Home » Modeling » EMF » [CDO] Possible bug in CDORepositorySynchronizer?([CDO] Possible bug in CDORepositorySynchronizer?)
[CDO] Possible bug in CDORepositorySynchronizer? [message #1016564] |
Wed, 06 March 2013 17:50  |
First of all I want to make clear that I am just trying to figure out how the non GUI related peices of the Offline example from Eike's webcast works. I am fooling with standalone code which will be posted below. When I try to start a NodeType.Client type node a NullPointerException is repeatedly thrown.
The owner variable below is null and so a NullPointerException is thrown in the second line of the following method.
public void handleLockChangeInfo(CDOLockChangeInfo lockChangeInfo)
CDOLockOwner owner = lockChangeInfo.getLockOwner();
String durableLockingID = owner.getDurableLockingID();
CDOBranch viewedBranch = lockChangeInfo.getBranch();
So my question is, what could I leaving out that causes the lock owner to be null? Following is the code I am running in its entirety. It is standalone, just a main() and a couple of private methods. I did have to modify the NodeType.java in a couple of spots due to access issues (public instead of private method access).
Any ideas would be appreciated.
public class TestCDOOffline {
private static final String ROOT_PROPERTY = "node.manager.root";
OMPlatform.INSTANCE.setDebugging(true);
OMPlatform.INSTANCE.addTraceHandler(PrintTraceHandler.CONSOLE);
OMPlatform.INSTANCE.addLogHandler(PrintLogHandler.CONSOLE);
NodeManager nodeManager = createNodeManager();
Net4jUtil.prepareContainer(IPluginContainer.INSTANCE); // Prepare the
// Net4j kernel
TCPUtil.prepareContainer(IPluginContainer.INSTANCE); // Prepare the TCP
// support
JVMUtil.prepareContainer(IPluginContainer.INSTANCE); //ditto JVM support
CDONet4jServerUtil.prepareContainer(IPluginContainer.INSTANCE); //prepare the CDO server.
String normalRepositoryName = "normal-repository-1"; // server
String normalClient1 = "normal-client-1";
NodeType.NormalRepository repository = createNormalRepository(
normalRepositoryName, nodeManager);
Node normalRepository = nodeManager.createNode(repository);
Node normal1 = nodeManager.getNode(normalRepositoryName);
normal1.start();
NodeType.Client client1 = createClient(normalClient1,
nodeManager, "7778", normalRepositoryName);
nodeManager.createNode(client1);
Node c1 = nodeManager.getNode(normalClient1);
c1.start(); //THIS IS WHERE THE PROBLEM STARTS!
System.out.println("Everything is started!");
private static IStore createStore(Node node) {
final boolean AUDITING = true;
final boolean BRANCHING = true;
JdbcDataSource dataSource = new JdbcDataSource();
dataSource.setURL("jdbc:h2:" + node.getFolder() + "/db/repository");
IMappingStrategy mappingStrategy = CDODBUtil
.createHorizontalMappingStrategy(AUDITING, BRANCHING);
IDBAdapter dbAdapter = new H2Adapter();
IDBConnectionProvider dbConnectionProvider = DBUtil
.createConnectionProvider(dataSource);
return CDODBUtil.createStore(mappingStrategy, dbAdapter,
dbConnectionProvider);
private static Map<String, String> createProperties(String name) {
Map<String, String> props = new HashMap<String, String>();
props.put(IRepository.Props.OVERRIDE_UUID, name);
props.put(IRepository.Props.SUPPORTING_AUDITS, "true");
props.put(IRepository.Props.SUPPORTING_BRANCHES, "true");
return props;
public static NodeManager createNodeManager() {
File f = new File(ROOT_PROPERTY);
System.out.println("root path: " + f.getAbsolutePath());
return new NodeManager(f);
public static NodeType.NormalRepository createNormalRepository(String name,
NodeManager nodeManager) {
NodeType.NormalRepository repository = new NodeType.NormalRepository(
nodeManager);
repository.getSettings().setProperty(NodeType.NAME_PROPERTY, name);
