Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMFCore](Using EMFStore without RCP )
[EMFCore] [message #1016506] Wed, 06 March 2013 12:07 Go to next message
Can i use EMFStore without the RCP way?
i.e. Can i just send xmi and corresponding ecore to the EMFStore so it can validate the xmi against the given ecore and persist the model
Its not for lack of trying i have not found much help on web searches.
Shiv
[Updated on: Thu, 07 March 2013 00:20] by Moderator
Re: [EMFCore] [message #1016662 is a reply to message #1016506] Thu, 07 March 2013 04:49 Go to previous messageGo to next message
you can use EMFStore without the provided UI. There is example code on
how to use EMFStore headless here:
http://eclipse.org/emfstore/documentation/howToUseExamples.php
You could also directly access the Server by XmlRPC, but I think it is a
lot simpler to use the client-side API.
Maximilian
Am 07.03.2013 02:36, schrieb Shiv Reddy:
> Thanks
> Shiv
Maximilian Kögel
Get Professional Eclipse Support: http://eclipsesource.com/munich
Re: [EMFCore] [message #1016768 is a reply to message #1016662] Thu, 07 March 2013 10:58 Go to previous messageGo to next message
Hi Maximilian,
I have gone through all the tutorials, my requirement is a little different.
As per the tutorial i see the Objects are created as shown below
League league1 = BowlingFactory.eINSTANCE.createLeague();
league1.setName("league");
league1.getPlayers().add(createPlayer("no. 1"));
league1.getPlayers().add(createPlayer("no. 2"));
project1.getProject().addModelElement(league1);
I would never have a predefined object, i would rather get a ecore metamodel and corresponding xmi model that i wish to persist in EMFStore.
What i would want is a wrapper on the EMFStore server that would process this xmi, validate against the ecore and persist.
Looked at dynamic EMF but couldn't figure out how to go from ecore/xmi to EObjects in EMFStore
Shiv
Re: [EMFStore] [message #1016805 is a reply to message #1016768] Thu, 07 March 2013 13:00 Go to previous message
Hi Shiv,
you can load an XMI-File with EMF as is. Once it is loaded you could add
the EObjects loaded from the Cmi to an EMFStore project as shown in the
tutorial.
Maximilian
Am 07.03.2013 16:58, schrieb Shiv Reddy:
> Hi Maximilian,
> different.
> Shiv
Maximilian Kögel
Previous Topic:[EMFatic] Link emfatic file with ecore file
Next Topic:[Texo] using Texo + Eclipselink in a J2SE environment
Current Time: Sat Jul 26 07:55:47 EDT 2025
Powered by FUDForum. Page generated in 0.40431 seconds
