[Xtend2] [message #1016354] |
Wed, 06 March 2013 02:47  |
Hi there,
I'm struggling a bit with lambda expressions, see
http://www.eclipse.org/xtend/documentation.html#lambdas
I understand that a lambda expression is an anonymous function that I
can pass as argument to methods that accept functions.
However, the examples there use standard Java methods, like
addActionListener that take an object as argument, i.e. an Object of
type ActionListener. This is usually implemented as anonymous Object
implementing the only method actionPerformed.
In the Xtend-pendant there is only a closure that implements the
behavior of the actionPerformed method. However, it is not named nor is
there any object wrapping the function like the required ActionListener.
So how are the rules that Xtend infers all these required informations?
Where are the limits? Is this only possible for anonymous classes with
exactly one method?
My own example is the FileVisitor of Java 7:
http://docs.oracle.com/javase/7/docs/api/java/nio/file/FileVisitor.html
(see below)
Is it possible to implement the pattern in the first example there with
lambda expressions? How is the SimpleFileVisitor replaced?
Something like
Files::walkFileTree(path, [Path file, BasicFileAttributes attrs|
println(file)])
Hauke
File Visitor pattern in Java:
Path start = ...
Files.walkFileTree(start, new SimpleFileVisitor<Path>() {
public FileVisitResult visitFile(Path file,
BasicFileAttributes attrs)
throws IOException
Files.delete(file);
return FileVisitResult.CONTINUE;
public FileVisitResult postVisitDirectory(Path dir,
IOException e)
throws IOException
if (e == null) {
Files.delete(dir);
} else {
// directory iteration failed
throw e;
Re: [Xtend2] [message #1020582 is a reply to message #1016354] |
Mon, 18 March 2013 09:54  |
Java uses interfaces with a single method where other languages use
lambda expressions. This is why Xtend will coerce a lambda to an
interface (or class in Xtend 2.4) with a single abstract method if
needed. The methods from java.lang.Object don't count (that's why
Comparable<T> can be implemented with a lambda)
FileVisitor and SimpleFileVisitor wouldn't work, as they have 4/0
abstract methods.
Am 06.03.13 08:47, schrieb Hauke Fuhrmann:
> Hi there,
> exactly one method?
> (see below)
> Something like
> println(file)])
> Cheers,
> Hauke
> Path start = ...
> @Override
> throws IOException
> Files.delete(file);
> @Override
> IOException e)
> throws IOException
> if (e == null) {
> Files.delete(dir);
> } else {
> throw e;
FUDForum. Page generated in 0.03427 seconds
