Home » Eclipse Projects » Eclipse Scout » Can I make table columns "un-hideable"?
Can I make table columns "un-hideable"? [message #1017773] Tue, 12 March 2013 10:06 Go to next message
Table columns have the "Displayable" property, which I can set to false to keep the user from showing the column using "right mouse click->organise columns".
I am looking for the opposite: I want to set a property that makes it impossible for the user to hide a column using "organise columns". Is this possible?
On a related note: It is possible to fix a column width by setting the ConfiguredFixedWidth property. Is it possible to lock a column position, so it can't be moved in the table?
On another related note: Is it possible to completely suppress the "organise columns" menu for specific tables?
Re: Can I make table columns "un-hideable"? [message #1018169 is a reply to message #1017773] Wed, 13 March 2013 05:52 Go to previous messageGo to next message
A column:
* Not Displayable => as if it was not there for the end user.
* Displayable => Can be set "Visible" or "Not Visible" (configured by the developer == initial State) or modified during runtime by the user. This configuration made by the user is persisted in the user preferences.
I do not know a mechanism that prevent from reorganizing a table.
The only possibilities I know concerns sorting: it is possible to disable sorting and to have sorting columns before and after the one defined by the user.
It might be possible to modify the menus proposed on table header (create your own table/column extending AbstracTable/AbstractColumn or with the "injection" mechanism) but I am not so sure.
Re: Can I make table columns "un-hideable"? [message #1018280 is a reply to message #1018169] Wed, 13 March 2013 10:55 Go to previous messageGo to next message
Thanks for your answer (even if it confirmed what I had suspected: I want something that can't easily be done Smile
Re: Can I make table columns "un-hideable"? [message #1018797 is a reply to message #1017773] Thu, 14 March 2013 09:38 Go to previous messageGo to next message
Hi Urs
The organize columns menu is added to the table in AbstractTable#execAddHeaderMenus. To suppress the menus, just override this method and make sure it does nothing.
This is also the point to add a custom OrganizeColumnsMenu with a custom OrganizeColumnsForm which is able to handle your "prevent hiding a column" property.
Re: Can I make table columns "un-hideable"? [message #1020432 is a reply to message #1018797] Mon, 18 March 2013 02:50 Go to previous messageGo to next message
Excellent, thank you. I'll have a look at this.
Re: Can I make table columns "un-hideable"? [message #1021130 is a reply to message #1020432] Tue, 19 March 2013 11:06 Go to previous messageGo to next message
After some playing, I've managed to solve all of my needs (except for fixing some columns so they can't be dragged to a different position).
In my client I've created the following classes:
org.eclipse.minicrm.client.ui.table.IForceVisible (to allow certain columns to be marked as non-hidable):
package org.eclipse.minicrm.client.ui.table;
public interface IForceVisible {
  public boolean getConfiguredForceVisible();
org.eclipse.minicrm.client.ui.table.ReducedMenuTable (a table with a reduced menu (simple reset menu only) and per-column menu for showing/hiding columns)
import org.eclipse.minicrm.client.ui.table.menus.CheckColumnMenu;
import org.eclipse.minicrm.client.ui.table.menus.ReducedResetColumnsMenu;
import org.eclipse.scout.commons.exception.ProcessingException;
import org.eclipse.scout.rt.client.ui.action.menu.IMenu;
import org.eclipse.scout.rt.client.ui.action.menu.MenuSeparator;
import org.eclipse.scout.rt.client.ui.basic.table.AbstractTable;
import org.eclipse.scout.rt.client.ui.basic.table.TableEvent;
import org.eclipse.scout.rt.client.ui.basic.table.columns.IColumn;
import org.eclipse.scout.rt.client.ui.basic.table.customizer.AddCustomColumnMenu;
import org.eclipse.scout.rt.client.ui.basic.table.customizer.ModifyCustomColumnMenu;
import org.eclipse.scout.rt.client.ui.basic.table.customizer.RemoveCustomColumnMenu;
public class ReducedMenuTable extends AbstractTable {
  protected void execAddHeaderMenus(TableEvent e) throws ProcessingException {
    if (getTableCustomizer() != null) {
      if (e.getPopupMenuCount() > 0) {
        e.addPopupMenu(new MenuSeparator());
      for (IMenu m : new IMenu[]{new AddCustomColumnMenu(this), new ModifyCustomColumnMenu(this), new RemoveCustomColumnMenu(this)}) {
        m.prepareAction();
        if (m.isVisible()) {
          e.addPopupMenu(m);
    //for (IMenu m : new IMenu[]{new ReducedResetColumnsMenu(this), new OrganizeColumnsMenu(this)}) {
    for (IMenu m : new IMenu[]{new ReducedResetColumnsMenu(this)}) {
      m.prepareAction();
        e.addPopupMenu(m);
    boolean separatorNeeded = false;
