Home » Modeling » Epsilon » EGL(EGL runing)
EGL [message #1020607] Mon, 18 March 2013 10:57 Go to next message
Hi all,
I want to code generation from gmf. But i dont know how can i use .egl file with .ewl file.
I just want to run my .egl from wizard commands.
So how can i done this ? there is a sample project or ducumantation ?
Re: EGL [message #1020772 is a reply to message #1020607] Mon, 18 March 2013 18:22 Go to previous message
Hi Serhat,
This is not supported out-of-the-box in EWL but it shouldn't be that hard to do. You'd need to implement a new Java tool [1] that you can call from your EWL wizard and which should in turn call EGL programmatically (see [2], [3] for examples of calling EGL from Java).
Dimitris
[1] http://eclipse.org/epsilon/doc/articles/call-java-from-epsilon/
[2] http://eclipse.org/epsilon/examples/index.php?example=org.eclipse.epsilon.examples.standalone
[3] https://code.google.com/p/pongo/source/browse/trunk/com.googlecode.pongo/src/com/googlecode/pongo/PongoGenerator.java
Previous Topic:EVL integration with EWL
Next Topic:EOL
Current Time: Sun Jul 27 01:55:44 EDT 2025
Powered by FUDForum. Page generated in 0.30029 seconds
