Home » Modeling » M2T (model-to-text transformation) » Xpand integer Global Variable(How can i increase integer Variable)
Xpand integer Global Variable [message #1008135] Sun, 10 February 2013 14:42 Go to next message
How can i increase global integer value and keep this value on this variable ?
Re: Xpand integer Global Variable [message #1018183 is a reply to message #1008135] Wed, 13 March 2013 06:31 Go to previous message
It is not possible to influence the value of an Integer type global var. You could store a datastructure which holds a value of type integer as global var, and then set and get its value.
Or use the counter extensions from org::eclipse::xtend::util::stdlib::counter.
Previous Topic:[ACCELEO] Dynamic templates generator deployment
Next Topic:[Acceleo] UnresolvedReferenceException
Current Time: Thu Jul 24 21:47:54 EDT 2025
Powered by FUDForum. Page generated in 0.07452 seconds