repository.getSettings().setProperty(NodeType.BROWSER_PROPERTY, "7777");
repository.getSettings().setProperty(NodeType.PORT_PROPERTY, "2036");
return repository;
public static NodeType.Client createClient(String name,
NodeManager nodeManager, String browserPort, String server) {
NodeType.Client client = new NodeType.Client(nodeManager);
client.getSettings().setProperty(NodeType.NAME_PROPERTY, name);
.setProperty(NodeType.BROWSER_PROPERTY, browserPort);
client.getSettings().setProperty(NodeType.SERVER_PROPERTY, server);
return client;
Re: [CDO] Possible bug in CDORepositorySynchronizer? [message #1016695 is a reply to message #1016564] |
Thu, 07 March 2013 06:25   |
Hi Andrew,
There's a first exception that you didn't mention:
Exception in thread "main" org.eclipse.net4j.util.container.FactoryNotFoundException: Factory not found:
org.eclipse.emf.cdo.server.browsers[default]
at org.eclipse.net4j.util.container.ManagedContainer.getFactory(ManagedContainer.java:228)
at org.eclipse.net4j.util.container.ManagedContainer.createElement(ManagedContainer.java:562)
at org.eclipse.net4j.util.container.ManagedContainer.getElement(ManagedContainer.java:320)
at org.eclipse.net4j.util.container.ManagedContainer.getElement(ManagedContainer.java:301)
at org.eclipse.emf.cdo.examples.client.offline.nodes.NodeType.start(NodeType.java:232)
at org.eclipse.emf.cdo.examples.client.offline.nodes.Node.start(Node.java:112)
at org.eclipse.emf.cdo.examples.client.offline.nodes.TestCDOOffline.main(TestCDOOffline.java:52)
You fix it by adding this to your stand-alone code:
IPluginContainer.INSTANCE.registerFactory(new CDOServerBrowser.ContainerBased.Factory());
Then there's a NullPointerException that you didn't mention, either:
org.eclipse.emf.cdo.sessions[cdo]
at org.eclipse.emf.cdo.examples.client.offline.nodes.NodeType$Client.start(NodeType.java:549)
at org.eclipse.emf.cdo.examples.client.offline.nodes.TestCDOOffline.main(TestCDOOffline.java:58)
You can fix it by adding this to your stand-alone code:
CDONet4jUtil.prepareContainer(IPluginContainer.INSTANCE);
Well, I just realized that this call does not add the needed Net4jConnectorInjector to the container. I've fixed that in
the master branch:
402636: Net4jConnectorInjector is missing from CDONet4jUtil.prepareContainer()
https://bugs.eclipse.org/bugs/show_bug.cgi?id=402636
You can work around this problem by adding this to your stand-alone code:
IPluginContainer.INSTANCE.addPostProcessor(new Net4jConnectorInjector());
Finally, the NullPointerException you mentioned seems to be caused by a bug in
SynchronizableRepository.replicateRawNotifyClients(long, long). These last two lines are not from me and I can currently
not make a sense out of them:
CDOLockChangeInfo lockChangeInfo = CDOLockUtil.createLockChangeInfo();
sessionManager.sendLockNotification(replicatorSession, lockChangeInfo);
Please submit a bugzilla so that I can investigate in more depth. Meanwhile you can just comment these two lines out and
avoid to use explicit durable locks in your example code.
Cheers
/Eike
http://www.esc-net.de
Am 06.03.2013 23:50, schrieb Andrew Whelan:
> Hello,
> public static void main(String[] args) {
> // Net4j kernel
> // support
> normal1.start();
> return props;
> nodeManager);
> return repository;
> return client;
Re: [CDO] Possible bug in CDORepositorySynchronizer? [message #1016859 is a reply to message #1016695] |
Thu, 07 March 2013 18:01   |
[quote title=Eike Stepper wrote on Thu, 07 March 2013 06:25]Hi Andrew,
Quote:Ok, in this case I actually had commented out the code that would have caused the exception during my investigation. Thanks for clearing this up. Sorry about the confusion.
