Home » Eclipse Projects » Remote Application Platform (RAP) » RWT ServiceManager
RWT ServiceManager [message #1015943] Mon, 04 March 2013 06:13 Go to next message
Hello!
I have used the new ServiceHandler to register images. I used an incrementing counter to create unique ids seperately for each user session (with SessionSingletonBase ..). I now noticed in a multi user environment, that the ids have to be unique among all client sessions. Is this the intended behavior?
Tiburon
Re: RWT ServiceManager [message #1016128 is a reply to message #1015943] Tue, 05 March 2013 02:49 Go to previous messageGo to next message
Tiburon,
could you elaborate a bit more what you use these ids for?
Thanks, Ralf
Ralf Sternberg
Twitter: @EclipseRAP
Re: RWT ServiceManager [message #1016194 is a reply to message #1016128] Tue, 05 March 2013 07:47 Go to previous messageGo to next message
Hello Ralf,
I use the ids like this (slightly changed example from [1]):
int id = 0; // This comes from a SessionSingleton
ServiceManager manager = RWT.getServiceManager();
String did = "download" + id++;
manager.registerServiceHandler( did, new DownloadServiceHandler() );
String url = manager.getServiceHandlerUrl( did );
I changed the ID generation to this(works fine):
String did = "download" + id++ + RWT.getUISession().getId();
It just seemed a little odd to me, that the ID is not scoped in the UISession.
I thought it might not hurt to post it here, to make sure it is no bug Smile .
Tiburon
[1]http://eclipse.org/rap/noteworthy/2.0/migration-guide/
Re: RWT ServiceManager [message #1016356 is a reply to message #1016194] Wed, 06 March 2013 02:53 Go to previous message
Hi Tiburon,
ServiceHandlers have application scope. Thus you should register them
only once with a fixed id. However, the service handler has access to
the current UISession.
If you need a sequence id for your downloads, you could either increment
it in your service handler directly, or you could append it as parameter
to your URL like this:
String url = manager.getServiceHandlerUrl( shid )
+ "&downloadId=" + id++;
HTH,
Ralf
Ralf Sternberg
Previous Topic:Misaligned Table Column Headers
Next Topic:RAP Running in Eclipse Internal Browser
Current Time: Fri Jul 25 09:50:09 EDT 2025
Powered by FUDForum. Page generated in 0.05163 seconds
