipse.wst.common_core.feature_3.4.0.v201107190500-7B7EFMSF7RZHOjIpQz-P-QS\feature.properties
Creating directory: "C:\Users\Owner\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\RBNRKMO7\eclipse-java-juno-win32-x86_64\eclipse\features\org.eclipse.wst.common_core.feature_3.4.0.v201107190500-7B7EFMSF7RZHOjIpQz-P-QS\META-INF\".
Extracting eclipse\features\org.eclipse.wst.common_core.feature_3.4.0.v201107190500-7B7EFMSF7RZHOjIpQz-P-QS\META-INF\ECLIPSE_.SF
Extracting eclipse\features\org.eclipse.wst.common_core.feature_3.4.0.v201107190500-7B7EFMSF7RZHOjIpQz-P-QS\META-INF\ECLIPSE_.RSA
Extracting eclipse\features\org.eclipse.wst.common_core.feature_3.4.0.v201107190500-7B7EFMSF7RZHOjIpQz-P-QS\META-INF\eclipse.inf
Extracting eclipse\features\org.eclipse.wst.common_core.feature_3.4.0.v201107190500-7B7EFMSF7RZHOjIpQz-P-QS\META-INF\MANIFEST.MF
Extracting eclipse\features\org.eclipse.wst.common_core.feature_3.4.0.v201107190500-7B7EFMSF7RZHOjIpQz-P-QS\license.html
Extracting eclipse\features\org.eclipse.wst.common_core.feature_3.4.0.v201107190500-7B7EFMSF7RZHOjIpQz-P-QS\feature.xml
Extracting eclipse\features\org.eclipse.wst.common_core.feature_3.4.0.v201107190500-7B7EFMSF7RZHOjIpQz-P-QS\epl-v10.html
Extracting eclipse\features\org.eclipse.wst.common_core.feature_3.4.0.v201107190500-7B7EFMSF7RZHOjIpQz-P-QS\eclipse_update_120.jpg
Creating directory: "C:\Users\Owner\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\RBNRKMO7\eclipse-java-juno-win32-x86_64\eclipse\features\org.eclipse.recommenders.feature.extdoc.rcp_1.0.0.v20120612-2305-b156\".
Extracting eclipse\features\org.eclipse.recommenders.feature.extdoc.rcp_1.0.0.v20120612-2305-b156\feature.properties
Creating directory: "C:\Users\Owner\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\RBNRKMO7\eclipse-java-juno-win32-x86_64\eclipse\features\org.eclipse.recommenders.feature.extdoc.rcp_1.0.0.v20120612-2305-b156\META-INF\".
Extracting eclipse\features\org.eclipse.recommenders.feature.extdoc.rcp_1.0.0.v20120612-2305-b156\META-INF\ECLIPSE_.SF
Extracting eclipse\features\org.eclipse.recommenders.feature.extdoc.rcp_1.0.0.v20120612-2305-b156\META-INF\ECLIPSE_.RSA
Extracting eclipse\features\org.eclipse.recommenders.feature.extdoc.rcp_1.0.0.v20120612-2305-b156\META-INF\eclipse.inf
Creating directory: "C:\Users\Owner\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\RBNRKMO7\eclipse-java-juno-win32-x86_64\eclipse\features\org.eclipse.recommenders.feature.extdoc.rcp_1.0.0.v20120612-2305-b156\META-INF\maven\".
The path is too long. Unable to extract "C:\Users\Owner\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\RBNRKMO7\eclipse-java-juno-win32-x86_64\eclipse\features\org.eclipse.recommenders.feature.extdoc.rcp_1.0.0.v20120612-2305-b156\META-INF\maven\org.eclipse.recommenders.feature".
Severe Error: Path for extracted file is too long; can't extract.
How can I fix this?
Thanks in advance
Chris Stross
Re: Problem Unzipping [message #901894 is a reply to message #901885] Tue, 14 August 2012 18:09 Go to previous messageGo to next message
> Creating directory:
> [snip]
> How can I fix this?
You might try a different zip program such as 7zip.
Re: Problem Unzipping [message #901909 is a reply to message #901894] Tue, 14 August 2012 21:18 Go to previous messageGo to next message
That worked, thank you Russell
Re: Problem Unzipping [message #901913 is a reply to message #901909] Tue, 14 August 2012 21:46 Go to previous messageGo to next message
I would also suggest you pick a different directory to extract to. You
have placed Eclipse quite deep in your directory structure. You have
also extracted it to you internet temporary folder. This can get
cleared out if you run disk cleanup and completely wipe out your Eclipse
installation.
Re: Problem Unzipping [message #986261 is a reply to message #901885] Mon, 19 November 2012 11:32 Go to previous messageGo to next message
This is a Windows* OS/file system issue.The cause is the directory paths in the system is longer than 255 characters (including spaces).You may see the error "The specified path, file name, or both are too long. The fully qualified file name must be less than 260 characters, and the directory name must be less than 248 characters," under the following circumstances:Opening an assembly with .NET Reflector
Exporting source code for an assembly using an add-in such as FileDisassembler, or FileGeneratorThere's a lot of additional softwares which can fix this problem like Long Path Tool.
PathTooDeep.com
Long Path Tool can simplify and probably end your problems in unlocking, managing and renaming files that appear to have a long filename. Since in some instances, you may have experienced problems accessing, managing and even renaming files that have
more than 255 characters, this utility has been made to answer this particular scenario. If you have also encountered problems like error messages that tell you
that the path too long, too long path, destination path too long or cannot delete file then this program is definitely for you. This will totally take place of
Windows Explorer, Far Manager or other file managing utilities since this is maybe used in any type of Operating System even the earliest Windows 95 version.
Re: Problem Unzipping [message #1003069 is a reply to message #901885] Sun, 20 January 2013 01:52 Go to previous messageGo to next message
I have downloaded Long Path Tool and it helped me a lot
Re: Problem Unzipping [message #1005533 is a reply to message #901885] Sat, 26 January 2013 02:16 Go to previous messageGo to next message
Have you tried using the Long Path Tool? I suggest that you try it, this is the answer to your problem. Check it.
destination path too long [message #1020686 is a reply to message #901885] Mon, 18 March 2013 14:20 Go to previous messageGo to next message
have you tried a software that fix your files? i mean its easy to create and rename files but it depends on how many files needed to be renamed. Ive been using long path tool since then i dont have problem with my files.
Re: destination path too long [message #1021032 is a reply to message #1020686] Tue, 19 March 2013 08:05 Go to previous messageGo to next message
What zip program are you using?
[Updated on: Tue, 19 March 2013 23:27] by Moderator
Long Path Tool [message #1061761 is a reply to message #901885] Mon, 03 June 2013 15:52 Go to previous message
I have download Long Path Tool and it is the best solution of your problem.
Previous Topic:Can I ignore @override in build.xml using Eclipse Compiler?
Next Topic:Backspace
Current Time: Wed Jul 23 17:43:48 EDT 2025
Powered by FUDForum. Page generated in 0.09701 seconds