Quote:You're amazing!. That is buried in there. I thought I saw some red text flash before my eyes once or twice. I did some "Find" searches on Exception but, I must not have boosted my buffer size those times....
the master branch:
Quote:[
I will create a bug, but I wanted to try your fix. I cant seem to check out the source code. I really didn't want to ask about this but, I'm burning an enormous amount of time on this(all afternoon). I tried the Buckminster route in http://wiki.eclipse.org/CDO_Source_Installation (using http://git.eclipse.org/c/cdo/cdo.git/plain/plugins/org.eclipse.emf.cdo.releng/local.mspec).
I get ERROR [0001] : No suitable provider for component org.eclipse.emf.cdo.releng:osgi.bundle was found in resourceMap http://git.eclipse.org/c/cdo/cdo.git/plain/plugins/org.eclipse.emf.cdo.releng/build.rmap.
I have the GIT GUI and tried cloning it, using http://git.eclipse.org/c/cdo/cdo.git/tag/?id=drops/S20130205-06 for the Source location.
I get
fatal: http://git.eclipse.org/c/cdo/cdo.git/tag/?id=drops/S20130205-0640/info/refs not valid: is this a git repository?
Also, what is the URL for the master branch? Is it that one from the http://wiki.eclipse.org/CDO_Source_Installation instructions.
I downloaded the emf-cdo-S20130205-0640-Dropins.zip and imported the plugins into Eclipse but couldn't figure out how to get that to compile. I am used to using a Target Platform (application .target) file solution and didn't find one in any of those plugins.
Any crumbs you could throw would be appreciated.
/quote]
Cheers
/Eike
> Hello,
> // Net4j kernel
> // support
> normal1.start();
> return props;
> nodeManager);
> return repository;
> return client;
Re: [CDO] Possible bug in CDORepositorySynchronizer? [message #1017048 is a reply to message #1016891] |
Fri, 08 March 2013 13:32   |
Eike Stepper wrote on Fri, 08 March 2013 00:21Am 08.03.2013 00:01, schrieb Andrew Whelan:
>> http://git.eclipse.org/c/cdo/cdo.git/plain/plugins/org.eclipse.emf.cdo.releng/local.mspec). I get ERROR [0001] : No
>> the Source location. I get
Hmm, please try this one: git://git.eclipse.org/gitroot/cdo/cdo.git
Then import all projects into the workspace and then run Import on the local.mspec. That should provision your target
platform.
>> instructions.
It's better to use Bucky. Let me know if the above helps.
Quote:I was able to use the GIT GUI to clone http://git.eclipse.org/gitroot/cdo/cdo.git.
Then I was able to Import->Projects from GIT->Select a GIT Repository and just import everything (I couldn't find a URL to the .mspec, so this is what I was able to get working).
I set the API Baseline default to the plugins directory of the downloaded stuff(in the GIT repository).
I ran import on org.eclipse.emf.releng/local.mspec. It did its thing and only warnings like the following were produced:WARNING [0012] : Component request org.junit:osgi.bundle/[3.8.2.v3_8_2_v20100427-1100,3.8.2.v3_8_2_v20100427-1100] is in conflict with request org.junit:osgi.bundle/[4.10.0.v4_10_0_v20120426-0900,4.10.0.v4_10_0_v20120426-0900]
The trouble is that the project did not all build correctly. There are 1707 errors.
The compilation errors at the top of the Problems list involve files in the ..releng.doc plugin because the com.sun.javadoc package cannot be found (Example: ClassDoc cannot be resolved to a type). There are also a bunch of "Invalid @since" tag errors that might be related to the com.sun.javadoc issue?
The de.escnet package is also not being resolved.
I am not really familiar with Buckminster but seeing as you recommend it I assume its what you all are using. I'm hoping there is something minor that comes to mind for you? Maybe I don't have all of the Eclipse tooling that I should have? Or maybe I need to edit something in the buckminster build files to satisfy the third party dependency issues?
Cheers
/Eike
Re: [CDO] Possible bug in CDORepositorySynchronizer? [message #1018252 is a reply to message #1017097] |
Wed, 13 March 2013 09:52   |
Is there an easy way to just build the Jar I need (say org.eclipse.emf.cdo.server_4.2.0.v20130126-0958.jar)?
I want to just comment out the two lines of code you mentioned above, build and replace the said jar, and see if I can get any further with this.
