Home » Eclipse Projects » GEF » Export as Image Action - Not enabled at StartUp
Export as Image Action - Not enabled at StartUp [message #1016274] Tue, 05 March 2013 14:03 Go to next message
I've got another problem this time Smile
I implemented a "Export as Image" Action.
The code is as follows:
public class ExportAsImageAction extends EditorPartAction {
   * Id of this action
  public static final String EXPORT_AS_IMAGE_ID = "export as image";
  private static final String DESCRIPTION = "Export as image";
   * Constructor
   * @param editor
  public ExportAsImageAction(IEditorPart editor) {
    super(editor);
    setDescription(DESCRIPTION);
    setImageDescriptor(ImageDescriptor.createFromImage(IconProvider.loadImage(IconProvider.EXPORT_ICON)));
    setText("Export");
  protected void init() {
    super.init();
    setId(EXPORT_AS_IMAGE_ID);
  public void run() {
    ImageSaveUtil.save(getEditorPart());
  protected boolean calculateEnabled() {
    return getEditorPart() != null;
  public void setEditorPart(IEditorPart part) {
    super.setEditorPart(part);
and in my ActionBarContributor I do the following:
 private ExportAsImageAction exportAction;
  protected void buildActions() {
    exportAction = new ExportAsImageAction(null);
    addAction(exportAction);
  public void setActiveEditor(IEditorPart editor) {
    // override this so that the exportAction instance can track the
    // current editor
    super.setActiveEditor(editor);
    exportAction.setEditorPart(editor);
Unfortunately, the action is not enabled when I open my editor.
After I click on another Eclipse View or anything, and then click back to my
editor, the action is enabled.
Apparently, the IEditorPart is not set at startup and I cannot figure out
how to do it. I tried to pass "getPage().getActiveEditor()" instead of null
like this, but it did not help either
    exportAction = new ExportAsImageAction(getPage().getActiveEditor());
Is there anything I can do about that?
Is this in general the right way to register this action?
Thanks in advance,
Tim
[Updated on: Tue, 05 March 2013 14:04] by Moderator
Re: Export as Image Action - Not enabled at StartUp [message #1016382 is a reply to message #1016274] Wed, 06 March 2013 05:14 Go to previous messageGo to next message
This "action based" approach is deprecated from my point of view. You should implement that using the command framework.
Re: Export as Image Action - Not enabled at StartUp [message #1016385 is a reply to message #1016382] Wed, 06 March 2013 05:17 Go to previous messageGo to next message
Thanks for your answer...
I'll try to use the command framework.
Is there any tutorial or implementation available, by any chance?
Where I could see how to achieve this?
Tim
Re: Export as Image Action - Not enabled at StartUp [message #1016387 is a reply to message #1016385] Wed, 06 March 2013 05:20 Go to previous messageGo to next message
Re: Export as Image Action - Not enabled at StartUp [message #1016390 is a reply to message #1016387] Wed, 06 March 2013 05:24 Go to previous messageGo to next message
Thanks a lot, I'll read it...
Re: Export as Image Action - Not enabled at StartUp [message #1017115 is a reply to message #1016390] Sat, 09 March 2013 08:43 Go to previous messageGo to next message
Sooo I've read through it and it looks promising.
But there is still one thing, I don't know how to achieve.
My Editor has a ActionBarContributor, which is only visible
if my editor is open.
If I understood it correctly, I can make my Command-Menu-Contribution
do the same via Eclipse Core Expressions.
But is there a way to put the command into my menu, contributed
by the ActionBarContributor?
So whenever somebody moves the redo/undo arrows and zooming option,
which are currently provided by the ActionBarContribution,
the command is also moved?
Thanks in advance,
Tim
[Updated on: Sun, 10 March 2013 06:59] by Moderator
Re: Export as Image Action - Not enabled at StartUp [message #1018807 is a reply to message #1017115] Thu, 14 March 2013 10:01 Go to previous messageGo to next message
Does nobody have an idea?
Or at least does know, that it is not possible in the way I'd like to have it?
Anything?
Re: Export as Image Action - Not enabled at StartUp [message #1022659 is a reply to message #1018807] Fri, 22 March 2013 05:55 Go to previous messageGo to next message
I've never need that. But I would like to know if it's possible as well. I've posted questions for this topic here and here.
Meanwhile you have to put the command in its own toolbar.
Re: Export as Image Action - Not enabled at StartUp [message #1088043 is a reply to message #1016274] Fri, 16 August 2013 09:47 Go to previous message
Hi Jan,
I have the same problem porting my GEF action based commands to Kepler.
All that worked so well on eclipse 3 now just does not work anymore - and I don´t even know where should I start to make that thing work again! (and it is not listed on "what is new about GEF" either...just another "surprise feature").
Does ActionBarContributor can work together with this "new" Command interface?
Or should I just forget about GEF integration completely?
If actions are deprecated, why GEF uses actions?
Thanks for this topic, is the only one I found in the subject.
Previous Topic:Figure cant shown in Diagram
Next Topic:Installation issues [Resolved]
Current Time: Sat Jul 26 23:23:19 EDT 2025
Powered by FUDForum. Page generated in 0.30368 seconds
