PDT Broken in Juno - PHP Perspective not available [message #1014951] |
Tue, 26 February 2013 17:41  |
Hi all. I'm at wits end here. I'm switching up to Eclipse 4.2 Juno and I'm having a lot of problems getting PDT working.
Basically, I have tried fresh installs of Eclipse EE, Java Dev, Classic and C++ Dev. I then have tried installing PDT 3.0, 3.1 and 3.2 on all versions. All fresh.
And nadda. Zip. Nothing. PDT just refuses to work at all. It says it's installed, but there is no PHP node in the preferences, nor is there a PHP perspective available.
What the frack is going on? I've never had the problems installing PDT before. Should I just give up? I'm incredibly frustrated here.
Any help would be appreciated.
Re: PDT Broken in Juno - PHP Perspective not available [message #1235268 is a reply to message #1016185] |
Thu, 23 January 2014 19:03  |
Vignesh Sabapathi wrote on Tue, 05 March 2013 06:54Hi Jamie,
Please install the previously installed all php related plugins. Once eclipse got restarted go to "Help -> Install New Software", select the "Juno - http://download.eclipse.org/releases/juno" entry from the "Work with" dropdown.
Under the "Web, XML, Java EE and OSGi Enterprise Developmet" category, select "PHP Development Tools (PDT) SDK Feature 3.1.1.201209101312". Click and install only this and once restarted eclipse you can able to get php perspective.
Vignesh
Thank You for your solution Mr. Vighnes. it working out. Good Job!
FUDForum. Page generated in 0.49359 seconds
