Home » Modeling » EMF » How to control default javadoc creation..(Switching off default Javadoc content..)
How to control default javadoc creation.. [message #1020214] Sun, 17 March 2013 11:29 Go to next message
The default EMF javadoc has contents which reads like "If the meaning of the ... attribute isn't clear,there really should be more of a description here.".
This is between <beging-user-doc> and <end-user-doc>.
Is there a way to switch off this content globally for all its instances. I am generating the ECore model from a BIG XSD file and thus want an easy option to switch it off globally.
Re: How to control default javadoc creation.. [message #1020227 is a reply to message #1020214] Sun, 17 March 2013 12:27 Go to previous messageGo to next message
Kapil,
No, there's no option to switch it off. If the feature has an
EAnnotation with source "http://www.eclipse.org/emf/2002/GenModel" and
key "documentation" the value of that key will be emitted instead. If
the XSD contained documentation element, that would be automatically
converted to corresponding Ecore annotations.
> description here.".
Re: How to control default javadoc creation.. [message #1020241 is a reply to message #1020227] Sun, 17 March 2013 13:30 Go to previous messageGo to next message
Ed, appreciate a prompt response.
Yes i tried the approach that u mentioned and this way the custom doc content (i.e. value of key "documentation"), mentioned in the ecore is generated inside <!-- begin-model-doc --> ..<!-- end-model-doc --> and the earlier one is not emitted.
The challenge i have is that the number of these instances is quite high (and thus not efficient to be done manually).
I guess the intent of this default value is to ensure owners provide something meaningful, but am wondering if its a good idea to provide a ecore directive to switch it off, which is also an indication that the owner of the model owns what comes out.
As a side note, if i want to hide the documentation for certain elements or attributes, would the ecore:ignore of the xsd:documentation help.
Re: How to control default javadoc creation.. [message #1020413 is a reply to message #1020241] Mon, 18 March 2013 01:38 Go to previous messageGo to next message
Kapil,
Comments below.
Exactly.
No, though it's only a few lines of code to read and Ecore resource, and
use Resource.getAllContents to visit each EStructuralFeature and use
EcoreUtil.setDocumentation("").
Yes.
I suppose so. Yet more options...
Yes or on the xsd:annotation itself.
Re: How to control default javadoc creation.. [message #1020568 is a reply to message #1020413] Mon, 18 March 2013 09:32 Go to previous messageGo to next message
Hi, Ed, Kapil,
Is this bit of the Javadoc overrideable in custom templates? If not,
factoring it out into a *.javajetinc could be a lighter-weight solution
than adding an option to the GenModel.
cW
On 2013-03-18 05:38:10 +0000, Ed Merks said:
> Kapil,
> Comments below.
> Exactly.
> and use Resource.getAllContents to visit each EStructuralFeature and
> use EcoreUtil.setDocumentation("").
> Yes.
>> help.
Re: How to control default javadoc creation.. [message #1020571 is a reply to message #1020568] Mon, 18 March 2013 09:39 Go to previous message
Christian,
There's only //Class/getGenFeature.javadoc.override.javajetinc that
affects the entire Javadoc comment, not just this part.
On 18/03/2013 2:32 PM, Christian W. Damus wrote:
> Hi, Ed, Kapil,
> solution than adding an option to the GenModel.
> cW
>> Kapil,
>> Comments below.
>> Exactly.
>> Yes.
Previous Topic:[Teneo] Table name conflict with imported package
Next Topic:[XCore/Xbase] Filtering
Current Time: Sat Nov 08 23:58:28 EST 2025
Powered by FUDForum. Page generated in 0.05034 seconds
