Home » Archived » BIRT » Page Number and pageTotal problem
Page Number and pageTotal problem [message #1016569] Wed, 06 March 2013 18:29 Go to next message
in my report there is a table that takes,in ppt or pdf format, several pages; i would insert the number of pages in a simply format (<page> of <total>) but the value of pageNumber and pageTotal is always 1.
How can I fix this?
Re: Page Number and pageTotal problem [message #1016603 is a reply to message #1016569] Thu, 07 March 2013 01:12 Go to previous messageGo to next message
What is your BIRT version? Any way you can recreate your issue using the sample database, so I can see what your setup is? Thanks.
Re: Page Number and pageTotal problem [message #1016702 is a reply to message #1016603] Thu, 07 March 2013 07:26 Go to previous messageGo to next message
Hi Michael,
i attached file (modified) that you sent me for my other problem groups.
In the Header i put 3 ways in which i take the number of page and number of total page.
I use the latest version of birt viewer 4.2.2.
Thanks in advance for your help
[Updated on: Thu, 07 March 2013 07:27] by Moderator
Re: Page Number and pageTotal problem [message #1016893 is a reply to message #1016702] Fri, 08 March 2013 00:57 Go to previous messageGo to next message
I don't see anything having to do with pageNumbers in the attached report. Can you double check that you uploaded the correct one and let me know? Thanks!
Re: Page Number and pageTotal problem [message #1016934 is a reply to message #1016893] Fri, 08 March 2013 04:23 Go to previous messageGo to next message
Rolling Eyes OPS !! Rolling Eyes
I upload your old file, these are the correct files....sorry
Re: Page Number and pageTotal problem [message #1017085 is a reply to message #1016934] Fri, 08 March 2013 16:51 Go to previous messageGo to next message
If you put this in your text box, in the right column:
<value-of> pageNumber </value-of> / <value-of> totalPage </value-of>
Then, run it to the web viewer and export to pdf, it works correctly. When you deploy the viewer, this would simply be calling the report with the frameset mapping and format=pdf, in the URL, which uses the separate run and render tasks, which is necessary for this to work. If you use the API's to run your reports, you'd just use the separate tasks, rather than the runAndRender task. Hope this helps.
Re: Page Number and pageTotal problem [message #1017147 is a reply to message #1017085] Sat, 09 March 2013 16:41 Go to previous messageGo to next message
Hi Michael,
with frameset works, i use this url:
http://localhost:8082/birt4/frameset?__format=PDF&__report=.....
but i would use this url:
http://localhost:8082/birt4/run?__format=PDF&__report=.....
I tested my report with first kind of url, but the behavior of the layout is different, so for me it is very important to use the second type of url to not lose all the job done.
I did not understand if with the first type of url i get the same result and, if so, i have not understand how use it.
[Updated on: Sat, 09 March 2013 17:04] by Moderator
Re: Page Number and pageTotal problem [message #1017157 is a reply to message #1017147] Sat, 09 March 2013 23:50 Go to previous messageGo to next message
How is the layout different? If you're wanting the page number within the report layout, like that, you'll have to use the frameset way?
If you're ok with doing the page n of m in your masterpage header, rather than the table header, you can use the auto-text from the palette. This works in the non frameset pdf output.
Re: Page Number and pageTotal problem [message #1017180 is a reply to message #1017157] Sun, 10 March 2013 14:27 Go to previous messageGo to next message
Hi Michael,
the layout is different becouse i design complex structure in which i the height so that the layout came into a A4, with the "run" is ok but with the "frameset" my layout is on 2 pages.
Maybe I have to find an alternative way, like take the values ​​from masterpage for display in my header table.
Re: Page Number and pageTotal problem [message #1017182 is a reply to message #1017180] Sun, 10 March 2013 15:18 Go to previous messageGo to next message
And using the masterpage auto-text, which works, is not an option?
Re: Page Number and pageTotal problem [message #1017268 is a reply to message #1017182] Mon, 11 March 2013 08:00 Go to previous messageGo to next message
I can't use the header of the master page because the data <page of Page> must be present in the table header.
Re: Page Number and pageTotal problem [message #1017333 is a reply to message #1017268] Mon, 11 March 2013 11:55 Go to previous messageGo to next message
Without being able to use the masterpage and without using separate run and render tasks, you're probably not going to be able to achieve what you're wanting. You could compute the total pages to show correctly, if you know how many rows fit per page, but the current page number doesn't update, unless you're using separate run and render, it seems. I've tried several different ways to try to get something to work, with no luck. If I find something, I'll let you know.
Re: Page Number and pageTotal problem [message #1017377 is a reply to message #1017333] Mon, 11 March 2013 13:47 Go to previous messageGo to next message
Michael Williams wrote on Mon, 11 March 2013 11:55
Sorry Michael, but how could I use the <<separate run and render tasks>> ?
Re: Page Number and pageTotal problem [message #1017395 is a reply to message #1017377] Mon, 11 March 2013 14:34 Go to previous messageGo to next message
Sorry. By URL, that's using the frameset option. From java, there are separate tasks: Run, Render, and runAndRender.
Re: Page Number and pageTotal problem [message #1033672 is a reply to message #1017395] Thu, 04 April 2013 10:01 Go to previous messageGo to next message
Hi Michael,
i insert this element in one cell on my table header
<cell id="68">
   <auto-text name="totP" id="67">
      <property name="type">total-page</property>
   </auto-text>
</cell>
and, in another cell, i insert a text field with these scripts:
1) onrender
var pageN= reportContext.getPersistentGlobalVariable("pageN");
if (pageN==null){
	pageN=0;
pageN= (pageN*1)+1;
reportContext.setPersistentGlobalVariable("pageN",pageN.toString());
this.text=pageN;
2) onpagebreak
pageN= (pageN*1)+1;
this.text=pageN;
it's work, infact i see correctly the two values in each page.
But, as final step, i would concatenate this values, so i modify my script of onpagebreak in this way (the first 3 rows):
importPackage( Packages.org.eclipse.birt.report.model.api);
elementFactory = reportContext.getDesignHandle().getElementFactory()
var totp = reportContext.getDesignHandle().findElement("totP");
pageN= (pageN*1)+1;
this.text=pageN;
how can i get a value of totp AutoTextHandle element?
Thanks in advance
[Updated on: Thu, 04 April 2013 10:01] by Moderator
Re: Page Number and pageTotal problem in BIRT Layout [message #1405357 is a reply to message #1016569] Thu, 07 August 2014 03:03 Go to previous message
How to get Pagenumbers with total page count in BIRT Layout(Not in MasterPage). Example: Page 1 of 5, 2 of 5 etc.
I used the following snippet:
<viewtime-value-of>pageNumber</viewtime-value-of>of<viewtime-value-of>totalPage</viewtime-value-of>
But this is showing as follows:
1 of 1
2 of 2
3 of 3.
Plz suggest me how to proceed.
Thanks in Advance.
Previous Topic:How to fetch Font from IAutoText and set to IText Paragraph
Next Topic:How to print the same dynamic image on every page.
Current Time: Sat Jul 26 23:36:53 EDT 2025
Powered by FUDForum. Page generated in 0.05410 seconds
