Home » Modeling » Epsilon » GMF Palette Divison
GMF Palette Divison [message #1018891] Thu, 14 March 2013 12:19 Go to next message
Hi all,
i want to palette division with .eol. But i dont know how can i do this. I search for
examples but can't find. So someone can help me for this ?
var toolGroupObjects = GmfTool!ToolGroup.all.selectOne(r|r.title = 'Objects');
toolGroupObjects.title='Nodes';
var newToolGroup = new GmfTool!ToolGroup;
newToolGroup.title='Fields';
toolGroupObjects.tools.add(newToolGroup);
i tried this code but not work Sad And how can i add image to palette with .eol ?
[Updated on: Thu, 14 March 2013 13:25] by Moderator
Re: GMF Palette Divison [message #1019024 is a reply to message #1018891] Thu, 14 March 2013 18:43 Go to previous messageGo to next message
Hi serhat,
Could you please elaborate on how it does not work? Does it produce an error, or does it not produce the results you expected?
Re: GMF Palette Divison [message #1019038 is a reply to message #1019024] Thu, 14 March 2013 19:25 Go to previous messageGo to next message
i get;
"The opposite features 'palette' of 'Tool Group Fields' and 'groups' of 'Palette contentmodel.diagram.part' do not refer to each other"
error.
and my code is;
var booleanField = getGroupObject('Boolean');
newToolGroup.tools.add(booleanField);
operation getGroupObject(title : String) : GmfTool!AbstractTool {
	return GmfTool!AbstractTool.all.selectOne(t|t.title=title);
[Updated on: Thu, 14 March 2013 19:26] by Moderator
Re: GMF Palette Divison [message #1019255 is a reply to message #1019038] Fri, 15 March 2013 06:22 Go to previous messageGo to next message
That's probably a validation error from GMF. It's basically saying that you forgot to assign your new tool group to the palette.
[Updated on: Fri, 15 March 2013 06:22] by Moderator
Re: GMF Palette Divison [message #1019348 is a reply to message #1019255] Fri, 15 March 2013 09:57 Go to previous messageGo to next message
But 'toolGroupObjects' already binded to pallette and i want to create
sub tool group to 'toolGroupObjects'. Why i get this error dont understand Sad
Re: GMF Palette Divison [message #1019469 is a reply to message #1019348] Fri, 15 March 2013 14:58 Go to previous message
Sorry, but I can't see where in your code newToolGroup is bound to any palette:
I would advise you to first modify the GMFTool model manually, and when you're sure of all the changes involved, automate them using EOL. It's usually better this way, since if you run into any issues with the manually changed model you will be able to get better help from the GMF experts at the GMF forum Smile.
Previous Topic:EWL UserPrompt
Next Topic:EVL integration with EWL
Current Time: Wed Jul 23 07:48:56 EDT 2025
Powered by FUDForum. Page generated in 0.45298 seconds
