Home » Modeling » EMF » [CDO] Error creating repository in h2 DB(insert into cdo_package_units throws UnsuppoetedOperationException)
[CDO] Error creating repository in h2 DB [message #1016184] Tue, 05 March 2013 06:50 Go to next message
Hi all,
I am trying to reproduce the CDO/Embedded example as it would cover one of our use-cases: http://wiki.eclipse.org/CDO/Embedded
Things seem to start working well, but after creating a few tables in the H2 database the program stops with an UnsupportedOperationException on the sql statement:
INSERT INTO cdo_package_units VALUES (?, ?, ?, ?)
I included the console-output as an attachment, and also the java-source as I am using it, and a picture from dbVisualizer which shows a view of the tables that where already created before this exception ocurred. BTW: all the created tables are empty.
Can anybody point me where I am going wrong (I still consider myself a newby Wink)?
Thanks in advance.
Rui Rosado
Re: [CDO] Error creating repository in h2 DB [message #1016697 is a reply to message #1016184] Thu, 07 March 2013 06:30 Go to previous messageGo to next message
Am 07.03.2013 01:34, schrieb Rui Rosado:
> Hi all,
I *think* this problem can be caused if the org.eclipse.emf.ecore.xmi bundle is not properly deployed to the server. Can
you please check that?
I'm currently working on the problem that some databases don't support rollback of a series of DDL statements in case
one of them fails. Not sure if that's related.
Cheers
/Eike
http://www.esc-net.de
Re: [CDO] Error creating repository in h2 DB [message #1016715 is a reply to message #1016697] Thu, 07 March 2013 08:16 Go to previous message
Eike,
Thank you for your pointer!
Everything works fine now that all the tables were created.
Rui
Previous Topic:[CDO] CDORevisionImpl instance count
Next Topic:can't find org.eclipse.emf.edit.ui.EditorEntryPoint for GWT editor
Current Time: Fri Jul 25 22:25:24 EDT 2025
Powered by FUDForum. Page generated in 0.06611 seconds
