Home » Modeling » EMF » [CDO] Derby - Table/View 'CDO_PROPERTIES' does not exist
[CDO] Derby - Table/View 'CDO_PROPERTIES' does not exist [message #1019058] Thu, 14 March 2013 20:40 Go to next message
I used MySQL for my CDO repositories before. Everything worked well. However, I want to test Derby now. I changed my server code as follows:
EmbeddedDataSource dataSource = new EmbeddedDataSource();
dataSource.setDatabaseName(connectionData.getDbName());
dataSource.setCreateDatabase("create");
IStore store = CDODBUtil.createStore(
				CDODBUtil.createHorizontalMappingStrategy(true),
				new EmbeddedDerbyAdapter(),
				DBUtil.createConnectionProvider(dataSource));
repository = CDOServerUtil.createRepository(
		connectionData.getRepositoryName(), store,
		new HashMap<String, String>());
CDOServerUtil.addRepository(IPluginContainer.INSTANCE, repository);
When the repository is added, CDO/Net4j reports the following exception:
java.sql.SQLSyntaxErrorException: Table/View 'CDO_PROPERTIES' does not exist.
The DB has been created. When I check the DB, I cannot find any table inside. Did I miss something very important? As I said, using the MySQL Adapter the code above was sufficient and everything worked.
I use
CDO Model Repository SDK	 4.2.0.v20130312-0827
Net4j DB Framework Derby Adapter 4.2.0.v20130116-0901  (however, the filename states org.eclipse.net4j.db.derby_4.1.0.v20130116-0901.jar)
I should also reference this topic, which reports the same problem. However, I cannot find a solution there (except using H2):
http://www.eclipse.org/forums/index.php/mv/msg/451546/
Thanks in advance!
Re: [CDO] Derby - Table/View 'CDO_PROPERTIES' does not exist [message #1019145 is a reply to message #1019058] Fri, 15 March 2013 01:45 Go to previous messageGo to next message
Am 15.03.2013 01:40, schrieb Kirsten M. Z.:
I normally recommend to try out H2 instead because it's slimmer and much faster. And it's the DB we test each build with.
That all looks ok.
I suspect that something in your model is not supported by EmbeddedDerbyAdapter. Is there additional trace info in the
log? In standalone mode you can call this to enable logging and tracing:
// Enable logging and tracing
OMPlatform.INSTANCE.setDebugging(true);
OMPlatform.INSTANCE.addLogHandler(PrintLogHandler.CONSOLE);
OMPlatform.INSTANCE.addTraceHandler(PrintTraceHandler.CONSOLE);
Just this week I've finished a major rehaul of the Net4j DB framework and CDO's DBStore to make the schema handling more
stable and flexible:
[401763] Make CDO Server more robust against data dictionary changes
https://bugs.eclipse.org/bugs/show_bug.cgi?id=401763
You may want to try out the newest I-build to test it.
> I use
Okay, that's the newest I-build.
That's okay. The build qualifier is made of the timestamp of the latest modification in the plugin, i.e., it doesn't
change with each build unless there's actual change.
> using H2):
Yes, that sounds similar. But I need to see the exception that's traced in org.eclipse.net4j.spi.db.DBAdapter:
public boolean createTable(IDBTable table, Statement statement) throws DBException
boolean created = true;
try
doCreateTable(table, statement);
catch (SQLException ex)
created = false;
if (TRACER.isEnabled())
TRACER.trace("-- " + ex.getMessage()); //$NON-NLS-1$
validateTable(table, statement);
return created;
Cheers
/Eike
http://www.esc-net.de
Re: [CDO] Derby - Table/View 'CDO_PROPERTIES' does not exist [message #1019222 is a reply to message #1019145] Fri, 15 March 2013 05:09 Go to previous messageGo to next message
I added the code for enabling debug tracing, but cannot see any change in the output.
I also set a breakpoint in the methode you mentioned:
The method is not called, so there is also no error.
Re: [CDO] Derby - Table/View 'CDO_PROPERTIES' does not exist [message #1019239 is a reply to message #1019145] Fri, 15 March 2013 05:46 Go to previous messageGo to next message
I tested H2 as you said now. I haven't known that H2 is also a Java DB engine. Works fine and also has all required features.
So I guess... Derby support is simply broken right now. However, H2 is a nice alternative, at least for me.
Thanks Eike!
Re: [CDO] Derby - Table/View 'CDO_PROPERTIES' does not exist [message #1019292 is a reply to message #1019239] Fri, 15 March 2013 07:39 Go to previous messageGo to next message
Am 15.03.2013 10:46, schrieb Kirsten M. Z.:
> features.
Great to hear that ;-)
Cheers
/Eike
Re: [CDO] Derby - Table/View 'CDO_PROPERTIES' does not exist [message #1019328 is a reply to message #1019222] Fri, 15 March 2013 09:03 Go to previous message
> in the output.
http://wiki.eclipse.org/FAQ_for_CDO_and_Net4j#How_can_I_enable_tracing.3F
> DBException
Previous Topic:Command on Tree Editor
Next Topic:How to manage mixed XSD/XML resource?
Current Time: Thu Jul 24 23:31:21 EDT 2025
Powered by FUDForum. Page generated in 0.27876 seconds
