Home » Modeling » Epsilon » Nodes with centred content don't work(Eugenia)
Nodes with centred content don't work [message #1016133] Tue, 05 March 2013 03:04 Go to next message
Dear all
I'm new to Eugenia, GMF , Epsilon. I want to learn eugenia so i found tutorials from official site and perform tutorials step by step. But when i came to "Nodes with centred content" tutorial and "Nodes with images defined at run-time" tutorial I could not perform these, always get error from Ecore2GMF.eol file. And cant find these practise on svn.
dont understand what i must do. Anyone can help me to understand these tutorials.
[Updated on: Tue, 05 March 2013 03:48] by Moderator
Re: Nodes with centred content don't work [message #1016665 is a reply to message #1016133] Thu, 07 March 2013 04:51 Go to previous messageGo to next message
Hi serhat,
We have quite a few example projects over here. Have you had a look at them?
http://dev.eclipse.org/svnroot/modeling/org.eclipse.epsilon/trunk/examples/
I've had a look and it seems we had a few mistakes in the "Nodes with centred content" tutorial, both in the metamodel and the ECore2GMF.eol polishing transformation. I've fixed these issues and created a new set of example projects for it, all starting with "org.eclipse.epsilon.eugenia.examples.centred". These should work fine if you import them all into your workspace.
As for the "Nodes with images defined at run-time" example, it should work fine. Could you tell us what kind of error are you getting?
Re: Nodes with centred content don't work [message #1016718 is a reply to message #1016665] Thu, 07 March 2013 08:21 Go to previous messageGo to next message
now i can check-out "Nodes with centred content" and it works fine thanks for help:).
But on http://dev.eclipse.org/svnroot/modeling/org.eclipse.epsilon/trunk/examples/
i can't find "Nodes with images defined at run-time". I think, i must create project
and follow documents step. If it works fine i must study this tutorial more and more Smile
because i can't success on this.
Re: Nodes with centred content don't work [message #1016808 is a reply to message #1016718] Thu, 07 March 2013 13:12 Go to previous messageGo to next message
We don't have example projects for that particular article, sorry! If you run into any more problems, drop us a line Smile.
Re: Nodes with centred content don't work [message #1016987 is a reply to message #1016808] Fri, 08 March 2013 08:39 Go to previous messageGo to next message
I can't understand "Nodes with images instead of shapes" tutorial.
Because i cant recognize where i must create classes e.x.
ComponentImagePathPropertyDescriptor ?
ComponentImagePathCellEditor ?
can anyone explain me this ?
or havu u got this case ?
Re: Nodes with centred content don't work [message #1017391 is a reply to message #1016987] Mon, 11 March 2013 14:23 Go to previous message
You'll need to create the class in the .diagram plugin. You don't need to modify the code generated by GMF at all: the generated code will attempt to use the custom class, producing a compile error that you will fix by writing the figure class yourself.
I remembered we did have an example for this article. It's referenced from the article itself:
http://eclipse.org/epsilon/examples/index.php?example=org.eclipse.epsilon.eugenia.examples.friends
Could you have a look at it?
Previous Topic:GMF with Epsilon vs MetaEdit+
Next Topic:Ecore model creation with EOL
Current Time: Fri Jul 25 22:49:56 EDT 2025
Powered by FUDForum. Page generated in 0.05144 seconds
