Home » Archived » BIRT » Export Birt report in Excel(Export Birt report in Excel)
Export Birt report in Excel [message #649278] |
Tue, 18 January 2011 09:43  |
I need your help with one the reports that i have. It has got many columns, about 21. When I export it to excel it merges some of the columns. How do i fix this problem in birt.
Re: Export Birt report in Excel [message #649505 is a reply to message #649278] |
Wed, 19 January 2011 09:02   |
This is it. Please help
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.17" id="1">
<property name="createdBy">Eclipse BIRT Designer Version 2.3.2.r232_20090202 Build <2.3.2.v20090218-0730></property>
<property name="units">in</property>
<property name="comments">IBM Confidential
OCO Source Materials
5724-M19
(C) COPYRIGHT IBM CORP. 2006
The source code for this program is not published or otherwise
divested of its trade secrets, irrespective of what has been
deposited with the U.S. Copyright Office.</property>
<html-property name="description">This template will create a report having a single header with multiple rows of data.</html-property>
<method name="initialize">< ![CDATA[importPackage(Packages.com.ibm.tivoli.maximo.report. script);
mxReportScriptContext = MXReportScriptContext.initialize(reportContext);]]></method >
<method name="afterFactory"><![CDATA[MXReportScriptContext.close();]] ></method>
<property name="theme">MaximoSystemLibrary.maximoTheme</property>
<text-property name="displayName">Tivoli Maximo List Template</text-property>
<property name="bidiLayoutOrientation">ltr</property>
<list-property name="libraries">
<structure>
<property name="fileName">MaximoSystemLibrary.rptlibrary</property>
<property name="namespace">MaximoSystemLibrary</property>
</structure>
</list-property>
<parameters>
<scalar-parameter name="where" id="25">
<property name="valueType">static</property>
<property name="dataType">string</property>
<property name="isRequired">false</property>
<property name="controlType">text-box</property>
<property name="defaultValue">1=1</property>
<structure name="format">
<property name="category">Unformatted</property>
</structure>
</scalar-parameter>
<scalar-parameter name="appname" id="200">
</structure>
</scalar-parameter>
<scalar-parameter name="paramdelimiter" id="202">
<property name="hidden">true</property>
</structure>
</scalar-parameter>
<scalar-parameter name="paramstring" id="201">
</structure>
</scalar-parameter>
<scalar-parameter name="startdate" id="504">
<property name="paramType">simple</property>
<property name="defaultValue">10-11-01</property>
<property name="distinct">true</property>
</structure>
</scalar-parameter>
<scalar-parameter name="enddate" id="505">
<property name="defaultValue">11-01-07</property>
</structure>
</scalar-parameter>
<scalar-parameter name="siteid" id="506">
<property name="defaultValue">=CENTRAL</property>
</structure>
</scalar-parameter>
<scalar-parameter name="CostCentre" id="507">
<property name="defaultValue">561401</property>
</structure>
</scalar-parameter>
</parameters>
<data-sources>
<script-data-source name="maximoDataSource" id="64" extends="MaximoSystemLibrary.maximoDataSource"/>
</data-sources>
<data-sets>
<script-data-set name="dataSet1" id="415">
<list-property name="resultSetHints">
<structure>
<property name="position">1</property>
<property name="name">costcentre</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">uniqueno</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">empname</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">refwo</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">activity</property>
</structure>
<structure>
<property name="position">6</property>
<property name="name">StartDate</property>
</structure>
<structure>
<property name="position">7</property>
<property name="name">finishdate</property>
</structure>
<structure>
<property name="position">8</property>
<property name="name">allowtype</property>
</structure>
<structure>
<property name="position">9</property>
<property name="name">worklocation</property>
</structure>
<structure>
<property name="position">10</property>
<property name="name">Approved</property>
</structure>
<structure>
<property name="position">11</property>
<property name="name">months</property>
</structure>
<structure>
<property name="position">12</property>
<property name="name">dates</property>
</structure>
<structure>
<property name="position">13</property>
<property name="name">timefrom</property>
</structure>
<structure>
<property name="position">14</property>
<property name="name">timeto</property>
</structure>
<structure>
<property name="position">15</property>
<property name="name">hours</property>
</structure>
<structure>
<property name="position">16</property>
<property name="name">ErrorReport</property>
</structure>
<structure>
<property name="position">17</property>
<property name="name">Reversal</property>
</structure>
<structure>
<property name="position">18</property>
<property name="name">ErrorMessage</property>
</structure>
<structure>
<property name="position">19</property>
<property name="name">Recordid</property>
</structure>
<structure>
<property name="position">20</property>
<property name="name">enterby</property>
</structure>
<structure>
<property name="position">21</property>
<property name="name">n_authorisedby</property>
</structure>
<structure>
<property name="position">22</property>
<property name="name">Capture</property>
</structure>
<structure>
<property name="position">23</property>
<property name="name">today</property>
</structure>
<structure>
<property name="position">24</property>
<property name="name">ldesc</property>
</structure>
</list-property>
<list-property name="columnHints">
<structure>
<property name="columnName">costcentre</property>
</structure>
<structure>
<property name="columnName">uniqueno</property>
</structure>
<structure>
<property name="columnName">empname</property>
</structure>
<structure>
<property name="columnName">refwo</property>
</structure>
<structure>
<property name="columnName">activity</property>
</structure>
<structure>
<property name="columnName">StartDate</property>
</structure>
<structure>
<property name="columnName">finishdate</property>
</structure>
<structure>
<property name="columnName">allowtype</property>
</structure>
<structure>
<property name="columnName">worklocation</property>
</structure>
<structure>
<property name="columnName">Approved</property>
</structure>
<structure>
<property name="columnName">months</property>
</structure>
<structure>
<property name="columnName">dates</property>
</structure>
<structure>
<property name="columnName">timefrom</property>
</structure>
<structure>
<property name="columnName">timeto</property>
</structure>
<structure>
<property name="columnName">hours</property>
</structure>
<structure>
<property name="columnName">ErrorReport</property>
</structure>
<structure>
<property name="columnName">Reversal</property>
</structure>
<structure>
<property name="columnName">ErrorMessage</property>
</structure>
<structure>
<property name="columnName">Recordid</property>
</structure>
<structure>
<property name="columnName">enterby</property>
</structure>
<structure>
<property name="columnName">n_authorisedby</property>
</structure>
<structure>
<property name="columnName">Capture</property>
</structure>
<structure>
<property name="columnName">today</property>
</structure>
<structure>
<property name="columnName">ldesc</property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
</structure>
<property name="dataSource">maximoDataSource</property>
<method name="open"><![CDATA[maximoDataSet = MXReportDataSetProvider.create(this.getDataSource().getName( ), this.getName());
maximoDataSet.open();
var sqlText = new String();
// Add query to sqlText variable.
sqlText = " SELECT laborcraftrate.CONTROLACCOUNT costcentre, "
+ "lb.laborcode uniqueno, "
+ "p.displayname empname,labtrans.refwo, "
+ "labtrans.transtype activity, "
+ "labtrans.startdate StartDate, "
+ "labtrans.finishdate, "
+ "labtrans.n_overtimetype allowtype, lb.worklocation, "
+ "case when labtrans.genapprservreceipt = 1 then 'Y' else 'N' end Approved, "
+ "TO_CHAR (labtrans.startdate, 'yyyymm') months, TO_CHAR (labtrans.startdate, 'dd/mm/yyyy') dates, "
+ "TO_CHAR (labtrans.starttime, 'hh24:mi:ss') timefrom, TO_CHAR (labtrans.finishtime, 'hh24:mi:ss') timeto, "
+ "labtrans.regularhrs hours, labtrans.N_ERRORCODE ErrorReport, "
+ "case when labtrans.REGULARHRS < 0 then 'Y' else 'N' end Reversal, "
+ "labtrans.N_ERRORDESC ErrorMessage, "
+ "labtrans.N_RECORDID Recordid, "
+ "labtrans.enterby, "
+ "labtrans.n_authorisedby, "
+ "labtrans.n_capindnorrev Capture, "
+ " (select sysdate from dual)today, "
+ "l.description ldesc "
+ "FROM labor lb,person p,labtrans ,LABORCRAFTRATE, locations l "
+ "WHERE labtrans.laborcode = lb.laborcode "
+ "and l.location = lB.worklocation "
+ "AND (labtrans.n_overtimetype IS NOT NULL) "
+ "AND p.personid = lb.personid and lb.LABORCODE = laborcraftrate.LABORCODE "
+ "and laborcraftrate.controlaccount like (SELECT CASE WHEN '" + params["CostCentre"] + "' = '*' THEN '%' WHEN '" + params["CostCentre"] + "' is null THEN '%' "
+ "WHEN '" + params["CostCentre"] + "' = '%' THEN '%' else '" + params["CostCentre"] + "' end from dual) "
+ "and laborcraftrate.DEFAULTCRAFT = 1 "
+ "and labtrans.STARTDATE >= to_date('" + params["startdate"]+"'" + ",'yy-mm-dd') "
+ "and labtrans.STARTDATE < to_date('" + params["enddate"]+"'" + ",'yy-mm-dd')+1 and "
+ MXReportSqlFormat.createParamWhereClause("lb.worksite", params["siteid"])
+ "ORDER BY lb.laborcode,labtrans.startdate, labtrans.starttime "
maximoDataSet.setQuery(sqlText);]]></method>
<method name="fetch"><![CDATA[if (!maximoDataSet.fetch())
return (false);
// Add a line for each output column
// The specific get method should match the data type of the output column.
