Home » Eclipse Projects » Eclipse 4 » Strange behaviour with contributed Handler(Handler called on startup and shutdown or not at all)
icon5.gif  Strange behaviour with contributed Handler [message #1017874] Tue, 12 March 2013 13:13 Go to next message
I managed to contribute some commands, handlers and MenuItems etc. to my host application as described here and here.
BTW: Thanks guys, you regularly save my day.
The head of my execute method looks like the following:
@Execute
@Inject
public void openAndProcessSequencerFile(IEclipseContext ctx,
	@Named(IServiceConstants.ACTIVE_SHELL) Shell shell,
	EModelService modelService,
	MApplication application){
 // some code here: opens a FileDialog
I've read somewhere that the @Inject isn't necessary when you have @Execute, because it's somehow included. But if it's there it seems, that this Handler is called on startup of my host application for every Handled*Item I have (two times for me, because I have one HandledMenuItem and one HandledToolItem for this Command). I know this because the FileDialog is opened twice. Afterwards those Handled*Items are deactivated (not enabled). Does @Inject do more than injecting?
If I remove the @Inject, this behaviour is gone and my MenuItem is enabled. But in turn, if I click it, nothing happens, not even an exception is thrown.
In addition it is called twice for every Handled*Item on shutdown of the application. 4 FileDialogs opening Evil or Very Mad
Any ideas on what is happening here?
I already tried to set the "enabled" property of the HandledMenuItem and HandledToolItem in my fragment to false, but that didn't help either.
I tried with and without a canExecute() method. Doesn't make any difference in both cases.
Here is my fragment.e4xmi (there are some more Commands and Handlers, but only one is implemented right now):
<?xml version="1.0" encoding="ASCII"?>
<fragment:ModelFragments xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:commands="http://www.eclipse.org/ui/2010/UIModel/application/commands" xmlns:fragment="http://www.eclipse.org/ui/2010/UIModel/fragment" xmlns:menu="http://www.eclipse.org/ui/2010/UIModel/application/ui/menu" xmi:id="_IQ5MMIsXEeKSObafD6BggQ">
  <fragments xsi:type="fragment:StringModelFragment" xmi:id="_Fp3wgIsgEeKSObafD6BggQ" featurename="commands" parentElementId="com.vknie.comma.app">
    <elements xsi:type="commands:Command" xmi:id="_Zu-dkIsgEeKSObafD6BggQ" elementId="com.vknie.comma.core.importFile.command.openSequencerFile" commandName="Import Sequencer File"/>
    <elements xsi:type="commands:Command" xmi:id="_S08_0IsiEeKSObafD6BggQ" elementId="com.vknie.comma.core.importFile.command.mergePieces" commandName="Merge Pieces"/>
    <elements xsi:type="commands:Command" xmi:id="_YvSQQIsiEeKSObafD6BggQ" elementId="com.vknie.comma.core.importFile.command.splitPiece" commandName="Split Piece"/>
  </fragments>
  <fragments xsi:type="fragment:StringModelFragment" xmi:id="_lW14kIsgEeKSObafD6BggQ" featurename="handlers" parentElementId="com.vknie.comma.app">
    <elements xsi:type="commands:Handler" xmi:id="_qAinkIsgEeKSObafD6BggQ" elementId="com.vknie.comma.core.importFile.handler.openSequencerFileHandler" contributionURI="bundleclass://com.vknie.comma.core.importFile/com.vknie.comma.core.importfile.handler.OpenSequencerFileHandler" command="_Zu-dkIsgEeKSObafD6BggQ"/>
    <elements xsi:type="commands:Handler" xmi:id="_h0GfsIsiEeKSObafD6BggQ" elementId="com.vknie.comma.core.importFile.handler.mergePieces" command="_S08_0IsiEeKSObafD6BggQ"/>
    <elements xsi:type="commands:Handler" xmi:id="_kxMi8IsiEeKSObafD6BggQ" elementId="com.vknie.comm.core.importFile.handler.splitPiece" command="_YvSQQIsiEeKSObafD6BggQ"/>
  </fragments>
  <fragments xsi:type="fragment:StringModelFragment" xmi:id="_8PY9oIsgEeKSObafD6BggQ" featurename="children" parentElementId="com.vknie.comma.app.menu.file">
    <elements xsi:type="menu:HandledMenuItem" xmi:id="_D6gPMIshEeKSObafD6BggQ" label="Import Sequencer File" command="_Zu-dkIsgEeKSObafD6BggQ"/>
  </fragments>
  <fragments xsi:type="fragment:StringModelFragment" xmi:id="_mnImUIshEeKSObafD6BggQ" featurename="children" parentElementId="com.vknie.comma.app.toolbar.mainToolbar">
    <elements xsi:type="menu:HandledToolItem" xmi:id="_0MtrMIshEeKSObafD6BggQ" label="Import Sequencer File" command="_Zu-dkIsgEeKSObafD6BggQ"/>
  </fragments>
</fragment:ModelFragments>
Re: Strange behaviour with contributed Handler [message #1018118 is a reply to message #1017874] Wed, 13 March 2013 03:37 Go to previous messageGo to next message
If you put @Inject on it the DI container calls is upon creation of the
handler instance (hence called twice on startup.) and whenever the
values in the context changes (hence on shutdown)
If it is not called upon clicking when you only have @Execute it means
one of the values you request is not available. Can you try putting
@Optional on the arguments an see which one of the those guys is NULL -
I know none of them should be but it helps tracking it down.
Tom
Am 12.03.13 18:13, schrieb Marina Knieling:
> http://www.vogella.com/articles/Eclipse4Modularity/article.html#contribute_fragment
> and
> http://www.bestsolution.at/en/download.php?cat=01_Services&file=Eclipse4Tutorial_WritingApplicationWithE4_BestSolution.pdf.
> @Execute
> @Inject
> application. 4 FileDialogs opening :evil:
> </fragments>
> </fragments>
> </fragments>
> </fragments>
Re: Strange behaviour with contributed Handler [message #1018161 is a reply to message #1018118] Wed, 13 March 2013 05:37 Go to previous message
What version of the platform are you on? If post Kepler M4 you should add the HandlerProcessingAddon to the addons.
Previous Topic:Prompting before closing Stopped working
Next Topic:subversive - Unable to read repository under Eclipse 4.2.2
Current Time: Wed Jul 23 05:44:51 EDT 2025
Powered by FUDForum. Page generated in 0.08511 seconds
