Attaching keywords to variables within Xbase expressions [message #1018767] |
Thu, 14 March 2013 08:42  |
Hi all,
I would like to attach (optional) keywords to variables within Xbase expressions.
For example, the following syntax should be supported:
special x > 3 && special y < 6
I am looking for a simple way to achieve that goal. Any help is appreciated.
Oren
Re: Attaching keywords to variables within Xbase expressions [message #1021352 is a reply to message #1020925] |
Tue, 19 March 2013 18:57  |
I think you'll have to extend XEqualityExpression in a subclass that
includes the boolean special field, and then use a parser action to
indicate that it should create an instance of that subclass:
XEqualityExpression returns XExpression:
{MyXEqualitySubclass} (special ?= 'special')? XRelationalExpression
(=>({XBinaryOperation.leftOperand=current}
feature=[types::JvmIdentifiableElement|OpEquality])
rightOperand=XRelationalExpression)*;
Hallvard
On 19.03.13 00.40, Oren Mishali wrote:
> Thanks Sebastian,
> I've tried the approach you have suggested. I've extended
> XEqualityExpression as follows (note the addition of the new 'special'
> keyword):
> 'special' ? XRelationalExpression
> This change indeed allows to write Xbase expressions such as:
> (special x == 3)
> Next, I've tried to add a new variable in order to know whether the new
> 'special' keyword was added:
> Unfortunately, I get the following two errors:
> Cannot find compatible feature special in sealed EClass XExpression from
> imported package http://www.eclipse.org/xtext/xbase/Xbase: The type
> 'XExpression' does not have a feature 'special'.
> An unassigned rule call is not allowed, when the 'current' was already
> created.
> Oren
FUDForum. Page generated in 0.04205 seconds