I couldn't get the ANT build to work (in org.eclipse.emf.cdo.releng) because ${hudson.WORKSPACE} didn't exist. I think this might have had something to do with one of those funky imports where there are really no plugins in my workspace folder. All of the packages showing up in my package explorer were actually pointers into my GIT repository. Anyhow, I found a way to re-import the plugins so they are copied into my workspace (they are physically located there).
When I try to run Import on the local.mspec in the org.eclipse.emf.cdo.releng package
and I keep getting the following errors. Does anyone have an idea what might be happening? Thanks
ERROR [0002] : No suitable provider for component org.eclipse.emf.cdo.site:eclipse.feature was found in resourceMap file:/D:/Shepherd/workspace_cdo_build/org.eclipse.emf.cdo.releng/build.rmap
ERROR [0002] : No suitable provider for component org.eclipse.emf.cdo.site:eclipse.feature was found in searchPath git
ERROR [0002] : Rejecting provider git({0},plugins/{1}[C:\Users\awhelan/git/cdo,plugins/org.eclipse.emf.cdo.site]): Components of type eclipse.feature are not supported
ERROR [0002] : Rejecting provider git({0},features/{1}-feature[C:\Users\awhelan/git/cdo,features/org.eclipse.emf.cdo.site-feature]): No component match was found
ERROR java.lang.NullPointerException
ERROR [0002] : No suitable provider for component oracle.database.driver.jdk50:osgi.bundle was found in resourceMap file:/D:/Shepherd/workspace_cdo_build/org.eclipse.emf.cdo.releng/build.rmap
ERROR [0002] : No suitable provider for component oracle.database.driver.jdk50:osgi.bundle was found in searchPath p2
ERROR [0002] : Rejecting provider p2(http://download.eclipse.org/eclipse/updates/{0}[http://download.eclipse.org/eclipse/updates/3.8]): No component match was found
ERROR [0002] : Rejecting provider p2(https://hudson.eclipse.org/hudson/job/emf-core-head/384/artifact/EMF.p2.repository[https://hudson.eclipse.org/hudson/job/emf-core-head/384/artifact/EMF.p2.repository]): No component match was found
ERROR [0002] : Rejecting provider p2(http://download.eclipse.org/modeling/emf/updates/milestones[http://download.eclipse.org/modeling/emf/updates/milestones]): No component match was found
ERROR [0002] : Rejecting provider p2(http://download.eclipse.org/modeling/emf/compare/updates/interim/2.1[http://download.eclipse.org/modeling/emf/compare/updates/interim/2.1]): No component match was found
ERROR [0002] : Rejecting provider p2(http://download.eclipse.org/modeling/emft/mwe/updates/milestones[http://download.eclipse.org/modeling/emft/mwe/updates/milestones]): No component match was found
ERROR [0002] : Rejecting provider p2(http://download.eclipse.org/modeling/amalgam/temp/ecoretools-1.0.0[http://download.eclipse.org/modeling/amalgam/temp/ecoretools-1.0.0]): No component match was found
ERROR [0002] : Rejecting provider p2(http://download.eclipse.org/tools/gef/updates/milestones[http://download.eclipse.org/tools/gef/updates/milestones]): No component match was found
ERROR [0002] : Rejecting provider p2(http://download.eclipse.org/graphiti/updates/milestones[http://download.eclipse.org/graphiti/updates/milestones]): No component match was found
ERROR [0002] : Rejecting provider p2(http://download.eclipse.org/modeling/gmp/updates/milestones[http://download.eclipse.org/modeling/gmp/updates/milestones]): No component match was found
ERROR [0002] : Rejecting provider p2(http://download.eclipse.org/modeling/mdt/ocl/updates/milestones/4.1.0[http://download.eclipse.org/modeling/mdt/ocl/updates/milestones/4.1.0]): No component match was found
ERROR [0002] : Rejecting provider p2(http://download.eclipse.org/mmt/qvto/updates/milestones[http://download.eclipse.org/mmt/qvto/updates/milestones]): No component match was found
ERROR [0002] : Rejecting provider p2(http://download.eclipse.org/modeling/mdt/uml2/updates/4.0.x[http://download.eclipse.org/modeling/mdt/uml2/updates/4.0.x]): No component match was found