row["costcentre"] = maximoDataSet.getString("costcentre");
row["uniqueno"] = maximoDataSet.getString("uniqueno");
row["empname"] = maximoDataSet.getString("empname");
row["refwo"] = maximoDataSet.getString("refwo");
row["activity"] = maximoDataSet.getString("activity");
row["StartDate"] = maximoDataSet.getString("StartDate");
row["finishdate"] = maximoDataSet.getString("finishdate");
row["allowtype"] = maximoDataSet.getString("allowtype");
row["worklocation"] = maximoDataSet.getString("worklocation");
row["Approved"] = maximoDataSet.getString("Approved");
row["months"] = maximoDataSet.getString("months");
row["dates"] = maximoDataSet.getString("dates");
row["timefrom"] = maximoDataSet.getString("timefrom");
row["timeto"] = maximoDataSet.getString("timeto");
row["hours"] = maximoDataSet.getString("hours");
row["ErrorReport"] = maximoDataSet.getString("ErrorReport");
row["Reversal"] = maximoDataSet.getString("Reversal");
row["ErrorMessage"] = maximoDataSet.getString("ErrorMessage");
row["Recordid"] = maximoDataSet.getString("Recordid");
row["enterby"] = maximoDataSet.getString("enterby");
row["n_authorisedby"] = maximoDataSet.getString("n_authorisedby");
row["Capture"] = maximoDataSet.getString("Capture");
row["today"] = maximoDataSet.getString("today");
row["ldesc"] = maximoDataSet.getString("ldesc");
return (true);]]></method>
</script-data-set>
<script-data-set name="dataSet2" id="1118">
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
<property name="name">description</property>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
<property name="name">n_approvalind</property>
</structure>
</list-property>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
<property name="columnName">description</property>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
<property name="columnName">n_approvalind</property>
</structure>
</list-property>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
</structure>
+ "lb.laborcode uniqueno, p.displayname empname, "
+ "a.n_allowancecode allowtype, "
+ "v.DESCRIPTION description, "
+ "TO_CHAR (a.startdate, 'yyyymm') months, "
+ "TO_CHAR (a.startdate, 'dd/mm/yyyy') dates, "
+ "TO_CHAR (a.starttime, 'hh24:mi:ss') timefrom, "
+ "TO_CHAR (a.finishtime, 'hh24:mi:ss') timeto, "
+ "a.N_ERRORCODE ErrorReport, "
+ "a.N_ERRORDESC ErrorMessage, "
+ "a.N_RECORDID Recordid, "
//+ "case when a.n_allowancecode in ('4400','4420','4410','3700','3800','4000','4010','4020','41 00','4110','4120','4130','4140','4150','4160','GO','GO1','GO 2','HV','HW','HR1','HR2','HR3','KJ','KK','KL','K3','K4','K5' ,'K6')then count(a.n_allowancecode) else 0 end Allowcount, "
+ "lb.worklocation, "
+ " a.startdate StartDate, "
+ "a.n_capindnorrev Capture, "
+ " a.enterby, "
+ " a.n_authorisedby, "
+ " case when a.n_approvalind = 1 then 'Y' else 'N' end n_approvalind "
+ "FROM labor lb,person p ,LABORCRAFTRATE , attendance a ,synonymdomain v "
+ "where p.personid = lb.personid "
+ "and lb.LABORCODE = laborcraftrate.LABORCODE "
+ "and a.laborcode = lb.laborcode "
+ " and a.STARTDATE >= to_date('" + params["startdate"]+"'" + ",'yy-mm-dd') "
+ " and a.STARTDATE < to_date('" + params["enddate"]+"'" + ",'yy-mm-dd')+1 and "
+ "AND v.VALUE(+) = a.n_allowancecode "
+ "and v.DOMAINID = 'ALLOWANCES' "
+ " ORDER BY lb.laborcode,a.startdate "
/*+ "group by laborcraftrate.CONTROLACCOUNT , "
+ "lb.laborcode , p.displayname , "
+ "a.n_allowancecode , "
+ "v.DESCRIPTION , "
+ "a.startdate, "
+ "a.starttime, "
+ "a.finishtime, "
+ "a.N_ERRORCODE , "
+ "a.N_ERRORDESC , "
+ "a.N_RECORDID "*/
return (false);
row["description"] = maximoDataSet.getString("description");
//row["Allowcount"] = maximoDataSet.getString("Allowcount");
row["n_approvalind"] = maximoDataSet.getString("n_approvalind");
</script-data-set>
</data-sets>
<styles>
<style name="crosstab" id="341">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab-cell" id="342">
</style>
</styles>
<page-setup>
<simple-master-page name="maximoLandscape" id="47" extends="MaximoSystemLibrary.maximoLandscape">
<property name="type">custom</property>
<property name="height">10in</property>
<property name="width">19in</property>
<overridden-values>
<ref-entry baseId="304" name="NewGrid2" id="304"/>
<ref-entry baseId="305" id="305"/>
<ref-entry baseId="306" id="306"/>
<ref-entry baseId="307" id="307"/>
<ref-entry baseId="308" id="308"/>
<ref-entry baseId="340" name="NewImage1" id="340">
<list-property name="visibility">
<structure>
<property name="format">all</property>
<expression name="valueExpr">true</expression>
</structure>
</list-property>
</ref-entry>
<ref-entry baseId="309" id="309"/>
<ref-entry baseId="310" name="NewImage" id="310">
<property name="source">file</property>
<expression name="uri">"eskom.gif"</expression>
<property name="height">10mm</property>
<property name="width">35mm</property>
</ref-entry>
<ref-entry baseId="322" name="NewGrid" id="322"/>
<ref-entry baseId="323" id="323"/>
<ref-entry baseId="324" id="324"/>
<ref-entry baseId="325" id="325"/>
<ref-entry baseId="326" id="326"/>
<ref-entry baseId="328" name="NewText" id="328"/>
<ref-entry baseId="327" id="327"/>
<ref-entry baseId="329" name="NewGrid1" id="329"/>
<ref-entry baseId="330" id="330"/>
<ref-entry baseId="331" id="331"/>
<ref-entry baseId="332" id="332"/>
<ref-entry baseId="333" id="333"/>
<ref-entry baseId="334" id="334"/>
<ref-entry baseId="335" name="NewAutoText" id="335"/>
<ref-entry baseId="336" id="336"/>
<ref-entry baseId="337" name="NewText1" id="337"/>
<ref-entry baseId="338" id="338"/>
<ref-entry baseId="339" name="NewAutoText1" id="339"/>
</overridden-values>
<property name="headerHeight">0.5in</property&g
Re: Export Birt report in Excel [message #649563 is a reply to message #649505] |
Wed, 19 January 2011 12:42   |
Nolo
for some reason the whole report did not come through. If you have
multiple tables you need to use Richards approach. The visibility
expression is available in the properties below the report canvas when
you select the table.
Jason
> id="1">
> 5724-M19
> ></method>
> <structure>
> </structure>
> </list-property>
> <parameters>
> </structure>
> </scalar-parameter>
> </structure>
> </scalar-parameter>
> </structure>
> </scalar-parameter>
> </structure>
> </scalar-parameter>
> </structure>
> </scalar-parameter>
> </structure>
> </scalar-parameter>
> </structure>
> </scalar-parameter>
> </structure>
> </scalar-parameter>
> </parameters>
> <data-sources>
> </data-sources>
> <data-sets>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> </structure>
> this.getName());
> Approved, "
> ",'yy-mm-dd') "
> params["siteid"]) + "ORDER BY lb.laborcode,labtrans.startdate,
> return (false);
> </script-data-set>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> </structure>
> this.getName());
> + " a.enterby, "
> ",'yy-mm-dd') "
> params["siteid"]) + "AND v.VALUE(+) = a.n_allowancecode "
> + "a.startdate, "
> + "a.starttime, "
> + "a.finishtime, "
> + "a.N_ERRORCODE , " + "a.N_ERRORDESC , "
> + "a.N_RECORDID "*/
> return (false);
> </script-data-set>
> </data-sets>
> <styles>
> </style>
> </style>
> </styles>
> <page-setup>
> <overridden-values>
> <structure>
> </structure>
> </list-property>
> </ref-entry>
> </ref-entry>
(no subject) [message #727568 is a reply to message #649816] |
Wed, 21 September 2011 09:40   |
Hi Jason,
I have the same problem , i have sent my report and sample output to your mail id.
please advise.
Same is attached here too.
Vijay
begin 644 SV_Summary_TN_Range.rptdesign
M/#]X;6P@=F5R<VEO;CTB,2XP(B!E;F-O9&EN9STB551&+3@B/SX*/')E<&]R
M="!X;6QN<STB:'1T<#HO+W=W=RYE8VQI<'-E+F]R9R]B:7)T+S(P,#4O9&5S
M:6=N(B!V97)S:6]N/2(S+C(N,C$B(&ED/2(Q(CX*("`@(#QP<F]P97)T>2!N
M86UE/2)C<F5A=&5D0GDB/D5C;&EP<V4@0DE25"!$97-I9VYE<B!697)S:6]N
M(#(N-2XR+G8R,#$P,#(P."!"=6EL9"`F;'0[,BXU+C(N=C(P,3`P,C$P+3`V
M,S`^/"]P<F]P97)T>3X*("`@(#QT97AT+7!R;W!E<G1Y(&YA;64](G1I=&QE
M(CY3=6)S8W)I<'1I;VX@5F5R<VEO;B!3=6UM87)Y(%)E<&]R="`H0GD@5$X@
M4F%N9V4L(%-T871U<R!A;F0@4&]R="!4>7!E*3PO=&5X="UP<F]P97)T>3X*
M("`@(#QP<F]P97)T>2!N86UE/2)U;FET<R(^:6X\+W!R;W!E<G1Y/@H@("`@
M/&UE=&AO9"!N86UE/2)I;FET:6%L:7IE(CX\(5M#1$%405MI;7!O<G1086-K
M86=E*%!A8VMA9V5S+FIA=F$N;&%N9RD["@I":7)T3&]G9V5R(#T@;W)G+F%P
M86-H92YL;V<T:BY,;V=G97(N9V5T3&]G9V5R*")"25)4(BD["D)I<G1,;V=G
M97(N9&5B=6<@*")35B!297!O<G0@8GD@5$X@4F%N9V4Z($EN:71I86QI>F4B
M*3L*"F5R<F]R8V]D92`](#`["@HO+U1H:7,@;&]G:6,@:&%S('1O(&)E(&ME
M<'0@:6X@86QL(')E<&]R=',@9F]R(&UO<F4@9G5N8W1I;VYA;&ET>2!35$%2
M5"`M+2T*=F%R('-/=71P=70@/2`B(CL*<T]U='!U=#TB(CL*=F%R('!A<F%M
M971E<D%R<F%Y(#T@<F5P;W)T0V]N=&5X="YG971$97-I9VY(86YD;&4H*2YG
M971!;&Q087)A;65T97)S*"D[.PIV87(@<&%R86UA=&5R0V]U;G0@/2!P87)A
M;65T97)!<G)A>2YS:7IE*"D["@IF;W(H('9A<B!I(#T@,#L@:2`\('!A<F%M
M871E<D-O=6YT.R!I*RL@*0I["@EV87(@<U!A<DYA;64@/2!P87)A;65T97)!
M<G)A>2YG970H:2DN9V5T1G5L;$YA;64H*3L)"@EI9B@@<&%R86UE=&5R07)R
M87DN9V5T*&DI+F=E=$-L87-S*"DN=&]3=')I;F<H*2`]/2`B8VQA<W,@;W)G
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M="`K("(_(B`K('-087).86UE("L@(CTB("L@<U!A<E9A;#L*"0E]"@D)96QS
M92!I9B@@0FER=$-O;7`N97%U86Q4;RAS4&%R3F%M92PB;6%X7W)O=VYU;2(I
M('Q\("!":7)T0V]M<"YE<75A;%1O*'-087).86UE+")M:6Y?<F]W;G5M(BDI
M>PH)"0D@+R\@<VMI<"!M:6Y?<F]W;G5M(&%N9"!M87A?<F]W;B`Z('1H97-E
M('=I;&P@8F4@861D960@8GD@<V-R:7!T"@D)"2!":7)T3&]G9V5R+F1E8G5G
M("@B4U8@4F5P;W)T(&)Y(%1.(%)A;F=E.B!);FET:6%L('9A;'5E("T@(B`K
M('-087).86UE("L@(CTB("L@<U!A<E9A;"D["@D)?0H)"65L<V4@:68H($)I
M<G1#;VUP+F5Q=6%L5&\H<U!A<DYA;64L(E-67U-405154R(I*0E["@D)"4)I
M<G1,;V=G97(N9&5B=6<@*")35B!297!O<G0@8GD@5$X@4F%N9V4Z($EN:71I
M86P@=F%L=64@+2`B("L@<U!A<DYA;64@*R`B/2(@*R!S4&%R5F%L*3L*"0D)
M"@D)"79A<B!S=&%T=7-686P@/2`B(CL*"0D)+R\@4U8@4W1A='5S(&-R:71E
M<FEA"@D)"79A<B!P87)M8V]U;G0@/2!P87)A;7-;(E-67U-405154R)=+G9A
M;'5E+FQE;F=T:#L*"0D)9F]R("@@=F%R(&H],#L@:B`\('!A<FUC;W5N=#L@
M:BLK("E["@D)"0EI9B`H('!A<F%M<ULB4U9?4U1!5%53(ETN=F%L=65;:ET@
M(3T@+3$@*2!["@D)"0D):68H(&H@/3T@,"`I>PH)"0D)"0ES=&%T=7-686P@
M*ST@<&%R86US6R)35E]35$%455,B72YV86QU95MJ73L*"0D)"0E](`H)"0D)
M"65L<V4@>PH)"0D)"0ES=&%T=7-686P@/2!S=&%T=7-686P@*R`B+"(@*R!P
M87)A;7-;(E-67U-405154R)=+G9A;'5E6VI=.R`*"0D)"0E]"@D)"0E]"@D)
M"0EE;'-E('L*"0D)"0ES=&%T=7-686P@/2`B+3$B.PH)"0D)"6)R96%K.PH)
M"0D)?0H)"0E]"@D)"6EF("@@<W1A='5S5F%L("$]("(B("D@>PH)"0D)<T]U
M='!U="`]('-/=71P=70@*R`B)F%M<#LB("L@<U!A<DYA;64@*R`B/2(@*R!S
M=&%T=7-686P["@D)"7T*"0E]"@D)96QS92!["@D)"6EF("@@<U!A<E9A;"`A
M/2`B(B`I('L*"0D)"7-/=71P=70@/2!S3W5T<'5T("L@(B9A;7`[(B`K('-0
M87).86UE("L@(CTB("L@<U!A<E9A;#L@"@D)"7T*"0E]"@E]"GT*"G)E<&]R
M=$-O;G1E>'0N<V5T1VQO8F%L5F%R:6%B;&4H(E]P87)A;4QI<W0B+'-/=71P
M=70I.PI":7)T3&]G9V5R+FEN9F\@*")35B!297!O<G0@8GD@5$X@4F%N9V4Z
M(%!A<F%M971E<B!,:7-T("T@(B`K('-/=71P=70I.PH*+R\@5&AI<R!L;V=I
M8R!H87,@=&\@8F4@:V5P="!I;B!A;&P@<F5P;W)T<R!F;W(@;6]R92!F=6YC
M=&EO;F%L:71Y("TM+2!%3D1=73X\+VUE=&AO9#X*("`@(#QM971H;V0@;F%M
M93TB8F5F;W)E1F%C=&]R>2(^/"%;0T1!5$%;:6UP;W)T4&%C:V%G92A086-K
M86=E<RYJ879A+FQA;F<I.PH*0FER=$QO9V=E<BYD96)U9R`H(E-6(%)E<&]R
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M7U)!3D=%(#T@(B`K('-T<E1N4F%N9V4@*R`B("A,14Y'5$@@/2`B("L@;&5N
M("L@(BD@(CL*"FEF("@@;&5N(#P](#$P("D@>PH):68@*"!L96X@/"`S("D@
M>PH)"45R<F]R37-G("L](")&86EL960N($%T(&QE87-T(&$@,R!D:6=I="!.
