Home » Eclipse Projects » EclipseLink » Beginner's Problem / strange behavior(cannot seem to use MySQL)
Beginner's Problem / strange behavior [message #1016966] Fri, 08 March 2013 06:32 Go to next message
I am just switching from Hibernate to EclipseLink and am facing a strange problem.
Here's my persistence.xml:
<?xml version="1.0" encoding="UTF-8" ?>
<persistence xmlns:xsi="removed because i am not allowed to post links"
xsi:schemaLocation="removed because i am not allowed to post links"
version="2.0" xmlns="removed because i am not allowed to post links">
	<persistence-unit name="it-status" transaction-type="RESOURCE_LOCAL">
		<provider>org.eclipse.persistence.jpa.PersistenceProvider</provider>
		<exclude-unlisted-classes>false</exclude-unlisted-classes>
		<properties>
			<property name="javax.persistence.jdbc.driver" value="com.mysql.jdbc.Driver" />
			<property name="javax.persistence.jdbc.url" value="jdbc:mysql://localhost:3306/ampel" />
			<property name="javax.persistence.jdbc.user" value="ampel" />
			<property name="javax.persistence.jdbc.password" value="ampel" />
			<property name="eclipselink.jdbc.connections.initial" value="1" />
			<property name="eclipselink.jdbc.connections.min" value="16" />
			<property name="eclipselink.jdbc.connections.max" value="16" />
			<property name="eclipselink.logging.level" value="FINE" />
			<property name="eclipselink.logging.thread" value="false" />
			<property name="eclipselink.logging.session" value="false" />
			<property name="eclipselink.logging.exceptions" value="false" />
			<property name="eclipselink.logging.timestamp" value="false" />
		</properties>
	</persistence-unit>
</persistence>
However, it detects HSQLPlatform:
[EL Fine]: Detected database platform: org.eclipse.persistence.platform.database.HSQLPlatform
[EL Config]: Connection(6204974)--connecting(DatabaseLogin(
	platform=>HSQLPlatform
	user name=> "ampel"
	connector=>JNDIConnector datasource name=>null
[EL Config]: Connection(6015989)--Connected: jdbc:hsqldb:file:data/hsqldb/hsqldb
	User: SA
	Database: HSQL Database Engine  Version: 2.2.8
	Driver: HSQL Database Engine Driver  Version: 2.2.8
[EL Config]: Connection(11238785)--connecting(DatabaseLogin(
	user name=> "ampel"
[EL Config]: Connection(15159299)--Connected: jdbc:hsqldb:file:data/hsqldb/hsqldb
	User: SA
Even if i force the usage of the MySQL platform with , it still connects to a HSQL Database:
[EL Config]: Connection(22270740)--connecting(DatabaseLogin(
	platform=>MySQLPlatform
	user name=> "ampel"
[EL Config]: Connection(25635634)--Connected: jdbc:hsqldb:file:data/hsqldb/hsqldb
	User: SA
[EL Config]: Connection(19199473)--connecting(DatabaseLogin(
	user name=> "ampel"
[EL Config]: Connection(3869646)--Connected: jdbc:hsqldb:file:data/hsqldb/hsqldb
	User: SA
It also doesn't seem to care or even try to make a MySQL connection, so it doesn't matter if the mysql-connector jar is in WEB-INF/lib or not.
What's strange about this is that it correctly reads the user name from the persistence.xml, which means that the javax.persistence.jdbc.* properties are being read.
However, I get no Error/Warning whatsoever. It just doesn't even try to use MySQL.
I'm using this in a Vaadin application on TomEE 1.5.1 and I have been stuck here for three straight days now.
Does anyone have an idea what I am doing wrong?
Re: Beginner's Problem / strange behavior [message #1017042 is a reply to message #1016966] Fri, 08 March 2013 13:04 Go to previous messageGo to next message
This is strange. It looks as if the container is injecting a datasource into the EntityManager which would override the javax.persistence properties set. How are you obtaining your EntityManager and EntityManagerFactory in the application? Could there be a different persistence unit that is loaded by the container with these settings?
Best Regards,
Chris
Re: Beginner's Problem / strange behavior [message #1017045 is a reply to message #1017042] Fri, 08 March 2013 13:16 Go to previous messageGo to next message
I just let JPAcontainer handle everything:
JPAContainer<Problem> problemContainer = JPAContainerFactory.make(Problem.class, "it-status");
But I also tried this, and it doesn't make a difference:
EntityManagerFactory emf = Persistence.createEntityManagerFactory("it-status");
EntityManager em = emf.createEntityManager();
em.getTransaction().begin();
Problem p = new Problem();
p.setTitle("foo");
p.setDescription("bar");
em.persist(p);
em.getTransaction().commit();
Edit: Hibernate works just fine with the same persistence.xml and code. But I would really like to use Eclipselink because it is recommended over Hibernate by the Vaadin guys and others.
[Updated on: Fri, 08 March 2013 13:18] by Moderator
Re: Beginner's Problem / strange behavior [message #1019462 is a reply to message #1017045] Fri, 15 March 2013 14:39 Go to previous messageGo to next message
Does the [EL Config] logging showing EclipseLink connecting to HSQL occur when you first call createEntityManagerFactory and createEntityManager or is it occurring on initial app deployment?
Chris
Re: Beginner's Problem / strange behavior [message #1021093 is a reply to message #1019462] Tue, 19 March 2013 10:09 Go to previous messageGo to next message
What version of EclipseLink are you using? If you are using a very old version it may not support "javax.persistence.jdbc.url", try instead "eclipselink.jdbc.url".
Also ensure you don't have another old persistence.xml on your classpath, and are not setting the <datasource> element.
Re: Beginner's Problem / strange behavior [message #1039760 is a reply to message #1021093] Fri, 12 April 2013 10:49 Go to previous messageGo to next message
OK. So for testing this again, I have set up a vanilla Eclipse/Tomcat/Project/everything.
The [EL Config] logging does not occur on initial app deployment.
The first two [EL Config] lines in the log after I choose "Debug on Server" show this:
[EL Config]: Connection(11615255)--connecting(DatabaseLogin(
user name=> "ampel"
[EL Config]: Connection(580142)--Connected: jdbc:hsqldb:file:data/hsqldb/hsqldb
User: SA
Which means that is is correctly reading javax.persistence.jdbc.user from the persistence.xml, but still ignoring javax.persistence.jdbc.url from the very same file.
I am not setting the datasource element and I am using EclipseLink 2.4.1
[Updated on: Fri, 12 April 2013 10:56] by Moderator
Re: Beginner's Problem / strange behavior [message #1039892 is a reply to message #1039760] Fri, 12 April 2013 15:15 Go to previous message
If you set the logging level to FINEST, it will log what the property value is when it is set on the Session, which occurs in the deployment phase right before login, just after it reads and logs the javax.persistence.transactionType property. If it is not the value it should be, then something is injecting a property somehow or the wrong persistence.xml is being picked up - logging should also show where the persistence.xml being read in is located.
Previous Topic:em.merge() creates 2 insert statements
Next Topic:Nested classes in JSon and removing unnecessary levels
Current Time: Sat Jul 26 23:26:12 EDT 2025
Powered by FUDForum. Page generated in 0.08712 seconds
