Home » Archived » BIRT » Implementation of the zoom in a chart
Implementation of the zoom in a chart [message #1016368] Wed, 06 March 2013 04:20 Go to next message
Hello!
I am visualizing in a view (Eclipse, java, SWT) a BIRT Line Chart, amongst other things. Now I want to implement the zoom option. I have the rectangle of the selection but I am in a trouble to get the data that is in this rectangle(I have tried different things and I have search on internet for some days). Can someone guide me? Which are the steps that I should follow?
Thank you for your time!
Re: Implementation of the zoom in a chart [message #1016878 is a reply to message #1016368] Thu, 07 March 2013 21:20 Go to previous messageGo to next message
How are you implementing the rectangle. If you could post an example that we can run and look at we may be able to help.
Jason
Re: Implementation of the zoom in a chart [message #1016910 is a reply to message #1016878] Fri, 08 March 2013 03:05 Go to previous messageGo to next message
I have the rectangle that I have implemented in the listener of the ChartViewer and to be able to generate the Char I have an ArrayList of the dataset. In the listener I don´t know how can I access to the information of the dataset.
Listener listener = new Listener() {
   public void handleEvent(Event event) {
	switch (event.type) {
		case SWT.MouseDown:
			mouseDownXCoor = event.x;
			mouseDownYCoor = event.y;
			drag = true;
                        break;
		case SWT.MouseMove:
			if (drag) {
				mouseUpXCoor = event.x;
				mouseUpYCoor = event.y;
				lineChartViewer.redraw();
			break;
		case SWT.MouseUp:
			drag = false;
			break;
		case SWT.Paint:
			if (drag) {
			    GC gc = event.gc;
			    gc.setBackground(Display.getDefault().getSystemColor(SWT.COLOR_BLACK));
			    gc.setAlpha(128);
		  	    int minX = Math.min(mouseDownXCoor, mouseUpXCoor);
  			    int minY = Math.min(mouseDownYCoor, mouseUpYCoor);
                            int maxX = Math.max(mouseDownXCoor, mouseUpXCoor);
			    int maxY = Math.max(mouseDownYCoor, mouseUpYCoor);
			    int width = maxX - minX;
			    int height = maxY - minY;
			    gc.fillRectangle(minX, minY, width, height);
		        break;
lineChartViewer.addListener(SWT.MouseDown, listener);
lineChartViewer.addListener(SWT.MouseMove, listener);
lineChartViewer.addListener(SWT.MouseUp, listener);
lineChartViewer.addListener(SWT.Paint, listener);
This is the listener part where I create the rectangle. Thanks!!
[Updated on: Wed, 13 March 2013 05:50] by Moderator
Re: Implementation of the zoom in a chart [message #1017047 is a reply to message #1016910] Fri, 08 March 2013 13:32 Go to previous messageGo to next message
Have you looked at this thread:
Chart Zoom
Jason
Re: Implementation of the zoom in a chart [message #1018167 is a reply to message #1017047] Wed, 13 March 2013 05:49 Go to previous messageGo to next message
Hi Jason,
I have looked and your example I can't run it, but I think that it is not important. I have read Savitha's comment and I think that is interesting, but I have a problem: I have never worked with triggers. These days I have been trying to do something but I have no progress done.
I have try to add the Trigger to the lineSeries but then I don't know how I can continue. Here is my trigger example.
LineSeries ls = (LineSeries) LineSeriesImpl.create();
ls.getTriggers().add(TriggerImpl.create(TriggerCondition.ONMOUSEUP_LITERAL,
            			ActionImpl.create(ActionType.CALL_BACK_LITERAL,
            			CallBackValueImpl.create(String.valueOf(ls.getSeriesIdentifier())))
I am a little bit lost. Can someone help me explaining the steps or with an easy example?
Thanks.
Re: Implementation of the zoom in a chart [message #1027133 is a reply to message #1018167] Tue, 26 March 2013 11:36 Go to previous messageGo to next message
Has somebody an example how to work with Triggers?
Thanks!