M4$$@:7,@<F5Q=6ER960N(CL*"0EE<G)O<F-O9&4@/2`Q,#`Q.PH)?0H*"6EF
M("@@;&5N(#P](#`@*2!["@D)17)R;W)-<V<@*ST@(D9A:6QE9"X@5$X@4F%N
M9V4@:7,@82!R97%U:7)E9"!I;G!U="!P87)A;65T97(N(CL*"0EE<G)O<F-O
M9&4@/2`Q,#`T.PH)?0H)"@DO+R!686QI9&%T:6]N(&9O<B!N=6UE<FEC('9A
M;'5E"@EI9B`H(&5R<F]R8V]D92`]/2`P("D@>PH)"69O<B`H:2`](#`[(&D@
M/"!L96X[(&DK*RD*"0E["@D)"7-T<D-H87(@/2!S=')4;E)A;F=E+F-H87)!
M="AI*3L*"0D):68@*"!S=')#:&%R(#P@-#@@?'P@<W1R0VAA<B`^(#4W("D@
M>PH)"0D)17)R;W)-<V<@*ST@(D9A:6QE9"X@5$X@4F%N9V4@<&%R86UE=&5R
M(&-O;G1A:6YS(&YO;BUN=6UE<FEC('9A;'5E+B(["@D)"0EE<G)O<F-O9&4@
M/2`Q,#`R.PH)"0D)8G)E86L["@D)"7T*"0E]"@E]"GT*96QS92!["@EI9B`H
M(&QE;B`A/2`Q-2`I('L*"0E%<G)O<DUS9R`K/2`B1F%I;&5D+B!43B!286YG
M92!S:&]U;&0@8V]N=&%I;B`Q-2!C:&%R86-T97)S("A#;W)R96-T($9O<FUA
M=#H@3E!!3EA84U-34RU34U-3*2XB.PH)"65R<F]R8V]D92`](#$P,#,["0H)
M?0H)+R]686QI9&%T:6]N(&9O<B!F;W)M870@;G!A;GAX<W-S<RUS<W-S"@EF
M;W(@*&D@/2`P.R!I(#P@;&5N.R!I*RLI"@E["@D)<W1R0VAA<B`]('-T<E1N
M4F%N9V4N8VAA<D%T*&DI.PH)"0H)"6EF("@@:2`\(#$P("D@>PH)"0EI9B`H
M('-T<D-H87(@/"`T."!\?"!S=')#:&%R(#X@-3<@*2!["@D)"0E%<G)O<DUS
M9R`K/2`B1F%I;&5D+B!43B!286YG92!P87)A;65T97(@8V]N=&%I;G,@;F]N
M+6YU;65R:6,@=F%L=64N(CL*"0D)"65R<F]R8V]D92`](#$P,#(["@D)"0EB
M<F5A:SL*"0D)?0H)"7T*"0EE;'-E(&EF("@@:2`]/2`Q,"`I('L*"0D):68@
M*"!S=')#:&%R("$](#0U("D@>R`O+R`T-2!I;F1I8V%T97,@)RTG"@D)"0E%
M<G)O<DUS9R`K/2`B1F%I;&5D+B!43B!286YG92!P<F]V:61E9"!I<R!I;G9A
M;&ED("A#;W)R96-T($9O<FUA=#H@3E!!3EA86%A86"U965E9*2XB.PH)"0D)
M97)R;W)C;V1E(#T@,3`P,SL*"0D)?0H)"7T*"0EE;'-E(&EF("@@:2`^(#$P
M("9A;7`[)F%M<#L@:2`\(#$U("D@>PH)"0EI9B`H('-T<D-H87(@/"`T."!\
M?"!S=')#:&%R(#X@-3<@*2!["@D)"0E%<G)O<DUS9R`K/2`B1F%I;&5D+B!4
M3B!286YG92!P87)A;65T97(@8V]N=&%I;G,@;F]N+6YU;65R:6,@=F%L=64N
M(CL*"0D)"65R<F]R8V]D92`](#$P,#(["@D)"0EB<F5A:SL*"0D)?0H)"7T*
M"7T*?0H*<F5P;W)T0V]N=&5X="YS971';&]B86Q687)I86)L92@B17)R;W)#
M;V1E(BQE<G)O<F-O9&4I.PII9B@@97)R;W)C;V1E("$](#`@*2!["@ER97!O
M<G1#;VYT97AT+F=E=$1E<VEG;DAA;F1L92@I+F9I;F1%;&5M96YT*")35E)E
M<&]R=$)Y5$XB*2YD<F]P*"D["GT*96QS92!["@E%<G)O<DUS9R`K/2`B4&%S
M<V5D+B(["GT*"D)I<G1,;V=G97(N:6YF;R`H(E-6(%)E<&]R="!B>2!43B!2
M86YG93H@(B`K($5R<F]R37-G*3M=73X\+VUE=&AO9#X*("`@(#QP<F]P97)T
M>2!N86UE/2)T:&5M92(^8V]M;6]N7V1B+D1E9F%U;'0@5&AE;64@+3$\+W!R
M;W!E<G1Y/@H@("`@/'!R;W!E<G1Y(&YA;64](FEC;VY&:6QE(CXO=&5M<&QA
M=&5S+V)L86YK7W)E<&]R="YG:68\+W!R;W!E<G1Y/@H@("`@/'!R;W!E<G1Y
M(&YA;64](FQA>6]U=%!R969E<F5N8V4B/F9I>&5D(&QA>6]U=#PO<')O<&5R
M='D^"B`@("`\<')O<&5R='D@;F%M93TB8FED:4QA>6]U=$]R:65N=&%T:6]N
M(CYL='(\+W!R;W!E<G1Y/@H@("`@/'!R;W!E<G1Y(&YA;64](FEM86=E1%!)
M(CXY-CPO<')O<&5R='D^"B`@("`\;&ES="UP<F]P97)T>2!N86UE/2)L:6)R
M87)I97,B/@H@("`@("`@(#QS=')U8W1U<F4^"B`@("`@("`@("`@(#QP<F]P
M97)T>2!N86UE/2)F:6QE3F%M92(^8V]M;6]N7V1B+G)P=&QI8G)A<GD\+W!R
M;W!E<G1Y/@H@("`@("`@("`@("`\<')O<&5R='D@;F%M93TB;F%M97-P86-E
M(CYC;VUM;VY?9&(\+W!R;W!E<G1Y/@H@("`@("`@(#PO<W1R=6-T=7)E/@H@
M("`@/"]L:7-T+7!R;W!E<G1Y/@H@("`@/'!A<F%M971E<G,^"B`@("`@("`@
M/'-C86QA<BUP87)A;65T97(@;F%M93TB7U]R97!O<G0B(&ED/2(T,C`B(&5X
M=&5N9',](F-O;6UO;E]D8BY?7W)E<&]R="(O/@H@("`@("`@(#QS8V%L87(M
M<&%R86UE=&5R(&YA;64](E1.7U)!3D=%(B!I9#TB,3<Y(CX*("`@("`@("`@
M("`@/'1E>'0M<')O<&5R='D@;F%M93TB:&5L<%1E>'0B/E-I;F=L92!43B!O
M<B!A(%1.(%)A;F=E+B!.4$$@:7,@;6%N9&%T;W)Y/"]T97AT+7!R;W!E<G1Y
M/@H@("`@("`@("`@("`\=&5X="UP<F]P97)T>2!N86UE/2)P<F]M<'1497AT
M(CY43B!286YG92`H1F]R;6%T.B!.4$%.6%A34U-3+5-34U,I/"]T97AT+7!R
M;W!E<G1Y/@H@("`@("`@("`@("`\<')O<&5R='D@;F%M93TB=F%L=654>7!E
M(CYS=&%T:6,\+W!R;W!E<G1Y/@H@("`@("`@("`@("`\<')O<&5R='D@;F%M
M93TB9&%T851Y<&4B/G-T<FEN9SPO<')O<&5R='D^"B`@("`@("`@("`@(#QP
M<F]P97)T>2!N86UE/2)D:7-T:6YC="(^=')U93PO<')O<&5R='D^"B`@("`@
M("`@("`@(#QP<F]P97)T>2!N86UE/2)P87)A;51Y<&4B/G-I;7!L93PO<')O
M<&5R='D^"B`@("`@("`@("`@(#QP<F]P97)T>2!N86UE/2)C;VYT<F]L5'EP
M92(^=&5X="UB;W@\+W!R;W!E<G1Y/@H@("`@("`@("`@("`\<W1R=6-T=7)E
M(&YA;64](F9O<FUA="(^"B`@("`@("`@("`@("`@("`\<')O<&5R='D@;F%M
M93TB8V%T96=O<GDB/E5N9F]R;6%T=&5D/"]P<F]P97)T>3X*("`@("`@("`@
M("`@/"]S=')U8W1U<F4^"B`@("`@("`@/"]S8V%L87(M<&%R86UE=&5R/@H@
M("`@("`@(#QS8V%L87(M<&%R86UE=&5R(&YA;64](E-67U-405154R(@:60]
M(C$U-R(^"B`@("`@("`@("`@(#QT97AT+7!R;W!E<G1Y(&YA;64](FAE;'!4
M97AT(CY3=6)S8W)I<'1I;VX@5F5R<VEO;B!3=&%T=7,\+W1E>'0M<')O<&5R
M='D^"B`@("`@("`@("`@(#QT97AT+7!R;W!E<G1Y(&YA;64](G!R;VUP=%1E
M>'0B/E-U8G-C<FEP=&EO;B!3=&%T=7,\+W1E>'0M<')O<&5R='D^"B`@("`@
M("`@("`@(#QP<F]P97)T>2!N86UE/2)V86QU951Y<&4B/G-T871I8SPO<')O
M<&5R='D^"B`@("`@("`@("`@(#QP<F]P97)T>2!N86UE/2)D871A5'EP92(^
M<W1R:6YG/"]P<F]P97)T>3X*("`@("`@("`@("`@/'!R;W!E<G1Y(&YA;64]
M(F1I<W1I;F-T(CYT<G5E/"]P<F]P97)T>3X*("`@("`@("`@("`@/'-I;7!L
M92UP<F]P97)T>2UL:7-T(&YA;64](F1E9F%U;'1686QU92(^"B`@("`@("`@
M("`@("`@("`\=F%L=64@='EP93TB8V]N<W1A;G0B/BTQ/"]V86QU93X*("`@
M("`@("`@("`@/"]S:6UP;&4M<')O<&5R='DM;&ES=#X*("`@("`@("`@("`@
M/&QI<W0M<')O<&5R='D@;F%M93TB<V5L96-T:6]N3&ES="(^"B`@("`@("`@
M("`@("`@("`\<W1R=6-T=7)E/@H@("`@("`@("`@("`@("`@("`@(#QP<F]P
M97)T>2!N86UE/2)V86QU92(^+3$\+W!R;W!E<G1Y/@H@("`@("`@("`@("`@
M("`@("`@(#QP<F]P97)T>2!N86UE/2)L86)E;"(^04Q,/"]P<F]P97)T>3X*
M("`@("`@("`@("`@("`@(#PO<W1R=6-T=7)E/@H@("`@("`@("`@("`@("`@
M/'-T<G5C='5R93X*("`@("`@("`@("`@("`@("`@("`\<')O<&5R='D@;F%M
M93TB=F%L=64B/C`\+W!R;W!E<G1Y/@H@("`@("`@("`@("`@("`@("`@(#QP
M<F]P97)T>2!N86UE/2)L86)E;"(^0V]N9FQI8W0\+W!R;W!E<G1Y/@H@("`@
M("`@("`@("`@("`@/"]S=')U8W1U<F4^"B`@("`@("`@("`@("`@("`\<W1R
M=6-T=7)E/@H@("`@("`@("`@("`@("`@("`@(#QP<F]P97)T>2!N86UE/2)V
M86QU92(^,3PO<')O<&5R='D^"B`@("`@("`@("`@("`@("`@("`@/'!R;W!E
M<G1Y(&YA;64](FQA8F5L(CY!8W1I=F4\+W!R;W!E<G1Y/@H@("`@("`@("`@
M("`@("`@/"]S=')U8W1U<F4^"B`@("`@("`@("`@("`@("`\<W1R=6-T=7)E
M/@H@("`@("`@("`@("`@("`@("`@(#QP<F]P97)T>2!N86UE/2)V86QU92(^
M,CPO<')O<&5R='D^"B`@("`@("`@("`@("`@("`@("`@/'!R;W!E<G1Y(&YA