      separatorNeeded = true;
    for (IColumn c : getColumnSet().getAllColumnsInUserOrder()) {
      if (c.isDisplayable()) {
        if (separatorNeeded) {
        IMenu m = new CheckColumnMenu(this, c);
        m.prepareAction();
        m.setEnabled(true);
        e.addPopupMenu(m);
org.eclipse.minicrm.client.ui.table.menus.CheckColumnMenu (a menu class that creates a toggle menu for a column with the columns name and visibility)
package org.eclipse.minicrm.client.ui.table.menus;
import java.util.ArrayList;
import java.util.List;
import org.eclipse.minicrm.client.ui.table.IForceVisible;
import org.eclipse.minicrm.shared.Icons;
import org.eclipse.scout.commons.StringUtility;
import org.eclipse.scout.rt.client.ui.ClientUIPreferences;
import org.eclipse.scout.rt.client.ui.action.menu.AbstractMenu;
import org.eclipse.scout.rt.client.ui.basic.table.IHeaderCell;
import org.eclipse.scout.rt.client.ui.basic.table.ITable;
public class CheckColumnMenu extends AbstractMenu {
  private final ITable m_table;
  private final IColumn m_column;
  private boolean m_forceVisible = false;
  public CheckColumnMenu(ITable table, IColumn column) {
    super();
    m_table = table;
    m_column = column;
    setText(getConfiguredText());
    setSelected(isSelected());
    if (column instanceof IForceVisible) {
      IForceVisible fv = (IForceVisible) column;
      m_forceVisible = fv.getConfiguredForceVisible();
  protected String getConfiguredText() {
    String result = null;
    String tooltip = null;
    if (m_column != null) {
      IHeaderCell c = m_column.getHeaderCell();
      if (c != null) {
        result = c.getText();
        tooltip = c.getTooltipText();
        if (!StringUtility.isNullOrEmpty(tooltip)) {
          if (StringUtility.isNullOrEmpty(result)) {
            result = tooltip;
          else {
            result = result + " (" + tooltip + ")";
        result = "'" + m_column.getColumnId() + "'";
    return result;
  protected boolean getConfiguredToggleAction() {
    return true;
  public String getIconId() {
    return isSelected() ? Icons.Checked : Icons.Unchecked;
  public void setEnabled(boolean b) {
    if (m_forceVisible && isSelected()) {
      b = false;
    super.setEnabled(b);
  public boolean isSelected() {
    return m_column.isVisible();
  protected void execAction() throws ProcessingException {
    try {
      m_table.setTableChanging(true);
      boolean visible = m_column.isVisible();
      m_column.setVisible(!visible);
      m_table.getColumnSet().setVisibleColumns(getVisibleColumns());
      ClientUIPreferences.getInstance().setAllTableColumnPreferences(m_table);
    finally {
      m_table.setTableChanging(false);
  private IColumn[] getVisibleColumns() {
    List<IColumn> result = new ArrayList<IColumn>();
    if (m_table != null) {
      for (IColumn c : m_table.getColumnSet().getAllColumnsInUserOrder()) {
        if (c.isVisible()) {
          result.add(c);
    return result.toArray(new IColumn[result.size()]);
org.eclipse.minicrm.client.ui.table.menus.ReducedResetColumnsMenu (a single menu that resets all column properties)
import org.eclipse.scout.rt.client.ui.basic.table.columnfilter.ITableColumnFilterManager;
import org.eclipse.scout.rt.client.ui.basic.table.customizer.ITableCustomizer;
import org.eclipse.scout.rt.shared.ScoutTexts;
public class ReducedResetColumnsMenu extends AbstractMenu {
  public ReducedResetColumnsMenu(ITable table) {
    m_table = table;
    return ScoutTexts.get("ResetTableColumns");
    try {
      m_table.resetDisplayableColumns();
      ITableColumnFilterManager m = m_table.getColumnFilterManager();
      if (m != null) {
        m.reset();
      ITableCustomizer cst = m_table.getTableCustomizer();
      if (cst != null) {
        cst.removeAllColumns();
    finally {
I can now convert any menu from the standard Scout table menus to our "simplified" menu by making the table on my page/form extend ReducedMenuTable instead of AbstractTable. Any Column that may not be hidden by the user must not only extend AbstractXxxxColumn but also implement IForceVisibile and override
      public boolean getConfiguredForceVisible() {
        return true;
And this is what 11 lines of code changes can look like using the above four classes:
index.php/fa/13921/0/
Re: Can I make table columns "un-hideable"? [message #1034773 is a reply to message #1021130] Fri, 05 April 2013 17:56 Go to previous messageGo to next message
Hi Urs
I opened a change request Bug 405052 facing your request. Thank you for this request.
/andreas
Re: Can I make table columns "un-hideable"? [message #1036285 is a reply to message #1034773] Mon, 08 April 2013 03:23 Go to previous message
Previous Topic:Datefield in RAP client
Next Topic:Showing Tables without "cellspacing" between rows
Current Time: Wed Jul 23 14:54:26 EDT 2025
Powered by FUDForum. Page generated in 0.07368 seconds
