Checking ocl syntax [message #1020771] |
Mon, 18 March 2013 18:21  |
I have noticed that the ocl in RSA is different from the ocl in Ecipse. I am not sure how I can write the ocl for example in Papyrus (I know that Papyrus only checks the syntax but not validate them)
where I can findout about the syntax which is accepted in papyrus?
Re: Checking ocl syntax [message #1020993 is a reply to message #1020771] |
Tue, 19 March 2013 06:13  |
RSA uses the classic/Ecore-based Eclipse OCL but tends to be rather out
of date. Use Help->About to find out what plugin versions you actually have.
Papyrus uses the new Pivot-based Eclipse OCL. The integration is of
limited utility in Juno; we're working hard to make Kepler good.
Validation is there but only if you're very clever.
All editors, the XText OCL Console and QVTc/QVTr use the new Xtext/Pivot
OCL. Acceleo, QVTo use the classic OCL.
The major differences between the classic and new approaches are
summarized in http://wiki.eclipse.org/MDT/OCL/Compliance, which I don't
update as often as I should. It just happens that I gave it a bit of a
refresh yesterday.
The steady improvements in the pivot-based approach left the classic
approach a bit behind, and so in Indigo there were some irritating
inconsistencies. In Juno, we tried to rectify as many of these as
possible, but some problems in the classic approach are too hard to fix,
so some differences such as "1 = 1.0" remain.
Ed Willink
On 18/03/2013 22:21, Jeni Martin wrote:
> Thanks
FUDForum. Page generated in 0.03439 seconds