M;64](FQA8F5L(CY096YD:6YG/"]P<F]P97)T>3X*("`@("`@("`@("`@("`@
M(#PO<W1R=6-T=7)E/@H@("`@("`@("`@("`@("`@/'-T<G5C='5R93X*("`@
M("`@("`@("`@("`@("`@("`\<')O<&5R='D@;F%M93TB=F%L=64B/C,\+W!R
M;W!E<G1Y/@H@("`@("`@("`@("`@("`@("`@(#QP<F]P97)T>2!N86UE/2)L
M86)E;"(^4V5N9&EN9SPO<')O<&5R='D^"B`@("`@("`@("`@("`@("`\+W-T
M<G5C='5R93X*("`@("`@("`@("`@("`@(#QS=')U8W1U<F4^"B`@("`@("`@
M("`@("`@("`@("`@/'!R;W!E<G1Y(&YA;64](G9A;'5E(CXT/"]P<F]P97)T
M>3X*("`@("`@("`@("`@("`@("`@("`\<')O<&5R='D@;F%M93TB;&%B96PB
M/D9A:6QE9#PO<')O<&5R='D^"B`@("`@("`@("`@("`@("`\+W-T<G5C='5R
M93X*("`@("`@("`@("`@("`@(#QS=')U8W1U<F4^"B`@("`@("`@("`@("`@
M("`@("`@/'!R;W!E<G1Y(&YA;64](G9A;'5E(CXU/"]P<F]P97)T>3X*("`@
M("`@("`@("`@("`@("`@("`\<')O<&5R='D@;F%M93TB;&%B96PB/E!A<G1I
M86P@1F%I;'5R93PO<')O<&5R='D^"B`@("`@("`@("`@("`@("`\+W-T<G5C
M='5R93X*("`@("`@("`@("`@("`@(#QS=')U8W1U<F4^"B`@("`@("`@("`@
M("`@("`@("`@/'!R;W!E<G1Y(&YA;64](G9A;'5E(CXV/"]P<F]P97)T>3X*
M("`@("`@("`@("`@("`@("`@("`\<')O<&5R='D@;F%M93TB;&%B96PB/D1I
M<V-O;FYE8W0@4&5N9&EN9SPO<')O<&5R='D^"B`@("`@("`@("`@("`@("`\
M+W-T<G5C='5R93X*("`@("`@("`@("`@("`@(#QS=')U8W1U<F4^"B`@("`@
M("`@("`@("`@("`@("`@/'!R;W!E<G1Y(&YA;64](G9A;'5E(CXW/"]P<F]P
M97)T>3X*("`@("`@("`@("`@("`@("`@("`\<')O<&5R='D@;F%M93TB;&%B
M96PB/D]L9#PO<')O<&5R='D^"B`@("`@("`@("`@("`@("`\+W-T<G5C='5R
M("`@("`@/'!R;W!E<G1Y(&YA;64](G9A;'5E(CXX/"]P<F]P97)T>3X*("`@
M("`@("`@("`@("`@("`@("`\<')O<&5R='D@;F%M93TB;&%B96PB/D-A;F-E
M;&5D/"]P<F]P97)T>3X*("`@("`@("`@("`@("`@(#PO<W1R=6-T=7)E/@H@
M("`@("`@("`@("`@("`@/'-T<G5C='5R93X*("`@("`@("`@("`@("`@("`@
M("`\<')O<&5R='D@;F%M93TB=F%L=64B/CD\+W!R;W!E<G1Y/@H@("`@("`@
M("`@("`@("`@("`@(#QP<F]P97)T>2!N86UE/2)L86)E;"(^0V%N8V5L(%!E
M;F1I;F<\+W!R;W!E<G1Y/@H@("`@("`@("`@("`@("`@/"]S=')U8W1U<F4^
M"B`@("`@("`@("`@("`@("`\<W1R=6-T=7)E/@H@("`@("`@("`@("`@("`@
M("`@(#QP<F]P97)T>2!N86UE/2)V86QU92(^,3`\+W!R;W!E<G1Y/@H@("`@
M("`@("`@("`@("`@("`@(#QP<F]P97)T>2!N86UE/2)L86)E;"(^56YD969I
M;F5D/"]P<F]P97)T>3X*("`@("`@("`@("`@("`@(#PO<W1R=6-T=7)E/@H@
M("`\<')O<&5R='D@;F%M93TB=F%L=64B/CDY/"]P<F]P97)T>3X*("`@("`@
M("`@("`@("`@("`@("`\<')O<&5R='D@;F%M93TB;&%B96PB/E9O:60\+W!R
M;W!E<G1Y/@H@("`@("`@("`@("`@("`@/"]S=')U8W1U<F4^"B`@("`@("`@
M("`@(#PO;&ES="UP<F]P97)T>3X*("`@("`@("`@("`@/'!R;W!E<G1Y(&YA
M;64](G!A<F%M5'EP92(^;75L=&DM=F%L=64\+W!R;W!E<G1Y/@H@("`@("`@
M("`@("`\<')O<&5R='D@;F%M93TB8V]N=')O;%1Y<&4B/FQI<W0M8F]X/"]P
M<F]P97)T>3X*("`@("`@("`@("`@/'!R;W!E<G1Y(&YA;64](FUU<W1-871C
M:"(^=')U93PO<')O<&5R='D^"B`@("`@("`@("`@(#QP<F]P97)T>2!N86UE
M/2)F:7AE9$]R9&5R(CYT<G5E/"]P<F]P97)T>3X*("`@("`@("`@("`@/'-T
M<G5C='5R92!N86UE/2)F;W)M870B/@H@("`@("`@("`@("`@("`@/'!R;W!E
M<G1Y(&YA;64](F-A=&5G;W)Y(CY5;F9O<FUA='1E9#PO<')O<&5R='D^"B`@
M("`@("`@("`@(#PO<W1R=6-T=7)E/@H@("`@("`@(#PO<V-A;&%R+7!A<F%M
M971E<CX*("`@("`@("`\<V-A;&%R+7!A<F%M971E<B!N86UE/2)03U)47U19
M4$4B(&ED/2(Q-C$B/@H@("`@("`@("`@("`\=&5X="UP<F]P97)T>2!N86UE
M/2)H96QP5&5X="(^5'EP92!O9B!,3E`@<&]R="`H3$E34"P@3%-04"!O<B!0
M;V]L*3PO=&5X="UP<F]P97)T>3X*("`@("`@("`@("`@/'1E>'0M<')O<&5R
M='D@;F%M93TB<')O;7!T5&5X="(^4&]R="!4>7!E/"]T97AT+7!R;W!E<G1Y
M/@H@("`@("`@("`@("`\<')O<&5R='D@;F%M93TB=F%L=654>7!E(CYS=&%T
M:6,\+W!R;W!E<G1Y/@H@("`@("`@("`@("`\<')O<&5R='D@;F%M93TB:7-2
M97%U:7)E9"(^=')U93PO<')O<&5R='D^"B`@("`@("`@("`@(#QP<F]P97)T
M>2!N86UE/2)D871A5'EP92(^:6YT96=E<CPO<')O<&5R='D^"B`@("`@("`@
M("`@(#QP<F]P97)T>2!N86UE/2)D:7-T:6YC="(^=')U93PO<')O<&5R='D^
M"B`@("`@("`@("`@(#QS:6UP;&4M<')O<&5R='DM;&ES="!N86UE/2)D969A
M=6QT5F%L=64B/@H@("`@("`@("`@("`@("`@/'9A;'5E('1Y<&4](F-O;G-T
M86YT(CXM,3PO=F%L=64^"B`@("`@("`@("`@(#PO<VEM<&QE+7!R;W!E<G1Y
M+6QI<W0^"B`@("`@("`@("`@(#QL:7-T+7!R;W!E<G1Y(&YA;64](G-E;&5C
M=&EO;DQI<W0B/@H@("`@("`@("`@("`@("`@/'-T<G5C='5R93X*("`@("`@
M("`@("`@("`@("`@("`\<')O<&5R='D@;F%M93TB=F%L=64B/BTQ/"]P<F]P
M96PB/D%,3#PO<')O<&5R='D^"B`@("`@("`@("`@("`@("`\+W-T<G5C='5R
M("`@("`@/'!R;W!E<G1Y(&YA;64](G9A;'5E(CXP/"]P<F]P97)T>3X*("`@
M("`@("`@("`@("`@("`@("`\<')O<&5R='D@;F%M93TB;&%B96PB/DQ34%`\
M+W!R;W!E<G1Y/@H@("`@("`@("`@("`@("`@/"]S=')U8W1U<F4^"B`@("`@
M("`@("`@("`@("`\<W1R=6-T=7)E/@H@("`@("`@("`@("`@("`@("`@(#QP
M<F]P97)T>2!N86UE/2)V86QU92(^,3PO<')O<&5R='D^"B`@("`@("`@("`@
M("`@("`@("`@/'!R;W!E<G1Y(&YA;64](FQA8F5L(CY,25-0/"]P<F]P97)T
M>3X*("`@("`@("`@("`@("`@(#PO<W1R=6-T=7)E/@H@("`@("`@("`@("`@
M("`@/'-T<G5C='5R93X*("`@("`@("`@("`@("`@("`@("`\<')O<&5R='D@
M;F%M93TB=F%L=64B/C(\+W!R;W!E<G1Y/@H@("`@("`@("`@("`@("`@("`@
M(#QP<F]P97)T>2!N86UE/2)L86)E;"(^4$]/3#PO<')O<&5R='D^"B`@("`@
M("`@("`@("`@("`\+W-T<G5C='5R93X*("`@("`@("`@("`@/"]L:7-T+7!R
M;W!E<G1Y/@H@("`@("`@("`@("`\<')O<&5R='D@;F%M93TB<&%R86U4>7!E
M(CYS:6UP;&4\+W!R;W!E<G1Y/@H@("`@("`@("`@("`\<')O<&5R='D@;F%M
M93TB8V]N=')O;%1Y<&4B/FQI<W0M8F]X/"]P<F]P97)T>3X*("`@("`@("`@
M("`@/'!R;W!E<G1Y(&YA;64](FUU<W1-871C:"(^=')U93PO<')O<&5R='D^
M"B`@("`@("`@("`@(#QP<F]P97)T>2!N86UE/2)F:7AE9$]R9&5R(CYT<G5E
M/"]P<F]P97)T>3X*("`@("`@("`@("`@/'-T<G5C='5R92!N86UE/2)F;W)M
M870B/@H@("`@("`@("`@("`@("`@/'!R;W!E<G1Y(&YA;64](F-A=&5G;W)Y
M(CY5;F9O<FUA='1E9#PO<')O<&5R='D^"B`@("`@("`@("`@(#PO<W1R=6-T
M=7)E/@H@("`@("`@(#PO<V-A;&%R+7!A<F%M971E<CX*("`@("`@("`\<V-A
M;&%R+7!A<F%M971E<B!N86UE/2).15=?4U!)1"(@:60](C(P,2(^"B`@("`@
M("`@("`@(#QT97AT+7!R;W!E<G1Y(&YA;64](FAE;'!497AT(CY.97<@4V5R
M=FEC92!0<F]V:61E<B!)1#PO=&5X="UP<F]P97)T>3X*("`@("`@("`@("`@
M/'1E>'0M<')O<&5R='D@;F%M93TB<')O;7!T5&5X="(^3F5W(%-0/"]T97AT
M+7!R;W!E<G1Y/@H@("`@("`@("`@("`\<')O<&5R='D@;F%M93TB=F%L=654
M>7!E(CYD>6YA;6EC/"]P<F]P97)T>3X*("`@("`@("`@("`@/'!R;W!E<G1Y
M(&YA;64](FES4F5Q=6ER960B/G1R=64\+W!R;W!E<G1Y/@H@("`@("`@("`@
M("`\<')O<&5R='D@;F%M93TB9&%T85-E=$YA;64B/D137U-0241?3$E35#PO
