Home » Archived » Visual Editor (VE) » SWT Shell and Composite Propertie view stays empty
SWT Shell and Composite Propertie view stays empty [message #101372] Fri, 05 August 2005 15:52 Go to next message
When I tried the VE to create an RCP View or Editor, it's working fine.
But when I try to create a SWT Shell or Composite, the Properties view
stays empty.
I removed my eclipse installation and ~/.eclipse, reinstalled
everything: once from the 'find and install' menu, once from the .zip's
and both not working.
Then I tried the swing applications and they are working fine too.
Kinda weird, since no one else seems to have this problem ?
Kind regards, Toon Geens
Re: SWT Shell and Composite Propertie view stays empty [message #101410 is a reply to message #101372] Fri, 05 August 2005 20:46 Go to previous messageGo to next message
Would like to understand the scenario better - How is the
shell/composite being created (new visual class wizard/..)? Do you see
the shell and composite on the graphical view and java beans view? Also
are there any errors in the logs?
Sri.
> stays empty.
Re: SWT Shell and Composite Propertie view stays empty [message #101632 is a reply to message #101410] Tue, 09 August 2005 12:26 Go to previous message
Also, is your default Installed Java a 1.4.2 or higher? 1.4.1 won't work
correctly with the SWT and VE.
Sri Gunturi wrote:
> Hello,
> Regards,
> Sri.
>> stays empty.
>> .zip's and both not working.
Rich Kulp
Re: SWT Shell and Composite Propertie view stays empty [message #610159 is a reply to message #101372] Fri, 05 August 2005 20:46 Go to previous message
Sri.
> stays empty.
Re: SWT Shell and Composite Propertie view stays empty [message #610196 is a reply to message #101410] Tue, 09 August 2005 12:26 Go to previous message
Sri Gunturi wrote:
> Hello,
> Regards,
> Sri.
>> stays empty.
Rich Kulp
Previous Topic:Error Log entries loading VE w/ WTP 0.7
Next Topic:VE Internal
Current Time: Sat Jul 26 09:32:57 EDT 2025
Powered by FUDForum. Page generated in 0.25135 seconds
