Home » Modeling » OCL » asOrderedSet() flattening too much?
asOrderedSet() flattening too much? [message #1018337] Wed, 13 March 2013 12:26 Go to next message
I have the following method [*] in a completeOCL document
context Container
def : crossProduct(toAppend : OrderedSet(Integer), currentSet : OrderedSet(OrderedSet(Integer))) : OrderedSet(OrderedSet(Integer)) =
	toAppend->iterate( c : Integer; paths : OrderedSet(OrderedSet(Integer)) = currentSet |
		 let origSet : OrderedSet(OrderedSet(Integer)) = currentSet in (paths->collect( s : OrderedSet(Integer) | s->append(c) ))->asOrderedSet()->union(origSet)->asOrderedSet()
However, the parser yields an error on the union operation
Unresolved Operation 'OrderedSet(Integer)::union(OrderedSet(OrderedSet(Integer)))'
So it looks like the (first) asOrderedSet() operation is flattening the Sequence(OrderedSet(Integer) (ie. the result of the collect() operation) into an OrderedSet(Integer), instead of "just removing" the duplicate elements and returning an OrderedSet(OrderedSet(Integer)).
Is this a bug, or is something wrong with my expression anyway?
TIA
Klaas
[*] Its goal is to create "crossProducts", ie.
crossProduct( {5, 6} , { {1, 2} {3, 4} }) should return { {1 , 2, 5}, {3, 4, 5}, {1, 2, 6}, {3, 4, 6} }.
Also as a side note: in reality, the operation is not meant to be executed on Integers (ie. I don't have the risk of duplicates)
Re: asOrderedSet() flattening too much? [message #1019004 is a reply to message #1018337] Thu, 14 March 2013 17:58 Go to previous messageGo to next message
In my development workspace, I get a strange dangling reference message
on the "s", but when I hover over the -> of paths->collect I can see the
specialization
IteratorExp *OrderedSet(OrderedSet(Integer))::collect(s :
OrderedSet(Integer) | OrderedSet(Integer)) : Sequence(Integer)*
which is correct. collect was specified in the early days of OCL when
there were no nested collections; it flattens. You need collectNested.
Ed Willink
On 13/03/2013 16:26, Klaas Gadeyne wrote:
> context Container
> OrderedSet(OrderedSet(Integer)) = currentSet | let origSet :
> TIA
> Klaas
Re: asOrderedSet() flattening too much? [message #1019323 is a reply to message #1019004] Fri, 15 March 2013 08:52 Go to previous message
Ed Willink wrote on Thu, 14 March 2013 17:58
specialization
Should have looked more thoroughly at the spec Embarrassed !
thx!
k
Previous Topic:Operation with Set(Real) as arguments is not recognized, Is this a bug?
Next Topic:Checking ocl syntax
Current Time: Sun Nov 02 11:02:18 EST 2025
Powered by FUDForum. Page generated in 0.56077 seconds