M<')O<&5R='D^"B`@("`@("`@("`@(#QE>'!R97-S:6]N(&YA;64](G9A;'5E
M17AP<B(@='EP93TB:F%V87-C<FEP="(^9&%T85-E=%)O=ULB4U!)1")=/"]E
M>'!R97-S:6]N/@H@("`@("`@("`@("`\97AP<F5S<VEO;B!N86UE/2)L86)E
M;$5X<'(B('1Y<&4](FIA=F%S8W)I<'0B/F1A=&%39712;W=;(E-0240B73PO
M97AP<F5S<VEO;CX*("`@("`@("`@("`@/'!R;W!E<G1Y(&YA;64](F1A=&%4
M>7!E(CYS=')I;F<\+W!R;W!E<G1Y/@H@("`@("`@("`@("`\<')O<&5R='D@
M;F%M93TB9&ES=&EN8W0B/G1R=64\+W!R;W!E<G1Y/@H@("`@("`@("`@("`\
M<VEM<&QE+7!R;W!E<G1Y+6QI<W0@;F%M93TB9&5F875L=%9A;'5E(CX*("`@
M("`@("`@("`@("`@(#QV86QU92!T>7!E/2)C;VYS=&%N="(^04Q,/"]V86QU
M93X*("`@("`@("`@("`@/"]S:6UP;&4M<')O<&5R='DM;&ES=#X*("`@("`@
M("`@("`@/'!R;W!E<G1Y(&YA;64](G!A<F%M5'EP92(^<VEM<&QE/"]P<F]P
M97)T>3X*("`@("`@("`@("`@/'!R;W!E<G1Y(&YA;64](F-O;G1R;VQ4>7!E
M(CYL:7-T+6)O>#PO<')O<&5R='D^"B`@("`@("`@("`@(#QP<F]P97)T>2!N
M86UE/2)M=7-T36%T8V@B/G1R=64\+W!R;W!E<G1Y/@H@("`@("`@("`@("`\
M<')O<&5R='D@;F%M93TB9FEX961/<F1E<B(^=')U93PO<')O<&5R='D^"B`@
M("`@("`@("`@(#QS=')U8W1U<F4@;F%M93TB9F]R;6%T(CX*("`@("`@("`@
M("`@("`@(#QP<F]P97)T>2!N86UE/2)C871E9V]R>2(^56YF;W)M871T960\
M+W!R;W!E<G1Y/@H@("`@("`@("`@("`\+W-T<G5C='5R93X*("`@("`@("`\
M+W-C86QA<BUP87)A;65T97(^"B`@("`@("`@/'-C86QA<BUP87)A;65T97(@
M;F%M93TB3TQ$7U-0240B(&ED/2(R,#(B/@H@("`@("`@("`@("`\=&5X="UP
M<F]P97)T>2!N86UE/2)H96QP5&5X="(^3VQD(%-E<G9I8V4@4')O=FED97(@
M240\+W1E>'0M<')O<&5R='D^"B`@("`@("`@("`@(#QT97AT+7!R;W!E<G1Y
M(&YA;64](G!R;VUP=%1E>'0B/D]L9"!34#PO=&5X="UP<F]P97)T>3X*("`@
M("`@("`@("`@/'!R;W!E<G1Y(&YA;64](G9A;'5E5'EP92(^9'EN86UI8SPO
M<')O<&5R='D^"B`@("`@("`@("`@(#QP<F]P97)T>2!N86UE/2)I<U)E<75I
M<F5D(CYT<G5E/"]P<F]P97)T>3X*("`@("`@("`@("`@/'!R;W!E<G1Y(&YA
M;64](F1A=&%3971.86UE(CY$4U]34$E$7TQ)4U0\+W!R;W!E<G1Y/@H@("`@
M("`@("`@("`\97AP<F5S<VEO;B!N86UE/2)V86QU945X<'(B('1Y<&4](FIA
M=F%S8W)I<'0B/F1A=&%39712;W=;(E-0240B73PO97AP<F5S<VEO;CX*("`@
M("`@("`@("`@/&5X<')E<W-I;VX@;F%M93TB;&%B96Q%>'!R(B!T>7!E/2)J
M879A<V-R:7!T(CYD871A4V5T4F]W6R)34$E$(ET\+V5X<')E<W-I;VX^"B`@
M("`@("`@("`@(#QP<F]P97)T>2!N86UE/2)D871A5'EP92(^<W1R:6YG/"]P
M<F]P97)T>3X*("`@("`@("`@("`@/'!R;W!E<G1Y(&YA;64](F1I<W1I;F-T
M(CYT<G5E/"]P<F]P97)T>3X*("`@("`@("`@("`@/'-I;7!L92UP<F]P97)T
M>2UL:7-T(&YA;64](F1E9F%U;'1686QU92(^"B`@("`@("`@("`@("`@("`\
M=F%L=64@='EP93TB8V]N<W1A;G0B/D%,3#PO=F%L=64^"B`@("`@("`@("`@
M(#PO<VEM<&QE+7!R;W!E<G1Y+6QI<W0^"B`@("`@("`@("`@(#QP<F]P97)T
M>2!N86UE/2)P87)A;51Y<&4B/G-I;7!L93PO<')O<&5R='D^"B`@("`@("`@
M("`@(#QP<F]P97)T>2!N86UE/2)C;VYT<F]L5'EP92(^;&ES="UB;W@\+W!R
M;W!E<G1Y/@H@("`@("`@("`@("`\<')O<&5R='D@;F%M93TB;75S=$UA=&-H
M(CYT<G5E/"]P<F]P97)T>3X*("`@("`@("`@("`@/'!R;W!E<G1Y(&YA;64]
M(F9I>&5D3W)D97(B/G1R=64\+W!R;W!E<G1Y/@H@("`@("`@("`@("`\<W1R
M=6-T=7)E(&YA;64](F9O<FUA="(^"B`@("`@("`@("`@("`@("`\<')O<&5R
M='D@;F%M93TB8V%T96=O<GDB/E5N9F]R;6%T=&5D/"]P<F]P97)T>3X*("`@
M("`@("`@("`@/"]S=')U8W1U<F4^"B`@("`@("`@/"]S8V%L87(M<&%R86UE
M=&5R/@H@("`@("`@(#QS8V%L87(M<&%R86UE=&5R(&YA;64](FUI;E]R;W=N
M=6TB(&ED/2(T,C<B(&5X=&5N9',](F-O;6UO;E]D8BYM:6Y?<F]W;G5M(B\^
M"B`@("`@("`@/'-C86QA<BUP87)A;65T97(@;F%M93TB;6%X7W)O=VYU;2(@
M:60](C0R."(@97AT96YD<STB8V]M;6]N7V1B+FUA>%]R;W=N=6TB+SX*("`@
M("`@("`\<V-A;&%R+7!A<F%M971E<B!N86UE/2)33U)47T)9(B!I9#TB-#<Q
M(CX*("`@("`@("`@("`@/'!R;W!E<G1Y(&YA;64](FAI9&1E;B(^9F%L<V4\
M+W!R;W!E<G1Y/@H@("`@("`@("`@("`\=&5X="UP<F]P97)T>2!N86UE/2)H
M96QP5&5X="(^4V]R="!B>2!&:65L9#PO=&5X="UP<F]P97)T>3X*("`@("`@
M("`@("`@/'1E>'0M<')O<&5R='D@;F%M93TB<')O;7!T5&5X="(^4V]R=#PO
M=&5X="UP<F]P97)T>3X*("`@("`@("`@("`@/'!R;W!E<G1Y(&YA;64](G9A
M;'5E5'EP92(^<W1A=&EC/"]P<F]P97)T>3X*("`@("`@("`@("`@/'!R;W!E
M<G1Y(&YA;64](F1A=&%4>7!E(CYS=')I;F<\+W!R;W!E<G1Y/@H@("`@("`@
M("`@("`\<')O<&5R='D@;F%M93TB9&ES=&EN8W0B/G1R=64\+W!R;W!E<G1Y
M/@H@("`@("`@("`@("`\<VEM<&QE+7!R;W!E<G1Y+6QI<W0@;F%M93TB9&5F
M875L=%9A;'5E(CX*("`@("`@("`@("`@("`@(#QV86QU92!T>7!E/2)C;VYS
M=&%N="(^5$X\+W9A;'5E/@H@("`@("`@("`@("`\+W-I;7!L92UP<F]P97)T
M>2UL:7-T/@H@("`@("`@("`@("`\;&ES="UP<F]P97)T>2!N86UE/2)S96QE
M8W1I;VY,:7-T(CX*("`@("`@("`@("`@("`@(#QS=')U8W1U<F4^"B`@("`@
M("`@("`@("`@("`@("`@/'!R;W!E<G1Y(&YA;64](G9A;'5E(CY43CPO<')O
M<&5R='D^"B`@("`@("`@("`@("`@("`@("`@/'!R;W!E<G1Y(&YA;64](FQA
M8F5L(CY43CPO<')O<&5R='D^"B`@("`@("`@("`@("`@("`\+W-T<G5C='5R
M("`@("`@/'!R;W!E<G1Y(&YA;64](G9A;'5E(CY35E])1#PO<')O<&5R='D^
M"B`@("`@("`@("`@("`@("`@("`@/'!R;W!E<G1Y(&YA;64](FQA8F5L(CY3
M5BU)1#PO<')O<&5R='D^"B`@("`@("`@("`@("`@("`\+W-T<G5C='5R93X*
M("`@("`@("`@("`@/"]L:7-T+7!R;W!E<G1Y/@H@("`@("`@("`@("`\<')O
M<&5R='D@;F%M93TB<&%R86U4>7!E(CYS:6UP;&4\+W!R;W!E<G1Y/@H@("`@
M("`@("`@("`\<')O<&5R='D@;F%M93TB8V]N=')O;%1Y<&4B/FQI<W0M8F]X
M/"]P<F]P97)T>3X*("`@("`@("`@("`@/'!R;W!E<G1Y(&YA;64](FUU<W1-
M871C:"(^=')U93PO<')O<&5R='D^"B`@("`@("`@("`@(#QP<F]P97)T>2!N
M86UE/2)F:7AE9$]R9&5R(CYT<G5E/"]P<F]P97)T>3X*("`@("`@("`@("`@
M/'-T<G5C='5R92!N86UE/2)F;W)M870B/@H@("`@("`@("`@("`@("`@/'!R
M;W!E<G1Y(&YA;64](F-A=&5G;W)Y(CY5;F9O<FUA='1E9#PO<')O<&5R='D^
M"B`@("`@("`@("`@(#PO<W1R=6-T=7)E/@H@("`@("`@(#PO<V-A;&%R+7!A
M<F%M971E<CX*("`@(#PO<&%R86UE=&5R<SX*("`@(#QD871A+7-O=7)C97,^
M"B`@("`@("`@/&]D82UD871A+7-O=7)C92!E>'1E;G-I;VY)1#TB;W)G+F5C
M;&EP<V4N8FER="YR97!O<G0N9&%T82YO9&$N:F1B8R(@;F%M93TB3$Y07T1A
M=&%3;W5R8V4B(&ED/2(T-S`B"B!E>'1E;F1S/2)C;VUM;VY?9&(N3$Y07T1A
M=&%3;W5R8V4B+SX*("`@(#PO9&%T82US;W5R8V5S/@H@("`@/&1A=&$M<V5T
M<SX*("`@("`@("`\;V1A+61A=&$M<V5T(&5X=&5N<VEO;DE$/2)O<F<N96-L
M:7!S92YB:7)T+G)E<&]R="YD871A+F]D82YJ9&)C+DID8F-396QE8W1$871A
M4V5T(B!N86UE/2)$4U]35E]354U-05)9(B!I9#TB,3`V(CX*("`@("`@("`@
M("`@/&QI<W0M<')O<&5R='D@;F%M93TB8V]L=6UN2&EN=',B/@H@("`@("`@
M("`@("`@("`@/'-T<G5C='5R93X*("`@("`@("`@("`@("`@("`@("`\<')O
M<&5R='D@;F%M93TB8V]L=6UN3F%M92(^4U9?240\+W!R;W!E<G1Y/@H@("`@
M("`@("`@("`@("`@("`@(#QT97AT+7!R;W!E<G1Y(&YA;64](F1I<W!L87E.