Re: Implementation of the zoom in a chart [message #1027367 is a reply to message #1027133] Tue, 26 March 2013 18:33 Go to previous message
When you use that type of trigger the class needs to implement ICallBackNotifier and you need to set the update notifier for the device renderer like:
idr.setProperty( IDeviceRenderer.UPDATE_NOTIFIER, this );
Look at this example
package my.swt.live.viewer;
import org.eclipse.birt.chart.computation.DataPointHints;
import org.eclipse.birt.chart.device.ICallBackNotifier;
import org.eclipse.birt.chart.device.IDeviceRenderer;
import org.eclipse.birt.chart.event.StructureSource;
import org.eclipse.birt.chart.event.WrappedStructureSource;
import org.eclipse.birt.chart.exception.ChartException;
import org.eclipse.birt.chart.factory.GeneratedChartState;
import org.eclipse.birt.chart.factory.Generator;
import org.eclipse.birt.chart.model.Chart;
import org.eclipse.birt.chart.model.ChartWithAxes;
import org.eclipse.birt.chart.model.attribute.ActionType;
import org.eclipse.birt.chart.model.attribute.AxisType;
import org.eclipse.birt.chart.model.attribute.Bounds;
import org.eclipse.birt.chart.model.attribute.CallBackValue;
import org.eclipse.birt.chart.model.attribute.IntersectionType;
import org.eclipse.birt.chart.model.attribute.LineAttributes;
import org.eclipse.birt.chart.model.attribute.LineStyle;
import org.eclipse.birt.chart.model.attribute.Marker;
import org.eclipse.birt.chart.model.attribute.MarkerType;
import org.eclipse.birt.chart.model.attribute.Position;
import org.eclipse.birt.chart.model.attribute.RiserType;
import org.eclipse.birt.chart.model.attribute.TickStyle;
import org.eclipse.birt.chart.model.attribute.TriggerCondition;
import org.eclipse.birt.chart.model.attribute.impl.BoundsImpl;
import org.eclipse.birt.chart.model.attribute.impl.CallBackValueImpl;
import org.eclipse.birt.chart.model.attribute.impl.ColorDefinitionImpl;
import org.eclipse.birt.chart.model.component.Axis;
import org.eclipse.birt.chart.model.component.Series;
import org.eclipse.birt.chart.model.component.impl.SeriesImpl;
import org.eclipse.birt.chart.model.data.NumberDataSet;
import org.eclipse.birt.chart.model.data.SeriesDefinition;
import org.eclipse.birt.chart.model.data.TextDataSet;
import org.eclipse.birt.chart.model.data.impl.ActionImpl;
import org.eclipse.birt.chart.model.data.impl.NumberDataSetImpl;
import org.eclipse.birt.chart.model.data.impl.SeriesDefinitionImpl;
import org.eclipse.birt.chart.model.data.impl.TextDataSetImpl;
import org.eclipse.birt.chart.model.data.impl.TriggerImpl;
import org.eclipse.birt.chart.model.impl.ChartWithAxesImpl;
import org.eclipse.birt.chart.model.layout.Legend;
import org.eclipse.birt.chart.model.layout.Plot;
import org.eclipse.birt.chart.model.type.BarSeries;
import org.eclipse.birt.chart.model.type.LineSeries;
import org.eclipse.birt.chart.model.type.impl.BarSeriesImpl;
import org.eclipse.birt.chart.model.type.impl.LineSeriesImpl;
import org.eclipse.birt.chart.util.PluginSettings;
import org.eclipse.birt.core.framework.PlatformConfig;
import org.eclipse.swt.SWT;
import org.eclipse.swt.events.PaintEvent;
import org.eclipse.swt.events.PaintListener;
import org.eclipse.swt.graphics.GC;
import org.eclipse.swt.graphics.Image;
import org.eclipse.swt.graphics.Rectangle;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.MessageBox;
import org.eclipse.swt.widgets.Shell;
public class SwtLiveChartViewer extends Composite implements
PaintListener,
ICallBackNotifier
private boolean bNeedsGeneration = true;
private IDeviceRenderer idr = null;
private Chart cm = null;
private GeneratedChartState gcs = null;
public static SwtLiveChartViewer c3dViewer;
* Used in building the chart for the first time
private boolean bFirstPaint = true;
public Chart getDesignTimeModel( )
return cm;
public void regenerateChart( )
redraw( );
public Chart getRunTimeModel( )
