Home » Modeling » Epsilon » [ETL] Transforming to herited model
[ETL] Transforming to herited model [message #1016379] Wed, 06 March 2013 05:00 Go to next message
Hello
I'm using ETL to perform a transformation from a model A to a model B.
The metamodel MA is an extension of the metamodel MB. Therefore, I have common objects.
The identical objects are tagged as object from MA when performing the transformation.
So far, I've had to write a rule to transform each element.
I was wondering if there was a more efficient way to transform the elements which are common to MA and MB, and thus not to write the associated rules.
Christophe
[Updated on: Thu, 07 March 2013 04:59] by Moderator
Re: [ETL] Transforming to herited model [message #1016872 is a reply to message #1016379] Thu, 07 March 2013 20:08 Go to previous messageGo to next message
Hi Christophe,
One option would be to use Flock instead of ETL [1]. Another option would be to write a model-to-text transformation that generates a copy ETL transformation from the MB Ecore metamodel and then import and refine the generated copy transformation from a 2nd transformation which deals with the additional EClasses in MA.
Dimitris
[1] http://www.eclipse.org/epsilon/doc/flock/
Re: [ETL] Transforming to herited model [message #1017184 is a reply to message #1016379] Sun, 10 March 2013 15:58 Go to previous message
Hi Dimitris
Thanks for the answer, I'll look into Flock, that seems to be a nice tool for what I want to do.
Best Reguards,
Christophe
Previous Topic:EVL-Validating from a node different of root not working until root validation is made
Next Topic:EVL Quick Fix
Current Time: Sat Jul 26 16:58:30 EDT 2025
Powered by FUDForum. Page generated in 0.03547 seconds
