Running an e4 RCP application multiple times [message #1020567] |
Mon, 18 March 2013 09:33  |
we have an e4 RCP application which our customers would like to launch multiple times,
so they can compare data.
This doesn't work though, the 2nd instance stops launching with the Error-Message
"Workspace Cannot Be locked", detail-message contains 'workspace is currently in use'.
e3 RCP apps allowed this.
Can I somehow persuade e4 to also allow it?
I tried with '-data @none' but this caueses an NPE in
org.eclipse.e4.ui.internal.workbench.ResourceHandler.loadMostRecentModel(ResourceHandler.java:127)
I also tried with '-data @noDefault' and then setting the workspace myself as unlocked like this
Location instanceLoc = Platform.getInstanceLocation();
try {
// set location to c:\temp
instanceLoc.set(new URL("file", null, "c:\\temp\\ws"), false);
// workspace unlocked here
catch (IOException e) {
throw new Error(e);
but in the class 'E4Application' this workspace is being locked:
// at this point its valid, so try to lock it and update the
// metadata version information if successful
try {
if (instanceLocation.lock()) {
writeWorkspaceVersion();
return true;
// ms: else show error-message "Workspace Cannot Be locked" ...
So do I have any other options for this use-case except creating a workspace on the fly for each running instance of the application?
Manuel
Re: Running an e4 RCP application multiple times [message #1020579 is a reply to message #1020567] |
Mon, 18 March 2013 09:52   |
Could you file a bugzilla for this. I think we should add a config
option to allow multiple starts.
Tom
Am 18.03.13 14:33, schrieb manuel.steurer@xxxxxxxx:
> multiple times,
> Error-Message
> currently in use'.
> try {
> throw new Error(e);
> try {
> return true;
> Manuel
Re: Running an e4 RCP application multiple times [message #1020594 is a reply to message #1020579] |
Mon, 18 March 2013 10:25  |
done:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=403642
Thanks for the quick reply.
Manuel
On Mon, 18 Mar 2013 14:52:23 +0100, Tom Schindl <tom.schindl@xxxxxxxx> wrote:
> Tom
>> Hi,
>> multiple times,
>> Error-Message
>> currently in use'.
>> try {
>> throw new Error(e);
>> try {
>> return true;
>> Thanks,
>> Manuel
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
FUDForum. Page generated in 0.05262 seconds
