gwt designer doesn't work with gwt 2.5 [message #1015505] |
Thu, 28 February 2013 17:39  |
Brand-new install of everything and I still can't view any class in designer - getting the infamous 'ClassNotFoundException' when trying to open a file in designer.
java.lang.ClassNotFoundException: org.eclipse.wb.internal.core.editor.multi.DesignerEditor
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:513)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:429)
Specifically I installed (from scratch) the following:
- Eclipse Indigo SR2 on Windows 7 64-bit
- Then installed latest gwt and gpe from here dl.google.com/eclipse/plugin/3.7
- Then installed gwt designer from here dl.google.com/eclipse/inst/d2gwt/latest/3.7
At some point during designer install I got a warning that windows builder core was skipped because a later version has allready been installed.
Is GWT designer compatible with gwt 2.5 or do I need earlier gwt version?
Any help would be much appreciated.
FUDForum. Page generated in 0.07382 seconds