M86UE(CY35E])1#PO=&5X="UP<F]P97)T>3X*("`@("`@("`@("`@("`@(#PO
M<W1R=6-T=7)E/@H@("`@("`@("`@("`@("`@/'-T<G5C='5R93X*("`@("`@
M("`@("`@("`@("`@("`\<')O<&5R='D@;F%M93TB8V]L=6UN3F%M92(^5$X\
M+W!R;W!E<G1Y/@H@("`@("`@("`@("`@("`@("`@(#QT97AT+7!R;W!E<G1Y
M(&YA;64](F1I<W!L87E.86UE(CY43CPO=&5X="UP<F]P97)T>3X*("`@("`@
M("`@("`@("`@(#PO<W1R=6-T=7)E/@H@("`@("`@("`@("`@("`@/'-T<G5C
M='5R93X*("`@("`@("`@("`@("`@("`@("`\<')O<&5R='D@;F%M93TB8V]L
M=6UN3F%M92(^3D577T-54E)%3E1?4U!)1#PO<')O<&5R='D^"B`@("`@("`@
M("`@("`@("`@("`@/'1E>'0M<')O<&5R='D@;F%M93TB9&ES<&QA>4YA;64B
M/DY%5U]#55)214Y47U-0240\+W1E>'0M<')O<&5R='D^"B`@("`@("`@("`@
M("`@("`\+W-T<G5C='5R93X*("`@("`@("`@("`@("`@(#QS=')U8W1U<F4^
M"B`@("`@("`@("`@("`@("`@("`@/'!R;W!E<G1Y(&YA;64](F-O;'5M;DYA
M;64B/D],1%]34$E$/"]P<F]P97)T>3X*("`@("`@("`@("`@("`@("`@("`\
M=&5X="UP<F]P97)T>2!N86UE/2)D:7-P;&%Y3F%M92(^3TQ$7U-0240\+W1E
M>'0M<')O<&5R='D^"B`@("`@("`@("`@("`@("`\+W-T<G5C='5R93X*("`@
M("`@("`@("`@("`@(#QS=')U8W1U<F4^"B`@("`@("`@("`@("`@("`@("`@
M/'!R;W!E<G1Y(&YA;64](F-O;'5M;DYA;64B/DY%5U]34%]$545?1$%413PO
M<')O<&5R='D^"B`@("`@("`@("`@("`@("`@("`@/'1E>'0M<')O<&5R='D@
M;F%M93TB9&ES<&QA>4YA;64B/DY%5U]34%]$545?1$%413PO=&5X="UP<F]P
M97)T>3X*("`@("`@("`@("`@("`@(#PO<W1R=6-T=7)E/@H@("`@("`@("`@
M("`@("`@/'-T<G5C='5R93X*("`@("`@("`@("`@("`@("`@("`\<')O<&5R
M='D@;F%M93TB8V]L=6UN3F%M92(^3TQ$7U-07T1515]$051%/"]P<F]P97)T
M>3X*("`@("`@("`@("`@("`@("`@("`\=&5X="UP<F]P97)T>2!N86UE/2)D
M:7-P;&%Y3F%M92(^3TQ$7U-07T1515]$051%/"]T97AT+7!R;W!E<G1Y/@H@
M("`@("`@("`@("`@("`@/"]S=')U8W1U<F4^"B`@("`@("`@("`@("`@("`\
M<W1R=6-T=7)E/@H@("`@("`@("`@("`@("`@("`@(#QP<F]P97)T>2!N86UE
M/2)C;VQU;6Y.86UE(CY30TA%1%5,141?04-4259!5$5?1$%413PO<')O<&5R
M='D^"B`@("`@("`@("`@("`@("`@("`@/'1E>'0M<')O<&5R='D@;F%M93TB
M9&ES<&QA>4YA;64B/E-#2$5$54Q%1%]!0U1)5D%415]$051%/"]T97AT+7!R
M97)T>2!N86UE/2)C;VQU;6Y.86UE(CY$7U-405154SPO<')O<&5R='D^"B`@
M("`@("`@("`@("`@("`@("`@/'1E>'0M<')O<&5R='D@;F%M93TB9&ES<&QA
M>4YA;64B/D1?4U1!5%53/"]T97AT+7!R;W!E<G1Y/@H@("`@("`@("`@("`@
M("`@/"]S=')U8W1U<F4^"B`@("`@("`@("`@("`@("`\<W1R=6-T=7)E/@H@
M("`@("`@("`@("`@("`@("`@(#QP<F]P97)T>2!N86UE/2)C;VQU;6Y.86UE
M(CY$7U1)34527U194$4\+W!R;W!E<G1Y/@H@("`@("`@("`@("`@("`@("`@
M(#QT97AT+7!R;W!E<G1Y(&YA;64](F1I<W!L87E.86UE(CY$7U1)34527U19
M4$4\+W1E>'0M<')O<&5R='D^"B`@("`@("`@("`@("`@("`\+W-T<G5C='5R
M("`@("`@/'!R;W!E<G1Y(&YA;64](F-O;'5M;DYA;64B/E-67U-405154U]#
M2$%.1T5?0T%54T4\+W!R;W!E<G1Y/@H@("`@("`@("`@("`@("`@("`@(#QT
M97AT+7!R;W!E<G1Y(&YA;64](F1I<W!L87E.86UE(CY35E]35$%455-?0TA!
M3D=%7T-!55-%/"]T97AT+7!R;W!E<G1Y/@H@("`@("`@("`@("`@("`@/"]S
M=')U8W1U<F4^"B`@("`@("`@("`@("`@("`\<W1R=6-T=7)E/@H@("`@("`@
M("`@("`@("`@("`@(#QP<F]P97)T>2!N86UE/2)C;VQU;6Y.86UE(CY/4D1%
M4E].54T\+W!R;W!E<G1Y/@H@("`@("`@("`@("`@("`@("`@(#QT97AT+7!R
M;W!E<G1Y(&YA;64](F1I<W!L87E.86UE(CY/4D1%4E].54T\+W1E>'0M<')O
M<&5R='D^"B`@("`@("`@("`@("`@("`\+W-T<G5C='5R93X*("`@("`@("`@
M("`@("`@(#QS=')U8W1U<F4^"B`@("`@("`@("`@("`@("`@("`@/'!R;W!E
M<G1Y(&YA;64](F-O;'5M;DYA;64B/DY004-?04-4259!5$E/3E]44SPO<')O
M<&5R='D^"B`@("`@("`@("`@("`@("`@("`@/'1E>'0M<')O<&5R='D@;F%M
M93TB9&ES<&QA>4YA;64B/DY004-?04-4259!5$E/3E]44SPO=&5X="UP<F]P
M='D@;F%M93TB8V]L=6UN3F%M92(^4D5'24].7U!+/"]P<F]P97)T>3X*("`@
M("`@("`@("`@("`@("`@("`\=&5X="UP<F]P97)T>2!N86UE/2)D:7-P;&%Y
M3F%M92(^4D5'24].7U!+/"]T97AT+7!R;W!E<G1Y/@H@("`@("`@("`@("`@
M("`@/"]S=')U8W1U<F4^"B`@("`@("`@("`@(#PO;&ES="UP<F]P97)T>3X*
M("`@("`@("`@("`@/'-T<G5C='5R92!N86UE/2)C86-H961-971A1&%T82(^
M"B`@("`@("`@("`@("`@("`\;&ES="UP<F]P97)T>2!N86UE/2)R97-U;'13
M970B/@H@("`@("`@("`@("`@("`@("`@(#QS=')U8W1U<F4^"B`@("`@("`@
M("`@("`@("`@("`@("`@(#QP<F]P97)T>2!N86UE/2)P;W-I=&EO;B(^,3PO
M<')O<&5R='D^"B`@("`@("`@("`@("`@("`@("`@("`@(#QP<F]P97)T>2!N
M86UE/2)N86UE(CY35E])1#PO<')O<&5R='D^"B`@("`@("`@("`@("`@("`@
M("`@("`@(#QP<F]P97)T>2!N86UE/2)D871A5'EP92(^9&5C:6UA;#PO<')O
M<&5R='D^"B`@("`@("`@("`@("`@("`@("`@/"]S=')U8W1U<F4^"B`@("`@
M("`@("`@/'!R;W!E<G1Y(&YA;64](G!O<VET:6]N(CXR/"]P<F]P97)T>3X*
M("`@("`@("`@("`@("`@("`@("`@("`@/'!R;W!E<G1Y(&YA;64](FYA;64B
M/E1./"]P<F]P97)T>3X*("`@("`@("`@("`@("`@("`@("`@("`@/'!R;W!E
M("`@("`@("`@("`@(#PO<W1R=6-T=7)E/@H@("`@("`@("`@("`@("`@("`@
M(#QS=')U8W1U<F4^"B`@("`@("`@("`@("`@("`@("`@("`@(#QP<F]P97)T
M>2!N86UE/2)P;W-I=&EO;B(^,SPO<')O<&5R='D^"B`@("`@("`@("`@("`@
M("`@("`@("`@(#QP<F]P97)T>2!N86UE/2)N86UE(CY.15=?0U524D5.5%]3
M4$E$/"]P<F]P97)T>3X*("`@("`@("`@("`@("`@("`@("`@("`@/'!R;W!E
M>2!N86UE/2)P;W-I=&EO;B(^-#PO<')O<&5R='D^"B`@("`@("`@("`@("`@
M("`@("`@("`@(#QP<F]P97)T>2!N86UE/2)N86UE(CY/3$1?4U!)1#PO<')O
M<&5R='D^"B`@("`@("`@("`@("`@("`@("`@("`@(#QP<F]P97)T>2!N86UE
M/2)D871A5'EP92(^<W1R:6YG/"]P<F]P97)T>3X*("`@("`@("`@("`@("`@
M("`@("`\+W-T<G5C='5R93X*("`@("`@("`@("`@("`@("`@("`\<W1R=6-T
M=7)E/@H@("`@("`@("`@("`@("`@("`@("`@("`\<')O<&5R='D@;F%M93TB
M<&]S:71I;VXB/C4\+W!R;W!E<G1Y/@H@("`@("`@("`@("`@("`@("`@("`@
M("`\<')O<&5R='D@;F%M93TB;F%M92(^3D577U-07T1515]$051%/"]P<F]P
M97)T>3X*("`@("`@("`@("`@("`@("`@("`@("`@/'!R;W!E<G1Y(&YA;64]
M(F1A=&%4>7!E(CYD871E+71I;64\+W!R;W!E<G1Y/@H@("`@("`@("`@("`@
M("`@("`@(#PO<W1R=6-T=7)E/@H@("`@("`@("`@("`@("`@("`@(#QS=')U
M8W1U<F4^"B`@("`@("`@("`@("`@("`@("`@("`@(#QP<F]P97)T>2!N86UE
M/2)P;W-I=&EO;B(^-CPO<')O<&5R='D^"B`@("`@("`@("`@("`@("`@("`@
M("`@(#QP<F]P97)T>2!N86UE/2)N86UE(CY/3$1?4U!?1%5%7T1!5$4\+W!R
M;W!E<G1Y/@H@("`@("`@("`@("`@("`@("`@("`@("`\<')O<&5R='D@;F%M
M93TB9&%T851Y<&4B/F1A=&4M=&EM93PO<')O<&5R='D^"B`@("`@("`@("`@
M("`@("`@("`@/"]S=')U8W1U<F4^"B`@("`@("`@("`@("`@("`@("`@/'-T
