Home » Archived » BIRT » How to turn text in label or label for 90grad ?
How to turn text in label or label for 90grad ? [message #1005868] Tue, 29 January 2013 02:02 Go to next message
Hello!
I have a long text for a column title and 30pixels for width colomn for it
can I turn text or label for 90 grad,how?
and can I change place of right row agregation colomn in cross tab before date to make it a first colomn, how?
thank you
Elena
  • Attachment: vertical.JPG
    (Size: 34.06KB, Downloaded 554 times)
[Updated on: Tue, 29 January 2013 04:12] by Moderator
Re: How to turn text in label or label for 90grad ? [message #1006027 is a reply to message #1005868] Tue, 29 January 2013 10:28 Go to previous messageGo to next message
For rotating the text label, take a look at this plug-in from the BIRT Exchange Marketplace:
BIRT Exchange Marketplace - BIRT Controls Lib
For the aggregation column in crosstab, I'm not sure I'm totally understanding the issue. If you're talking about the total field, when you set it up in the grand total editor, there's an option for position that can be changed to make the aggregation column first. Let me know if you're talking about something else.
Re: How to turn text in label or label for 90grad ? [message #1006028 is a reply to message #1005868] Tue, 29 January 2013 10:28 Go to previous messageGo to next message
Re: How to turn text in label or label for 90grad ? [message #1016621 is a reply to message #1006028] Thu, 07 March 2013 02:51 Go to previous messageGo to next message
Thank you very much!
it is work good in html format (this RotatedText),
but there are no in xls format
what can we do to show them in xls format?
Elena
index.php/fa/13726/0/
  • Attachment: null cell.JPG
    (Size: 37.16KB, Downloaded 2700 times)
Re: How to turn text in label or label for 90grad ? [message #1016786 is a reply to message #1016621] Thu, 07 March 2013 11:56 Go to previous messageGo to next message
i need the same also for the other format (pdf, ppt, doc).
Is ok also for 4.2.2 version?
[Updated on: Thu, 07 March 2013 11:58] by Moderator
Re: How to turn text in label or label for 90grad ? [message #1016886 is a reply to message #1016786] Thu, 07 March 2013 23:53 Go to previous messageGo to next message
The rotated text item creates an image, I believe. The standard XLS emitter does not support images. This is probably why it doesn't work for you in XLS. If you try another XLS emitter, like this one: BIRT Exchange Marketplace - Spud Soft BIRT Excel Emitters, it might work for you, cause there is image support. You might give it a try. As far as the other outputs, it should at least work in pdf, but I don't see why the others wouldn't work, as well. The code for creating the rotated text element can be found in the BIRT source code. For 4.2.2, you might have to go get the source and build the plugin project yourself.
Re: How to turn text in label or label for 90grad ? [message #1016939 is a reply to message #1016886] Fri, 08 March 2013 04:38 Go to previous messageGo to next message
how to replace the old with the new emitter in my runtime birt?
How can i get the source code and build the plugin project?
[Updated on: Fri, 08 March 2013 04:44] by Moderator
Re: How to turn text in label or label for 90grad ? [message #1044992 is a reply to message #1016939] Fri, 19 April 2013 11:57 Go to previous messageGo to next message
Hi Elena,
what should I do to use the plugin for rotate text?
Thanks in advance
Re: How to turn text in label or label for 90grad ? [message #1416038 is a reply to message #1044992] Thu, 04 September 2014 03:58 Go to previous message
you need put jar file in the place, where other plugs are.
Previous Topic:Header is not repeating in table
Next Topic:Can I bring up two parameter screens?
Current Time: Wed Jul 23 14:15:24 EDT 2025
Powered by FUDForum. Page generated in 0.04007 seconds
