Home » Archived » Visual Editor (VE) » One issue
One issue [message #101356] Fri, 05 August 2005 09:39 Go to next message
Originally posted by: abel.castify.net
One I issue I've found f:
I've got two projects in my eclipse workspace (both opened)
-1 very large project with no visual class
-1 very small project with my visual class (for prototyping)
When I launch eclipse, it seems that VE scans or do somthing with the
large project. In the progress window I've got a task "Setup Visual
Editor" wichh never stops, and I cannot cancel it...All I can do is
disabled VE, then kill eclipse, then relaunch eclipse, close the large
project, enable VE, restart eclipse (ouf!)
Pierre
Re: One issue [message #101401 is a reply to message #101356] Fri, 05 August 2005 20:43 Go to previous messageGo to next message
Hi Pierre,
Is the large project on the classpath of the small project? It could be
that VE is bulding beaninfo for the large project as well.
Sri.
Pierre Abel wrote:
> Pierre
Re: One issue [message #101494 is a reply to message #101356] Mon, 08 August 2005 10:55 Go to previous messageGo to next message
Pierre Abel wrote:
Did you close Eclipse with a visual class opened? (Eclipse will try to
open them up when it is restarted). VE plugins
should not start just because the project is opened.
If you click ont the progress, it should give you some more information of what
the Setup job is doing.
... try to clear all of VE's caches by open a VE editor (to start the VE plugins),
and than do a project clean.
> Pierre
Re: One issue [message #101973 is a reply to message #101494] Thu, 11 August 2005 10:02 Go to previous message
Sorry for the late answer (holidays...)
> be that VE is bulding beaninfo for the large project as well.
no
yes
> information of what
yes, a task "Setup Visual Editor" is displayed, but it doesn't move...
> VE plugins),
thanks I will try next time I have this situation
Note: there are *no* problems if I open the large project after while I
working on the small project that use VE, it's only when I restart eclipse.
Pierre
Re: One issue [message #610157 is a reply to message #101356] Fri, 05 August 2005 20:43 Go to previous message
Hi Pierre,
Sri.
Pierre Abel wrote:
> Pierre
Re: One issue [message #610171 is a reply to message #101356] Mon, 08 August 2005 10:55 Go to previous message
Pierre Abel wrote:
> Pierre
Re: One issue [message #610243 is a reply to message #101494] Thu, 11 August 2005 10:02 Go to previous message
no
yes
> information of what
> VE plugins),
Pierre
Previous Topic:VE Screen scraping
Next Topic:Table
Current Time: Tue Nov 04 21:24:32 EST 2025
Powered by FUDForum. Page generated in 0.03998 seconds