return gcs.getChartModel( );
public void repaintChart( )
redraw( );
public Object peerInstance()
return this;
public void callback( Object event, Object source, CallBackValue value )
Object obj1 = ((DataPointHints)((WrappedStructureSource)source).getSource()).getBaseValue();
Object obj2 = ((DataPointHints)((WrappedStructureSource)source).getSource()).getOrthogonalValue().toString();
Object obj3 = ((DataPointHints)((WrappedStructureSource)source).getSource()).getSeriesValue();
double xval = ((DataPointHints)((WrappedStructureSource)source).getSource()).getLocation().getX();
double yval = ((DataPointHints)((WrappedStructureSource)source).getSource()).getLocation().getY();
StructureSource structuredSource = (StructureSource) source;
DataPointHints dph = (DataPointHints) structuredSource.getSource();
Object obj4 = ((DataPointHints)((WrappedStructureSource)source).getSource()).getSeriesValue();
MessageBox mb = new MessageBox ( this.getShell( ) );
mb.setMessage( xval + "," + yval);
mb.open( );
* execute application
* @param args
public static void main( String[] args )
Display display = Display.getDefault( );
Shell shell = new Shell( display );
shell.setSize( 600, 400 );
shell.setLayout( new GridLayout( ) );
c3dViewer = new SwtLiveChartViewer( shell, SWT.NO_BACKGROUND );
c3dViewer.setLayoutData( new GridData( GridData.FILL_BOTH ) );
c3dViewer.addPaintListener( c3dViewer );
shell.open( );
while ( !shell.isDisposed( ) )
if ( !display.readAndDispatch( ) )
display.sleep( );
display.dispose( );
* Constructor
SwtLiveChartViewer( Composite parent, int style )
super( parent, style );
PlatformConfig config = new PlatformConfig();
config.setProperty( "STANDALONE", "true" ); //$NON-NLS-1$//$NON-NLS-2$
final PluginSettings ps = PluginSettings.instance( config );
try
idr = ps.getDevice( "dv.SWT" );//$NON-NLS-1$
catch ( ChartException ex )
ex.printStackTrace( );
cm = createLiveChart( );
public static final Chart createLiveChart( )
ChartWithAxes cwaBar = ChartWithAxesImpl.create( );
//Plot
cwaBar.getBlock( ).setBackground( ColorDefinitionImpl.WHITE( ) );
Plot p = cwaBar.getPlot( );
p.getClientArea( ).setBackground( ColorDefinitionImpl.create( 255,
255,
225 ) );
//Legend
Legend lg = cwaBar.getLegend( );
LineAttributes lia = lg.getOutline( );
lg.getText( ).getFont( ).setSize( 16 );
lia.setStyle( LineStyle.SOLID_LITERAL );
lg.getInsets( ).setLeft( 10 );
lg.getInsets( ).setRight( 10 );
//Title
cwaBar.getTitle( )
.getLabel( )
.getCaption( )
.setValue( "Live Chart Demo" );//$NON-NLS-1$
//X-Axis
Axis xAxisPrimary = cwaBar.getPrimaryBaseAxes( )[0];
xAxisPrimary.setType( AxisType.TEXT_LITERAL );
xAxisPrimary.getOrigin( ).setType( IntersectionType.VALUE_LITERAL );
xAxisPrimary.getOrigin( ).setType( IntersectionType.MIN_LITERAL );
xAxisPrimary.getTitle( )
.getCaption( )
.setValue( "Category Text X-Axis" );//$NON-NLS-1$
xAxisPrimary.setTitlePosition( Position.BELOW_LITERAL );
xAxisPrimary.getLabel( ).getCaption( ).getFont( ).setRotation( 75 );
xAxisPrimary.setLabelPosition( Position.BELOW_LITERAL );
xAxisPrimary.getMajorGrid( ).setTickStyle( TickStyle.BELOW_LITERAL );
.getLineAttributes( )
.setStyle( LineStyle.DOTTED_LITERAL );
.setColor( ColorDefinitionImpl.create( 64, 64, 64 ) );
xAxisPrimary.getMajorGrid( ).getLineAttributes( ).setVisible( true );
//Y-Axis
Axis yAxisPrimary = cwaBar.getPrimaryOrthogonalAxis( xAxisPrimary );
yAxisPrimary.getLabel( ).getCaption( ).setValue( "Price Axis" );//$NON-NLS-1$
yAxisPrimary.getLabel( ).getCaption( ).getFont( ).setRotation( 37 );
yAxisPrimary.setLabelPosition( Position.LEFT_LITERAL );
yAxisPrimary.setTitlePosition( Position.LEFT_LITERAL );
yAxisPrimary.getTitle( ).getCaption( ).setValue( "Linear Value Y-Axis" );//$NON-NLS-1$
yAxisPrimary.setType( AxisType.LINEAR_LITERAL );
yAxisPrimary.getMajorGrid( ).setTickStyle( TickStyle.LEFT_LITERAL );
.setColor( ColorDefinitionImpl.RED( ) );