ERROR [0002] : Rejecting provider p2(http://download.eclipse.org/modeling/m2t/xpand/updates/milestones[http://download.eclipse.org/modeling/m2t/xpand/updates/milestones]): No component match was found
ERROR [0002] : Rejecting provider p2(http://download.eclipse.org/technology/swtbot/helios/dev-build/update-site[http://download.eclipse.org/technology/swtbot/helios/dev-build/update-site]): No component match was found
ERROR [0002] : Rejecting provider p2(http://download.eclipse.org/mylyn/snapshots/kepler[http://download.eclipse.org/mylyn/snapshots/kepler]): No component match was found
ERROR [0002] : Rejecting provider p2(http://download.eclipse.org/egit/updates-nightly[http://download.eclipse.org/egit/updates-nightly]): No component match was found
ERROR [0002] : Rejecting provider p2(http://download.eclipse.org/tools/buckminster/headless-4.2[http://download.eclipse.org/tools/buckminster/headless-4.2]): No component match was found
ERROR [0002] : Rejecting provider p2(http://download.eclipse.org/technology/nebula/snapshot[http://download.eclipse.org/technology/nebula/snapshot]): No component match was found
ERROR [0002] : Rejecting provider p2(http://download.eclipse.org/tools/orbit/downloads/drops/{0}/repository[http://download.eclipse.org/tools/orbit/downloads/drops/S20130308121626/repository]): No component match was found
ERROR [0002] : Rejecting provider p2(http://download.eclipse.org/modeling/emf/teneo/updates/2.0.0/interim[http://download.eclipse.org/modeling/emf/teneo/updates/2.0.0/interim]): No component match was found
ERROR [0002] : Rejecting provider p2(http://download.oracle.com/otn_software/oepe/juno[http://download.oracle.com/otn_software/oepe/juno]): No component match was found
ERROR No repository found at http://download.oracle.com/otn_software/oepe/juno/.
ERROR [0002] : Rejecting provider p2(http://www.elver.org/eclipse/2.0.0/update[http://www.elver.org/eclipse/2.0.0/update]): No component match was found
WARNING [0008] : Component request org.junit:osgi.bundle/[3.8.2.v3_8_2_v20100427-1100,3.8.2.v3_8_2_v20100427-1100] is in conflict with request org.junit:osgi.bundle/[4.10.0.v4_10_0_v20120426-0900,4.10.0.v4_10_0_v20120426-0900]
WARNING [0008] : Component request org.junit:osgi.bundle/[3.8.2.v3_8_2_v20100427-1100,3.8.2.v3_8_2_v20100427-1100] is in conflict with request org.junit:osgi.bundle/4.8.1
WARNING [0008] : Component request org.junit:osgi.bundle/[3.8.2.v3_8_2_v20100427-1100,3.8.2.v3_8_2_v20100427-1100] is in conflict with request org.junit:osgi.bundle/4.7.0
ERROR [0050] : java.lang.ArrayIndexOutOfBoundsException: -1
Attempt to use an unresolved node. Request is org.hamcrest.text.source:osgi.bundle/[1.1.0.v20090501071000,1.1.0.v20090501071000]
Re: [CDO] Possible bug in CDORepositorySynchronizer? [message #1018346 is a reply to message #1018252] |
Wed, 13 March 2013 12:43   |
Am 13.03.2013 14:52, schrieb Andrew Whelan:
Why don't you just export the plugin(s) in question via PDE?
Unfortunately the Ant build is really made for the Eclipse.org build server because it does a lot more than just build.
> are not supported
> was found
Buckminster is supposed to show stack traces with --displaystacktrace, but then there is
https://bugs.eclipse.org/bugs/show_bug.cgi?id=372470 ;-(
> match was found
> match was found
> match was found
This could be an instance of http://www.eclipse.org/forums/index.php/m/676099 , which also lets our build fail every
once in a while ;-(
Cheers
/Eike
Re: [CDO] Possible bug in CDORepositorySynchronizer? [message #1018444 is a reply to message #1018346] |
Wed, 13 March 2013 17:00   |
Eike Stepper wrote on Wed, 13 March 2013 12:43Am 13.03.2013 14:52, schrieb Andrew Whelan:
Quote:Yes, I can do that for now. The temporary fix you mentioned above works. I created bug 403229 as you asked earlier today.
