import platform-resource to completeoclfile [message #1017213] |
Mon, 11 March 2013 04:05  |
I´m trying to create a CompleteOCL-file to validate a Profile that is applied on a uml-model. The profile is saved in a external uml-file so i have to import this file to the completeOCL-file, but eclipse says that this is an unresolved import:
"Unresolved import 'platform:/resource/Profile/Profile.uml' : Failed to load 'pivot:/platform/resource/Profile/Profile.uml' : Unnamed package"
This is my ocl-file:
import uml: 'http://www.eclipse.org/uml2/3.0.0/UML#/'
import signal: 'platform:/resource/Profile/Profile.uml'
context uml::Class
inv Defined:
let stereo: Stereotype= self.getAppliedStereotype('Profile::Protokoll') in not stereo.oclIsUndefined()implies (self.getValue(stereo,'ID').oclAsType(Integer) > 0
I´m running this file with a CompleteOCLEObjectValidator in standalone(but running it inside eclipse makes no difference) and when i tried to run this with the file above i get the error:
"0 [main] ERROR idation.CompleteOCLEObjectValidator - Failed to load 'file:/D:/PapyrusWorkspacee/standalone_validierer/src/profile.ocl
2: Unresolved import 'platform:/resource/Profile/Profile.uml' : The path '/Profile/Profile.uml' is unmapped"
Thats my validator:
CompleteOCLStandaloneSetup.doSetup();
OCLstdlib.install();
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put("uml", new XMIResourceFactoryImpl());
resourceSet.getPackageRegistry().put(SysmlPackage.eNS_URI, SysmlPackage.eINSTANCE);
resourceSet.getPackageRegistry().put(BlocksPackage.eNS_URI, BlocksPackage.eINSTANCE);
resourceSet.getPackageRegistry().put(UMLPackage.eNS_URI, UMLPackage.eINSTANCE);
resourceSet.getPackageRegistry().put(EcorePackage.eNS_URI, EcorePackage.eINSTANCE);
resourceSet.getPackageRegistry().put("pathmap://Papyrus.profile.uml",UMLPackage.eINSTANCE);
resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put(resourceSet.getResourceFactoryRegistry().DEFAULT_EXTENSION, new XMIResourceFactoryImpl());
URI uri = URI.createFileURI(args[0]);
URI ocluri = URI.createFileURI(args[1]);
EPackage.Registry.INSTANCE.put(args[0],UMLPackage.eINSTANCE);
Resource resource = resourceSet.createResource(uri);
try {
resource.load(null);
System.out.println("Model: load complete");
} catch (IOException e) {
e.printStackTrace();
Model m = (Model) EcoreUtil.getObjectByType(resource.getContents(), UMLPackage.Literals.MODEL);
if(m==null){
System.err.println("Model: load failed!");
System.exit(1);
CompleteOCLEObjectValidator val = new TestValidator(UMLPackage.eINSTANCE,ocluri);
EValidator.Registry.INSTANCE.put(UMLPackage.eINSTANCE,val);
EValidator.Registry.INSTANCE.put(SysmlPackage.eINSTANCE,val);
Diagnostic diag = Diagnostician.INSTANCE.validate(m);
System.out.println(diag.getMessage());
for(Diagnostic object : diag.getChildren()){
System.err.println(object.getMessage());
I´m using the KeplerM5-release..
What´s the problem with this import?
Is it necessary to do some special registrations in the java-file/the project containing it?
Basti
Re: import platform-resource to completeoclfile [message #1017594 is a reply to message #1017213] |
Tue, 12 March 2013 02:56   |
Getting UML registrations correct is extremely difficult and so I
contributed what became UMLResourcesUtil.init(). If you can do better
you are welcome to do so and then contribute it back to Eclipse.
Imperfections in UMLResourcesUtil.init() are addressed by a further
contribution exploiting a recent EMF enhancement that you may find in
https://bugs.eclipse.org/bugs/show_bug.cgi?id=401682.
Your code contains pathmap://Papyrus.profile.uml which is odd and has no
obvious resolution.
appears to suggest that wherever your profile is encountered, the UML
metamodel should be consulted for its resolution.
Ed Willink
On 11/03/2013 08:05, Ba sti wrote:
> Hello,
> context uml::Class
> inv Defined:
> (self.getValue(stereo,'ID').oclAsType(Integer) > 0 I´m running this
> Thats my validator:
> try {
> Model m = (Model)
> if(m==null){
> System.exit(1);
> What´s the problem with this import? Is it necessary to do some
> Regards,
> Basti
Re: import platform-resource to completeoclfile [message #1017662 is a reply to message #1017620] |
Tue, 12 March 2013 05:30  |
HI
As I wrote before:
I do not have time to debug everyone's code just because they think they
can do better than the solution I provided.
Until you provide a demonstrable example using the recommended approach,
I cannot help you further.
An unnamed package is one without a name and this may arise as a result
of a demand-created package when using inappropriate registrations.
My solution took me a long time to develop. You should expect to take an
equally long time to learn how to make your different/better solution work.
Ed Willink
On 12/03/2013 08:18, Ba sti wrote:
> yes there is a little problem with this pathmap, but its not such a
> big problem so this is ok.. the validator works fine..
> my problem is the completeOcl-file with this unresolved import
> I now have registerd my "platform:/resource/Profile/Profile.uml" in
> the EPackageRegistry and now there is no more error with the unmapped
> path while running the validator, but i still get the errormessage
> in the ocl-file at line 2. What´s the meaning of unnamed package and
> how can i resolve this import?
> Regards,
> Basti
FUDForum. Page generated in 0.08511 seconds