yAxisPrimary.getMajorGrid( ).getLineAttributes( ).setVisible( true );
//X-Series
Series seCategory = SeriesImpl.create( );
SeriesDefinition sdX = SeriesDefinitionImpl.create( );
xAxisPrimary.getSeriesDefinitions( ).add( sdX );
sdX.getSeries( ).add( seCategory );
//Y-Series (1)
BarSeries bs1 = (BarSeries) BarSeriesImpl.create( );
bs1.setSeriesIdentifier( "Unit Price" );//$NON-NLS-1$
bs1.setRiserOutline( null );
bs1.setRiser( RiserType.RECTANGLE_LITERAL );
//bs1.getTriggers( ).add(
// TriggerImpl.create( TriggerCondition.MOUSE_CLICK_LITERAL,
// ActionImpl.create( ActionType.TOGGLE_VISIBILITY_LITERAL, SeriesValueImpl.create("not used" ) ) ) );
//Trigger tr1 = TriggerImpl.create(TriggerCondition.ONMOUSEOVER_LITERAL,
// ActionImpl.create(ActionType.SHOW_TOOLTIP_LITERAL,
// TooltipValueImpl.create(200, null)));
bs1.getTriggers( ).add( TriggerImpl.create( TriggerCondition.ONMOUSEOVER_LITERAL,
ActionImpl.create( ActionType.CALL_BACK_LITERAL,
CallBackValueImpl.create( String.valueOf( bs1.getSeriesIdentifier( ) ) ) ) ) );
//bs1.getTriggers().add(tr1);
//Y-Series (2)
LineSeries ls1 = (LineSeries) LineSeriesImpl.create( );
ls1.setSeriesIdentifier( "Quantity" );//$NON-NLS-1$
ls1.getLineAttributes( ).setColor( ColorDefinitionImpl.GREEN( ) );
for ( int i = 0; i < ls1.getMarkers( ).size( ); i++ )
( (Marker) ls1.getMarkers( ).get( i ) ).setType( MarkerType.BOX_LITERAL );
ls1.setCurve( true );
SeriesDefinition sdY = SeriesDefinitionImpl.create( );
yAxisPrimary.getSeriesDefinitions( ).add( sdY );
sdY.getSeriesPalette( ).shift( -1 );
sdY.getSeries( ).add( bs1 );
sdY.getSeries( ).add( ls1 );
// Update data
updateDataSet( cwaBar );
return cwaBar;
static final void updateDataSet( ChartWithAxes cwaBar )
// Associate with Data Set
TextDataSet categoryValues = TextDataSetImpl.create( sa );
NumberDataSet seriesOneValues = NumberDataSetImpl.create( da1 );
NumberDataSet seriesTwoValues = NumberDataSetImpl.create( da2 );
// X-Axis
SeriesDefinition sdX = (SeriesDefinition) xAxisPrimary.getSeriesDefinitions( )
.get( 0 );
( (Series) sdX.getSeries( ).get( 0 ) ).setDataSet( categoryValues );
// Y-Axis
SeriesDefinition sdY = (SeriesDefinition) yAxisPrimary.getSeriesDefinitions( )
.get( 0 );
( (Series) sdY.getSeries( ).get( 0 ) ).setDataSet( seriesOneValues );
( (Series) sdY.getSeries( ).get( 1 ) ).setDataSet( seriesTwoValues );
//Live Date Set
private static final String[] sa = {
"One", "Two", "Three", "Four", "Five",//$NON-NLS-1$//$NON-NLS-2$//$NON-NLS-3$//$NON-NLS-4$//$NON-NLS-5$
"Six", "Seven", "Eight", "Nine", "Ten"};//$NON-NLS-1$//$NON-NLS-2$//$NON-NLS-3$//$NON-NLS-4$//$NON-NLS-5$
private static final double[] da1 = {
56.99,
352.95,
-201.95,
299.95,
-95.95,
25.45,
129.33,
-26.5,
43.5,
122
private static final double[] da2 = {
20, 35, 59, 105, 150, -37, -65, -99, -145, -185
public final void paintControl( PaintEvent e )
Rectangle d = this.getClientArea( );
Image imgChart = new Image( this.getDisplay( ), d );
GC gcImage = new GC( imgChart );
//Look at IDeviceRenderer.java for all properties
//like DPI_RESOLUTION
//FILE_IDENTIFIER
//FORMAT_IDENTIFIER
//UPDATE_NOTIFIER
idr.setProperty( IDeviceRenderer.GRAPHICS_CONTEXT, gcImage );
Bounds bo = BoundsImpl.create( 0, 0, d.width, d.height );
bo.scale( 72d / idr.getDisplayServer( ).getDpiResolution( ) );
Generator gr = Generator.instance( );
if ( bNeedsGeneration )
bNeedsGeneration = false;
try
gcs = gr.build( idr.getDisplayServer( ),
cm,
bo,
null,
null,
null );
catch ( ChartException ce )
ce.printStackTrace( );
if ( bFirstPaint )
bFirstPaint = false;
try
gr.render( idr, gcs );
GC gc = e.gc;
gc.drawImage( imgChart, d.x, d.y );
Previous Topic:The right and generic way to format numbers in all reports
Next Topic:Pagination, Run Task, Render Task, and Writing to Disk
Current Time: Sun Jul 20 23:58:32 EDT 2025
Powered by FUDForum. Page generated in 0.04605 seconds
