How to delete the test cases which moved to external project [message #1016339] |
Wed, 06 March 2013 01:26  |
Once I moved a testcase to unbound_modules_concrete_[6.0],which was used by a Project. After that I need to modify the properties of the testcase,but I found that it can't to be edited,so I create another testcase to exchange it.
There is the problem,I can edit and run well on the ITE in this time I change the testcase, but if I open the project next time,it return to the initial one. Could anyone give me some advices to solve it? Thank you very much!
Posia
[Updated on: Thu, 07 March 2013 02:41] by Moderator
Re: How to delete the test cases which moved to external project [message #1016905 is a reply to message #1016349] |
Fri, 08 March 2013 02:57  |
Thanks for posting your solution. As a general rule, I'd advise strongly against adding your own test cases to the unbound modules - these get updated regularly and if you add your own test cases, then you can either no longer update, or you lose your test cases. If you're creating a library project, it's a better idea to have your own, separate project for it.
Alex
FUDForum. Page generated in 0.24859 seconds
