Remote System Explorer bug? [message #1018638] |
Thu, 14 March 2013 04:41  |
Hi all
Before start, i apologize for my broken English
i try to use eclipse remote system explorer(in windows 7) connect to my windows XP laptop, it work, can edit file and do anything, but after i disconnect and close the daemon. i cannot open any Folder and the "My Computer" in the windows XP.Can i know what is the reason cause this??
i use System Restore, restore my windows XP back to the day before eclipse connect, then windows XP back to normal,
Re: Remote System Explorer bug? [message #1019034 is a reply to message #1018638] |
Thu, 14 March 2013 19:10   |
I'm not sure what would cause that. I don't normally work on windows this
way but, when I tried, I couldn't reproduce this. What level of RSE were
you using?
"CHEE FEI TONG" <forums-noreply@xxxxxxxx> wrote in message
news:khsi4d$p8a$1@xxxxxxxxe.org...
> Hi all
Re: Remote System Explorer bug? [message #1019356 is a reply to message #1019061] |
Fri, 15 March 2013 10:18   |
Hi Zachary,
1) I wouldn't expect this in any scenario. Since we test on unix systems,
I'd expect HP-UX to be in better shape. I'm assume you're using dstore for
the windows tests - note there are also other ways to connect to unix, like
via SSH or FTP.
2) If you're using dstore, then you have to put the server jars and scripts
on the host machine. If you have admin access, then you can start the RSE
dstore daemon (i.e. daemon.pl). If not, then you may have to either connect
manually (by starting server.sh and connecting to the appropriate port) or
by using the REXEC option of starting the server. If you're not using SSH,
then you can connect via whatever SSH daemon is running and it's a similar
story for FTP.
news:khtr76$ah7$1@xxxxxxxxe.org...
> Hi David,
> thx for your reply.i using Eclipse Juno , Remote System Explorer End-User
> Runtime version 3.4.1.201302122026
> Can i ask you 2 question?
> 1)i am doing student project,i connect to windows XP is just a testing
> before i connect HP-UX server.
> Is it connect to HP-UX server will have same problem??
> 2)Can you teach me how to connect to HP-UX ? eclipse (windows 7) and HP-UX
> server need do any setting or install/run anything?
> Regards
> Zachary Tong
FUDForum. Page generated in 0.03360 seconds