M<G5C='5R93X*("`@("`@("`@("`@("`@("`@("`@("`@/'!R;W!E<G1Y(&YA
M;64](G!O<VET:6]N(CXW/"]P<F]P97)T>3X*("`@("`@("`@("`@("`@("`@
M("`@("`@/'!R;W!E<G1Y(&YA;64](FYA;64B/E-#2$5$54Q%1%]!0U1)5D%4
M15]$051%/"]P<F]P97)T>3X*("`@("`@("`@("`@("`@("`@("`@("`@/'!R
M;W!E<G1Y(&YA;64](F1A=&%4>7!E(CYD871E+71I;64\+W!R;W!E<G1Y/@H@
M("`@("`@("`@("`@("`@("`@(#PO<W1R=6-T=7)E/@H@("`@("`@("`@("`@
M("`@("`@(#QS=')U8W1U<F4^"B`@("`@("`@("`@("`@("`@("`@("`@(#QP
M<F]P97)T>2!N86UE/2)P;W-I=&EO;B(^.#PO<')O<&5R='D^"B`@("`@("`@
M("`@("`@("`@("`@("`@(#QP<F]P97)T>2!N86UE/2)N86UE(CY$7U-40515
M4SPO<')O<&5R='D^"B`@("`@("`@("`@("`@("`@("`@("`@(#QP<F]P97)T
M>2!N86UE/2)D871A5'EP92(^<W1R:6YG/"]P<F]P97)T>3X*("`@("`@("`@
M("`@("`@("`@("`\+W-T<G5C='5R93X*("`@("`@("`@("`@("`@("`@("`\
M<W1R=6-T=7)E/@H@("`@("`@("`@("`@("`@("`@("`@("`\<')O<&5R='D@
M;F%M93TB<&]S:71I;VXB/CD\+W!R;W!E<G1Y/@H@("`@("`@("`@("`@("`@
M("`@("`@("`\<')O<&5R='D@;F%M93TB;F%M92(^1%]424U%4E]465!%/"]P
M<F]P97)T>3X*("`@("`@("`@("`@("`@("`@("`@("`@/'!R;W!E<G1Y(&YA
M;64](F1A=&%4>7!E(CYS=')I;F<\+W!R;W!E<G1Y/@H@("`@("`@("`@("`@
M/2)P;W-I=&EO;B(^,3`\+W!R;W!E<G1Y/@H@("`@("`@("`@("`@("`@("`@
M("`@("`\<')O<&5R='D@;F%M93TB;F%M92(^4U9?4U1!5%537T-(04Y'15]#
M055313PO<')O<&5R='D^"B`@("`@("`@("`@("`@("`@("`@("`@(#QP<F]P
M97)T>2!N86UE/2)D871A5'EP92(^9&5C:6UA;#PO<')O<&5R='D^"B`@("`@
M("`@("`@("`@("`@("`@/"]S=')U8W1U<F4^"B`@("`@("`@("`@("`@("`@
M("`@/'-T<G5C='5R93X*("`@("`@("`@("`@("`@("`@("`@("`@/'!R;W!E
M<G1Y(&YA;64](G!O<VET:6]N(CXQ,3PO<')O<&5R='D^"B`@("`@("`@("`@
M("`@("`@("`@("`@(#QP<F]P97)T>2!N86UE/2)N86UE(CY/4D1%4E].54T\
M+W!R;W!E<G1Y/@H@("`@("`@("`@("`@("`@("`@("`@("`\<')O<&5R='D@
M;F%M93TB9&%T851Y<&4B/G-T<FEN9SPO<')O<&5R='D^"B`@("`@("`@("`@
M;64](G!O<VET:6]N(CXQ,CPO<')O<&5R='D^"B`@("`@("`@("`@("`@("`@
M("`@("`@(#QP<F]P97)T>2!N86UE/2)N86UE(CY.4$%#7T%#5$E6051)3TY?
M5%,\+W!R;W!E<G1Y/@H@("`@("`@("`@("`@("`@("`@("`@("`\<')O<&5R
M='D@;F%M93TB9&%T851Y<&4B/F1A=&4M=&EM93PO<')O<&5R='D^"B`@("`@
M<G1Y(&YA;64](G!O<VET:6]N(CXQ,SPO<')O<&5R='D^"B`@("`@("`@("`@
M("`@("`@("`@("`@(#QP<F]P97)T>2!N86UE/2)N86UE(CY214=)3TY?4$L\
M;F%M93TB9&%T851Y<&4B/F1E8VEM86P\+W!R;W!E<G1Y/@H@("`@("`@("`@
M("`@("`@("`@(#PO<W1R=6-T=7)E/@H@("`@("`@("`@("`@("`@/"]L:7-T
M+7!R;W!E<G1Y/@H@("`@("`@("`@("`\+W-T<G5C='5R93X*("`@("`@("`@
M("`@/'!R;W!E<G1Y(&YA;64](G)O=T9E=&-H3&EM:70B/C`\+W!R;W!E<G1Y
M/@H@("`@("`@("`@("`\;65T:&]D(&YA;64](F)E9F]R94]P96XB/CPA6T-$
M051!6VEM<&]R=%!A8VMA9V4@*%!A8VMA9V5S+FIA=F$N;&%N9RD["FEM<&]R
M=%!A8VMA9V4@*%!A8VMA9V5S+FIA=F$N:6\I.PH*0FER=$QO9V=E<BYD96)U
M9R`H(E-6(%)E<&]R="!B>2!43B!286YG93H@8F5F;W)E3W!E;B(I.PH*=F%R
M(&-O;'5M;G,@/2`B(CL*8V]L=6UN<R`K/2`B(%-67TE$+"!43BP@;F5W7V-U
M<G)E;G1?<W!I9"P@;VQD7W-P:60L(&YE=U]S<%]D=65?9&%T92P@;VQD7W-P
M7V1U95]D871E+"(["F-O;'5M;G,@*ST@(B!S8VAE9'5L961?86-T:79A=&5?
M9&%T92P@<W1A='5S+"`B.PIC;VQU;6YS("L]("(@9&5C;V1E*%-6+E-40515
M4RPG,"<L)T-O;F9L:6-T)RPG,2<L)T%C=&EV92<L("<R)RPG4&5N9&EN9R<L
M("<S)RPG4V5N9&EN9R<L)S0G+"=&86EL960G+"`G-2<L)U!A<G1I86PM1F%I
M;&5D)RP@)S8G+"=$:7-C;VYN96-T+5!E;F1I;F<G+"`G-R<L)T]L9"<L("<X
M)RPG0V%N8V5L960G+"`G.2<L)T-A;F-E;"U096YD:6YG)RPG,3`G+"=5;F1E
M9FEN960G+"<Y.2<L)U9O:60G*2!$7U-405154RP@(CL*8V]L=6UN<R`K/2`B
M(&1E8V]D92`H<W9?875X+G1I;65R7W1Y<&4L("<P)RPG3&]N9R<L)S$G+"=3
M:&]R="<L)S(G+"=-961I=6TG*2!$7U1)34527U194$4L("(["F-O;'5M;G,@
M*ST@(B!35E]35$%455-?0TA!3D=%7T-!55-%+"!O<F1E<E]N=6TL($Y004-?
M04-4259!5$E/3E]44RP@4D5'24].7U!+("(["@IV87(@9&5F875L=%%U97)Y
M(#T@(E-%3$5#5"`O*BL@1DE24U1?4D]74R!/4D1%4D5$(%5315].3"AS=E]G
M='0I($E.1$58*'-V+$E87U-67U1.*2`J+R!23U=?3E5-0D52*"D@3U9%4B`H
M($]21$52($)9(%1.("D@<E]N=6TL("(@*R`@8V]L=6UN<R`K("(@9G)O;2!3
M5BP@4U9?0558('=H97)E(%-6+E-67U!+(#T@4U9?0558+E-67U!+("(["0IV
M87(@=VAE<F5#;&%U<V4@/2`B(CL*"G9A<B!O<F1E<D)Y(#T@(B(["FEF("@@
M<&%R86US6R)33U)47T)9(ET@/3T@(E1.(B`I('L*"6]R9&5R0GD@/2`B($]2
M1$52($)9(%1.(CL*?0IE;'-E(&EF("AP87)A;7-;(E-/4E1?0EDB72`]/2`B
M4U9?240B*2!["@EO<F1E<D)Y(#T@(B!/4D1%4B!"62!35E])1"(["GT*"G9A
M<B!T;E)A;F=E(#T@<&%R86US6R)43E]204Y'12)=+G9A;'5E.PIV87(@;&5N
M(#T@=&Y286YG92YL96YG=&@H*3L*"FEF("@@*&QE;B`]/2`S*2!\?"`H(&QE
M;B`^(#,@)F%M<#LF86UP.R!L96X@/"`Q,"`I("D@>PH)=VAE<F5#;&%U<V4@
M/2`B($%.1"!43B!L:6ME("<B("L@=&Y286YG92`K("(E)R`B.PI]"F5L<V4@
M:68@*"!L96X@/3T@,3`@*2R(@*R!T;E)A;F=E("L@(B<B.PI]"F5L<V4@:68@*"!L96X@/3T@,34@*2S
M=')I;F<H,"PQ,"D@*R`B)R`B.PH)=VAE<F5#;&%U<V4@*ST@(B!!3D0@5$X@
M/#T@)R(@*R!T;E)A;F=E+G-U8G-T<FEN9R@P+#8I.PH)=VAE<F5#;&%U<V4@
M*ST@=&Y286YG92YS=6)S=')I;F<H,3$L,34I("L@(B<@(CL*?0H*+R\@4U8@
M4W1A='5S(&-R:71E<FEA"G9A<B!P87)M8V]U;G0@/2!P87)A;7-;(E-67U-4
M05154R)=+G9A;'5E+FQE;F=T:#L*=F%R('-T871U<T-L875S92`]("(B.PH*
M:68@*"!P87)M8V]U;G0@/B`P("9A;7`[)F%M<#L@*'!A<F%M<ULB4U9?4U1!
M5%53(ETN=F%L=64I6S!=("$]("TQ("D@>PH)<W1A='5S0VQA=7-E(#T@(B!!
M3D0@4W1A='5S(&EN("@@(CL*?0IE;'-E('L*"7!A<FUC;W5N="`](#`["GT*
M"F9O<B`H(&D],#L@:2`\('!A<FUC;W5N=#L@:2LK("E["@EI9B@@:2`]/2`P
M("E["@D)<W1A='5S0VQA=7-E(#T@<W1A='5S0VQA=7-E("L@<&%R86US6R)3
M5E]35$%455,B72YV86QU95MI73L*"7T@"@EE;'-E('L*"0ES=&%T=7-#;&%U
M<V4@/2!S=&%T=7-#;&%U<V4@*R`B("P@(B`K('!A<F%M<ULB4U9?4U1!5%53
M(ETN=F%L=65;:5T[(`H)?0I]"@II9B`H('!A<FUC;W5N="`^(#`@*7L*"7=H
M97)E0VQA=7-E("L]('-T871U<T-L875S92`K("(@*2`B.PI]"@HO+R!.97<@
M4U!)1"!C<FET97)I80II9B`H('!A<F%M<ULB3D577U-0240B72YV86QU92`A
M/2`G04Q,)R`I('L*"7=H97)E0VQA=7-E("L]("(@04Y$($Y%5U]#55)214Y4
M7U-0240@24X@*"<B("L@<&%R86US6R).15=?4U!)1")=+G9A;'5E("L@(B<I
M("(["GT*+R\@3VQD(%-0240@8W)I=&5R:6$*:68@*"!P87)A;7-;(D],1%]3
M4$E$(ETN=F%L=64@(3T@)T%,3"<@*2!["@EW:&5R94-L875S92`K/2`B($%.
