Home » Modeling » TMF (Xtext) » Xtype: JvmTypeReference not working as wanted (validation, scope)
Xtype: JvmTypeReference not working as wanted (validation, scope) [message #1017027] Fri, 08 March 2013 12:04 Go to next message
I have my language:
https://wwwsecu.irit.fr/hg/SMAC/victor-noel-phd/may/may-xtext2/ (rev 6fbd57747647)
The language is described in fr.irit.smac.may.speadl and I use xtext 2.4.
An example of instance is:
namespace Test {
	ecosystem TestE1[X] {
		provides test: String = b.test3;
		requires test2: java.util.Map[X,String];
		part b: Test.TestE2 {
			bind test4 to b.test3;
			bind test4 to this.test;
	ecosystem TestE2[Y] {
		provides test3: String = this.test3
		requires test4: String
My problems are as follow:
1) I have elements of the language (the Ecosystem) that contains JvmParameterizedTypeReferences (in the Ports).
It seems the scope of the JvmArgumentTypeReference contained in the JvmParameterizedTypeReferences accepts both X and Y for the arguments of "requires test2: java.util.Map[X,String]".
Stranger, it seems content assist in that place shows me only Y and not X.
Obviously I would have though that X should only be proposed.
Did I miss something to enable that behaviour?
2) Isn't there any Validator to check that the number of argument of a JvmParameterizedTypeReferences is the correct one?
3) If I use the JvmModelInferer for my model, how should I say that an Ecosystem maps to a class with generic parameters? I started an extension of the JvmTypesBuilder (see AdvancedJvmTypeBuilder) but I'm not really sure this is the way to do it...
4) If I want to check that the type of a port referenced in a binding is the compatible with the type of the port it is bound to, how can I compute the actual type of the port. For example "bind test4 to this.test", test4 type should be using the types passed as arguments to b.
Thank you for any help
Re: Xtype: JvmTypeReference not working as wanted (validation, scope) [message #1017228 is a reply to message #1017027] Mon, 11 March 2013 04:59 Go to previous message
Any idea about that?
Thank you Smile
Previous Topic:Recursive imports in xtext
Next Topic:importURI and cross references during serialization
Current Time: Sun Jul 20 23:17:03 EDT 2025
Powered by FUDForum. Page generated in 0.04274 seconds
