Home » Eclipse Projects » Remote Application Platform (RAP) » RAP Tree - moveable columns not working(setMoveable(true) for Tree columns doesn't work)
| RAP Tree - moveable columns not working [message #1018755] |
Thu, 14 March 2013 08:21  |
Before I open a bug, could someone confirm if this is indeed a bug, or working as designed in RAP... basically I have a Tree which has setMoveable(true) for all columns, but if I try to actually drag the columns around to change their order, the 'ghost' of the column header gets left on the display and no re-ordering is done.
Same code works ok in SWT.
Just to note, I'm using quite a recent Nightly of RAP from a few days ago.
Snippet:
/* DEMONSTRATES RAP ISSUE WITH COLUMN MOVE IN RAP */
package bug.snippet;
import org.eclipse.swt.SWT;
import org.eclipse.swt.graphics.Color;
import org.eclipse.swt.graphics.RGB;
import org.eclipse.swt.layout.FormAttachment;
import org.eclipse.swt.layout.FormData;
import org.eclipse.swt.layout.FormLayout;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.Tree;
import org.eclipse.swt.widgets.TreeColumn;
import org.eclipse.swt.widgets.TreeItem;
public class Bugsy {
private Display display;
private Shell shell;
private Tree tree;
public void begin() {
System.out.println("BugSnippy Starting...");
// create Shell
display = new Display();
shell = new Shell(display, SWT.TITLE|SWT.BORDER|SWT.CLOSE);
shell.setText("Bug Snippet");
shell.setBackground(new Color(null, new RGB(192,192,192)));
FormLayout layout = new FormLayout();
layout.marginWidth = 0;
layout.marginHeight = 0;
layout.marginLeft = 10;
layout.marginTop = 10;
layout.marginRight = 10;
layout.marginBottom = 10;
layout.spacing = 0;
shell.setLayout(layout);
// create the Tree
tree = new Tree(shell, SWT.MULTI|SWT.FULL_SELECTION);
tree.setHeaderVisible(true);
tree.setLinesVisible(true);
FormData fd = new FormData();
fd.left = new FormAttachment(0, 10);
fd.top = new FormAttachment(0, 10);
fd.width = 800;
fd.height = 600;
tree.setLayoutData(fd);
// create the columns
for (int j = 0; j < 10; j++) {
TreeColumn tc = new TreeColumn(tree, SWT.NONE);
tc.setMoveable(true);
tc.setResizable(true);
tc.setText("Col"+j);
tc.setWidth(100+j*5);
// populate some data
for (int i = 0; i < 100; i++) {
TreeItem it = new TreeItem(tree, SWT.NONE);
String[] data = new String[10];
data[j] = "Row"+i+" Col"+j;
it.setText(data);
shell.layout();
shell.open();
//SWT ONLY: while (!shell.isDisposed()) {
//SWT ONLY: if (!display.readAndDispatch())
//SWT ONLY: display.sleep();
//SWT ONLY: }
//SWT ONLY: display.dispose();
System.out.println("BugSnippy Done!");
Thanks, John
| Re: RAP Tree - moveable columns not working [message #1018826 is a reply to message #1018755] |
Thu, 14 March 2013 10:39   |
Hi.
Your snippet works fine for me in FF, IE and Chrome. What browser/OS are
you using? Can you give a screenshot?
Greetings,
Tim
Am 14.03.2013 13:21, schrieb John Gymer:
> Snippet:
> import org.eclipse.swt.widgets.Display;
> private Tree tree;
> // create Shell
> layout.spacing = 0;
> // create the Tree
> fd.width = 800;
> fd.height = 600;
> it.setText(data);
> shell.layout();
> shell.open();
> //SWT ONLY: }
> Thanks, John
Tim Buschtöns
Twitter: @EclipseRAP
| Re: RAP Tree - moveable columns not working [message #1019366 is a reply to message #1018906] |
Fri, 15 March 2013 10:49  |
Yeah, well, it happens a lot around here, but we have not yet found a
way to warn the user when this happens. Just use AbstractEntryPoint all
the time, then it should always work.
Am 14.03.2013 18:05, schrieb John Gymer:
> STUPID ME! 8o Sorry Tim, you are absolutely correct... I add and remove
> that main loop constantly in my BugSnippet code as I'm constantly trying
> things out in SWT, RAP and Tabris! Just forgot to do it on this occasion!
> Totally my fault... adding the loop back in sorts it out!
> RED FACE :blush: John
Tim Buschtöns
Current Time: Sun Nov 09 09:53:42 EST 2025
Powered by FUDForum. Page generated in 0.04410 seconds