Quote:So there isn't really a configured way in the downloaded code to generate JARs? If I do Buckminster->Invoke Action on local.mspec and build.mspec and choose bundle.jar, I have the opportunity to choose the build.properties or plubin.properties in org.eclipse.emf.cdo.server. When I do this something happens but the output in the console (shown below) doesn't give me too many clues. I'm not sure what the below means. I cant seem to find an updated jar anywhere so I'm assuming this won't help me?
[start org.eclipse.emf.cdo.releng:osgi.bundle$4.2.0.qualifier#eclipse.build]
[end org.eclipse.emf.cdo.releng:osgi.bundle$4.2.0.qualifier#eclipse.build]
Quote:I was kind of hoping we could set up a mirror of the environment you are working with so we could make modifications and donate the updates back to you guys if we ever get rolling with this stuff here. It probably wont be real soon (It could be a matter of a few months before we got to that point).
Quote:For the record though, the Buckminster configuration that I have downloaded and built here isn't really sufficient for development purposes is it?
Thanks! -Andrew
> are not supported
> was found
> match was found
> match was found
> match was found
once in a while ;-(
Cheers
/Eike
Re: [CDO] Possible bug in CDORepositorySynchronizer? [message #1018734 is a reply to message #1018444] |
Thu, 14 March 2013 07:33   |
Andrew,
How are you replying to forum posts? The entire post below is a huge quote and very hard to parse ;-(
Comments below...
Am 13.03.2013 22:00, schrieb Andrew Whelan:
>> can > get any further with this.
>> Quote:
>> today.
Thanks!
>> Quote:
No other way than the aforementioned PDE export.
>> Quote:
Buckminster should do that for you. I'll try to test it with a fresh local workspace...
>> Quote:
It should be: http://wiki.eclipse.org/CDO_Source_Installation
Cheers
/Eike
Re: [CDO] Possible bug in CDORepositorySynchronizer? [message #1018768 is a reply to message #1018734] |
Thu, 14 March 2013 08:42   |
Eike Stepper wrote on Thu, 14 March 2013 07:33Andrew,
Quote:How do you? Honestly, I've tried figuring out how to do what you are doing and their must be something simple I am missing. I felt stupid for asking before so now I am just going to make a public spectacle out of myself. LOL. If I hit the quote button below and quote the whole thing my comments and your latest comments are indistinguishable from eachother.
Comments below...
>> Quote:
>> today.
Thanks!
>> Quote:
Quote:So it sounds like we will need to come up with our own way to turn CDO code into JAR artifacts for when we need to productize our applications. Correct?
>> Quote:
>> Quote:
Cheers
/Eike
Re: [CDO] Possible bug in CDORepositorySynchronizer? [message #1018849 is a reply to message #1018768] |
Thu, 14 March 2013 11:09  |
Am 14.03.2013 13:42, schrieb Andrew Whelan:
>> Andrew,
>> Quote:
>> > How do you?
I use Thunderbird's NNTP client.
>> from eachother.
>> Comments below...
>> I >> can > get any further with this.
>> >> Quote:
>> earlier >> today.
>> Thanks!
>> build.
>> >> Quote:
>> >> > So there isn't really a configured way in the downloaded code to generate JARs? No other way than the
>> Quote:
>> to >> choose the build.properties or plubin.properties in org.eclipse.emf.cdo.server. When I do this something
>> happens but >> the output in the console (shown below) doesn't give me too many clues. I'm not sure what the below
>> means. I cant >> seem to find an updated jar anywhere so I'm assuming this won't help me?
>> >> Quote:
>> >> > I was kind of hoping we could set up a mirror of the environment you are working with so we could make >>
>> >> Quote:
>> sufficient >> for development purposes is it?
>> Cheers
>> /Eike
>> http://thegordian.blogspot.com
>> http://twitter.com/eikestepper
Current Time: Wed Jul 23 15:28:40 EDT 2025
Powered by FUDForum. Page generated in 0.06036 seconds