M1"!/3$1?4U!)1"!)3B`H)R(@*R!P87)A;7-;(D],1%]34$E$(ETN=F%L=64@
M*R`B)RD@(CL*?0H*:68@*"!P87)A;7-;(E!/4E1?5%E012)=+G9A;'5E("$]
M("TQ("D@>PH)=VAE<F5#;&%U<V4@*ST@(B!!3D0@3$Y07U194$4@/2`B("L@
M<&%R86US6R)03U)47U194$4B72YV86QU92`K("(@(CL*?0H*=&AI<RYQ=65R
M>51E>'0@/2!D969A=6QT475E<GD@*R!W:&5R94-L875S92`K("(@04Y$(')O
M=VYU;3P]("(@*R!N97AT("L@;W)D97)">2`["G1H:7,N<75E<GE497AT(#T@
M(G-E;&5C="`J(&9R;VT@*"(@*R`@=&AI<RYQ=65R>51E>'0@*R`B("D@=VAE
M<F4@<E]N=6T@/CTB("L@<')E=B`["@I":7)T3&]G9V5R+F1E8G5G("@B4U8@
M4F5P;W)T(&)Y(%1.(%)A;F=E.B!297!O<G0@475E<GD@+2`B("L@=&AI<RYQ
M=65R>51E>'0I.PI=73X\+VUE=&AO9#X*("`@("`@("`@("`@/'!R;W!E<G1Y
M(&YA;64](F1A=&%3;W5R8V4B/DQ.4%]$871A4V]U<F-E/"]P<F]P97)T>3X*
M("`@("`@("`@("`@/&QI<W0M<')O<&5R='D@;F%M93TB<F5S=6QT4V5T(CX*
M("`@("`@("`@("`@("`@(#QS=')U8W1U<F4^"B`@("`@("`@("`@("`@("`@
M("`@/'!R;W!E<G1Y(&YA;64](G!O<VET:6]N(CXQ/"]P<F]P97)T>3X*("`@
M("`@("`@("`@("`@("`@("`\<')O<&5R='D@;F%M93TB;F%M92(^4U9?240\
M+W!R;W!E<G1Y/@H@("`@("`@("`@("`@("`@("`@(#QP<F]P97)T>2!N86UE
M/2)N871I=F5.86UE(CY35E])1#PO<')O<&5R='D^"B`@("`@("`@("`@("`@
M("`@("`@/'!R;W!E<G1Y(&YA;64](F1A=&%4>7!E(CYD96-I;6%L/"]P<F]P
M97)T>3X*("`@("`@("`@("`@("`@("`@("`\<')O<&5R='D@;F%M93TB;F%T
M:79E1&%T851Y<&4B/C(\+W!R;W!E<G1Y/@H@("`@("`@("`@("`@("`@/"]S
M("`@("`@("`@("`@(#QP<F]P97)T>2!N86UE/2)P;W-I=&EO;B(^,CPO<')O
M<&5R='D^"B`@("`@("`@("`@("`@("`@("`@/'!R;W!E<G1Y(&YA;64](FYA
M;64B/E1./"]P<F]P97)T>3X*("`@("`@("`@("`@("`@("`@("`\<')O<&5R
M='D@;F%M93TB;F%T:79E3F%M92(^5$X\+W!R;W!E<G1Y/@H@("`@("`@("`@
M<F]P97)T>3X*("`@("`@("`@("`@("`@("`@("`\<')O<&5R='D@;F%M93TB
M;F%T:79E1&%T851Y<&4B/C$R/"]P<F]P97)T>3X*("`@("`@("`@("`@("`@
M("`@("`@("`@("`@("`@("`\<')O<&5R='D@;F%M93TB<&]S:71I;VXB/C,\
M/2)N86UE(CY.15=?0U524D5.5%]34$E$/"]P<F]P97)T>3X*("`@("`@("`@
M("`@("`@("`@("`\<')O<&5R='D@;F%M93TB;F%T:79E3F%M92(^3D577T-5
M4E)%3E1?4U!)1#PO<')O<&5R='D^"B`@("`@("`@("`@("`@("`@("`@/'!R
M;W!E<G1Y(&YA;64](F1A=&%4>7!E(CYS=')I;F<\+W!R;W!E<G1Y/@H@("`@
M("`@("`@("`@("`@("`@(#QP<F]P97)T>2!N86UE/2)N871I=F5$871A5'EP
M92(^,3(\+W!R;W!E<G1Y/@H@("`@("`@("`@("`@("`@/"]S=')U8W1U<F4^
M("`@(#QP<F]P97)T>2!N86UE/2)P;W-I=&EO;B(^-#PO<')O<&5R='D^"B`@
M("`@("`@("`@("`@("`@("`@/'!R;W!E<G1Y(&YA;64](FYA;64B/D],1%]3
M4$E$/"]P<F]P97)T>3X*("`@("`@("`@("`@("`@("`@("`\<')O<&5R='D@
M;F%M93TB;F%T:79E3F%M92(^3TQ$7U-0240\+W!R;W!E<G1Y/@H@("`@("`@
M("`@("`@("`@("`@(#QP<F]P97)T>2!N86UE/2)D871A5'EP92(^<W1R:6YG
M/"]P<F]P97)T>3X*("`@("`@("`@("`@("`@("`@("`\<')O<&5R='D@;F%M
M93TB;F%T:79E1&%T851Y<&4B/C$R/"]P<F]P97)T>3X*("`@("`@("`@("`@
M("`@(#PO<W1R=6-T=7)E/@H@("`@("`@("`@("`@("`@/'-T<G5C='5R93X*
M("`@("`@("`@("`@("`@("`@("`\<')O<&5R='D@;F%M93TB<&]S:71I;VXB
M/C4\+W!R;W!E<G1Y/@H@("`@("`@("`@("`@("`@("`@(#QP<F]P97)T>2!N
M86UE/2)N86UE(CY.15=?4U!?1%5%7T1!5$4\+W!R;W!E<G1Y/@H@("`@("`@
M("`@("`@("`@("`@(#QP<F]P97)T>2!N86UE/2)N871I=F5.86UE(CY.15=?
M4U!?1%5%7T1!5$4\+W!R;W!E<G1Y/@H@("`@("`@("`@("`@("`@("`@(#QP
M<F]P97)T>2!N86UE/2)D871A5'EP92(^9&%T92UT:6UE/"]P<F]P97)T>3X*
M("`@("`@("`@("`@("`@("`@("`\<')O<&5R='D@;F%M93TB;F%T:79E1&%T
M851Y<&4B/CDS/"]P<F]P97)T>3X*("`@("`@("`@("`@("`@(#PO<W1R=6-T
M=7)E/@H@("`@("`@("`@("`@("`@/'-T<G5C='5R93X*("`@("`@("`@("`@
M("`@("`@("`\<')O<&5R='D@;F%M93TB<&]S:71I;VXB/C8\+W!R;W!E<G1Y
M/@H@("`@("`@("`@("`@("`@("`@(#QP<F]P97)T>2!N86UE/2)N86UE(CY/
M3$1?4U!?1%5%7T1!5$4\+W!R;W!E<G1Y/@H@("`@("`@("`@("`@("`@("`@
M(#QP<F]P97)T>2!N86UE/2)N871I=F5.86UE(CY/3$1?4U!?1%5%7T1!5$4\
M/2)D871A5'EP92(^9&%T92UT:6UE/"]P<F]P97)T>3X*("`@("`@("`@("`@
M("`@("`@("`\<')O<&5R='D@;F%M93TB;F%T:79E1&%T851Y<&4B/CDS/"]P
M<F]P97)T>3X*("`@("`@("`@("`@("`@(#PO<W1R=6-T=7)E/@H@("`@("`@
M<&5R='D@;F%M93TB<&]S:71I;VXB/C<\+W!R;W!E<G1Y/@H@("`@("`@("`@
M("`@("`@("`@(#QP<F]P97)T>2!N86UE/2)N86UE(CY30TA%1%5,141?04-4
M259!5$5?1$%413PO<')O<&5R='D^"B`@("`@("`@("`@("`@("`@("`@/'!R
M;W!E<G1Y(&YA;64](FYA=&EV94YA;64B/E-#2$5$54Q%1%]!0U1)5D%415]$
M051%/"]P<F]P97)T>3X*("`@("`@("`@("`@("`@("`@("`\<')O<&5R='D@
M;F%M93TB9&%T851Y<&4B/F1A=&4M=&EM93PO<')O<&5R='D^"B`@("`@("`@
M("`@("`@("`@("`@/'!R;W!E<G1Y(&YA;64](FYA=&EV941A=&%4>7!E(CXY
M,SPO<')O<&5R='D^"B`@("`@("`@("`@("`@("`\+W-T<G5C='5R93X*("`@
M/'!R;W!E<G1Y(&YA;64](G!O<VET:6]N(CXX/"]P<F]P97)T>3X*("`@("`@
M("`@("`@("`@("`@("`\<')O<&5R='D@;F%M93TB;F%M92(^1%]35$%455,\
M/2)N871I=F5.86UE(CY$7U-405154SPO<')O<&5R='D^"B`@("`@("`@("`@
M("`@("`@("`@/'!R;W!E<G1Y(&YA;64](F1A=&%4>7!E(CYS=')I;F<\+W!R
M;W!E<G1Y/@H@("`@("`@("`@("`@("`@("`@(#QP<F]P97)T>2!N86UE/2)N
M871I=F5$871A5'EP92(^,3(\+W!R;W!E<G1Y/@H@("`@("`@("`@("`@("`@
M/"]S=')U8W1U<F4^"B`@("`@("`@("`@("`@("`\<W1R=6-T=7)E/@H@("`@
M("`@("`@("`@("`@("`@(#QP<F]P97)T>2!N86UE/2)P;W-I=&EO;B(^.3PO
M<')O<&5R='D^"B`@("`@("`@("`@("`@("`@("`@/'!R;W!E<G1Y(&YA;64]
M(FYA;64B/D1?5$E-15)?5%E013PO<')O<&5R='D^"B`@("`@("`@("`@("`@
M("`@("`@/'!R;W!E<G1Y(&YA;64](FYA=&EV94YA;64B/D1?5$E-15)?5%E0
M13PO<')O<&5R='D^"B`@("`@("`@("`@("`@("`@("`@/'!R;W!E<G1Y(&YA
M("`@("`@(#QP<F]P97)T>2!N86UE/2)N871I=F5$871A5'EP92(^,3(\+W!R
M97)T>2!N86UE/2)P;W-I=&EO;B(^,3`\+W!R;W!E<G1Y/@H@("`@("`@("`@
M("`@("`@("`@(#QP<F]P97)T>2!N86UE/2)N86UE(CY35E]35$%455-?0TA!
M3D=%7T-!55-%/"]P<F]P97)T>3X*("`@("`@("`@("`@("`@("`@("`\<')O
M<&5R='D@;F%M93TB;F%T:79E3F%M92(^4U9?4U1!5%537T-(04Y'15]#0553
M;64](F1A=&%4>7!E(CYD96-I;6%L/"]P<F]P97)T>3X*("`@("`@("`@("`@
M("`@("`@("`\<')O<&5R='D@;F%M93TB;F%T:79E1&%T851Y<&4B/C(\+W!R
M97)T>2!N86UE/2)P;W-I=&EO;B(^,3$\+W!R;W!E<G1Y/@H@("`@("`@("`@
M("`@("`@("`@(#QP<F]P97)T>2!N86UE/2)N86UE(CY/4D1%4E].54T\+W!R
M871I=F5.86UE(CY/4D1%4E].54T\+W!R;W!E<G1Y/@H@("`@("`@("`@("`@
M("`@("`@(#QP<F]P97)T>2!N86UE/2)D871A5'EP92(^<W1R:6YG/"]P<F]P
M:79E1&%T851
Current Time: Thu Jul 24 23:39:56 EDT 2025
Powered by FUDForum. Page generated in 0.21213 seconds
